nRF9160 DK Asset Tracker not reliably finding network
I am having trouble getting the nRF9160 DK to find a network running the Asset Tracker than came in the device.  It appears to reset after 15 seconds of LED 3 blinking.  I can connect the LTE Link Monitor and watch it do that.  Secure Boot boots to Zephyr and then about 15 seconds approx later it says it failed (nrf_cloud_connect failed: 60) and starts all over again.  Really difficult and unreliable to get to the state of LED 3 and LED 4 both blinking.  Sometimes just stops with LED 3 lit solid.
I have had it connected a number of times, but not reliably. The SIM is registered.  This is making it difficult to get the things linked to my nRF Cloud account when I am having trouble even getting to the pattern entry portion of setting this up.
Is there an issue with the asset tracker that came in the device such that it won't connect?  Something else I might have going on?  I have not loaded anything different into the DK than what it came with.
Erik
  • Hello Erik,
    Can you please verify that you have the latest modem FW? The latest version can be found here.
    You can check the modem FW using the AT Command  AT+CGMR. AT Commands are available using the AT Client example, found here, and running the LTE Link Monitor will run the command for you (Follow this video).
    Oeyvind
  • I did not have the latest modem firmware but have updated now.
    I am not having any better results.
    Here is a video of what the LED looks like, if it works.
    What I see in LTE Link Monitor is below.
    This can't be behaving as expected.
    Erik
    ***** Booting Zephyr OS v1.13.99-ncs2 *****
    Application started
    LTE LC config ...
    Secure Boot: configure flash
    Secure Boot: SPU: set region 0 as Secure
    Secure Boot: SPU: set region 1 as Secure
    Secure Boot: SPU: set region 2 as Secure
    Secure Boot: SPU: set region 3 as Secure
    Secure Boot: SPU: set region 4 as Secure
    Secure Boot: SPU: set region 5 as Secure
    Secure Boot: SPU: set region 6 as Secure
    Secure Boot: SPU: set region 7 as Secure
    Secure Boot: SPU: set Flash region 8 as Non-Secure
    Secure Boot: SPU: set Flash region 9 as Non-Secure
    Secure Boot: SPU: set Flash region 10 as Non-Secure
    Secure Boot: SPU: set Flash region 11 as Non-Secure
    Secure Boot: SPU: set Flash region 12 as Non-Secure
    Secure Boot: SPU: set Flash region 13 as Non-Secure
    Secure Boot: SPU: set Flash region 14 as Non-Secure
    Secure Boot: SPU: set Flash region 15 as Non-Secure
    Secure Boot: SPU: set Flash region 16 as Non-Secure
    Secure Boot: SPU: set Flash region 17 as Non-Secure
    Secure Boot: SPU: set Flash region 18 as Non-Secure
    Secure Boot: SPU: set Flash region 19 as Non-Secure
    Secure Boot: SPU: set Flash region 20 as Non-Secure
    Secure Boot: SPU: set Flash region 21 as Non-Secure
    Secure Boot: SPU: set Flash region 22 as Non-Secure
    Secure Boot: SPU: set Flash region 23 as Non-Secure
    Secure Boot: SPU: set Flash region 24 as Non-Secure
    Secure Boot: SPU: set Flash region 25 as Non-Secure
    Secure Boot: SPU: set Flash region 26 as Non-Secure
    Secure Boot: SPU: set Flash region 27 as Non-Secure
    Secure Boot: SPU: set Flash region 28 as Non-Secure
    Secure Boot: SPU: set Flash region 29 as Non-Secure
    Secure Boot: SPU: set Flash region 30 as Non-Secure
    Secure Boot: SPU: set Flash region 31 as Non-Secure
    Secure Boot: configure SRAM
    Secure Boot: SPU: set SRAM region 0 as Secure
    Secure Boot: SPU: set SRAM region 1 as Secure
    Secure Boot: SPU: set SRAM region 2 as Secure
    Secure Boot: SPU: set SRAM region 3 as Secure
    Secure Boot: SPU: set SRAM region 4 as Secure
    Secure Boot: SPU: set SRAM region 5 as Secure
    Secure Boot: SPU: set SRAM region 6 as Secure
    Secure Boot: SPU: set SRAM region 7 as Secure
    Secure Boot: SPU: set SRAM region 8 as Non-Secure
    Secure Boot: SPU: set SRAM region 9 as Non-Secure
    Secure Boot: SPU: set SRAM region 10 as Non-Secure
    Secure Boot: SPU: set SRAM region 11 as Non-Secure
    Secure Boot: SPU: set SRAM region 12 as Non-Secure
    Secure Boot: SPU: set SRAM region 13 as Non-Secure
    Secure Boot: SPU: set SRAM region 14 as Non-Secure
    Secure Boot: SPU: set SRAM region 15 as Non-Secure
    Secure Boot: SPU: set SRAM region 16 as Non-Secure
    Secure Boot: SPU: set SRAM region 17 as Non-Secure
    Secure Boot: SPU: set SRAM region 18 as Non-Secure
    Secure Boot: SPU: set SRAM region 19 as Non-Secure
    Secure Boot: SPU: set SRAM region 20 as Non-Secure
    Secure Boot: SPU: set SRAM region 21 as Non-Secure
    Secure Boot: SPU: set SRAM region 22 as Non-Secure
    Secure Boot: SPU: set SRAM region 23 as Non-Secure
    Secure Boot: SPU: set SRAM region 24 as Non-Secure
    Secure Boot: SPU: set SRAM region 25 as Non-Secure
    Secure Boot: SPU: set SRAM region 26 as Non-Secure
    Secure Boot: SPU: set SRAM region 27 as Non-Secure
    Secure Boot: SPU: set SRAM region 28 as Non-Secure
    Secure Boot: SPU: set SRAM region 29 as Non-Secure
    Secure Boot: SPU: set SRAM region 30 as Non-Secure
    Secure Boot: SPU: set SRAM region 31 as Non-Secure
    Secure Boot: configure peripherals
    Secure Boot: MSP_NS 2002ab70
    Secure Boot: prepare to jump to Non-Secure image
    Application started
    LTE LC config ...
    Application started
    LTE LC config ...
  • Hi Erik,
    My sincere apologies for the delayed answer. I am discussing this topic with my colleagues and will get back to you ASAP.
    Oeyvind
