PC-BLE-Driver (C/C++) Installation on Windows 10 : Building Problem of Connectivity HEX file with MSBuild & CMD.exe
Hello, this is Kwonjoon Lee from Korea.
I would like to ask about building problem of connectivity HEX file of pc-ble-driver (C/C++).
Actually, installation of the pc-ble-driver (C/C++) on Windows have many issues !!!
so that I cannot install smoothly according to the guide in the following Git Hub. Please help me.
(https://github.com/NordicSemiconductor/pc-ble-driver#Architecture
(Development Environments)
1) Windows 10 64 Bit with cmd.exe (administrator)
2) Visual Studio 2015
3) GCC-ARM-Embedded Version : 7.3.1
(Default installation version of the guide was 7.2.1, and it had cmake error during "Compiling Connectivity HEX Files on the Windows"
in the above-mentioned Git Hub guide due to the version of the gcc-arm-embedded. So I changed it)
4) Python Version 3.7.2
(Detailed Problem)
During the 3. MSBuild stage, building is progressed and successful for a while,
However, I got a error in the building of "compile_connectivity_1.0.0_usb_with_s132_3.1.0.vcproj" as following sentences.
CustomBuild:
Generating connectivity_1.0.0_usb_with_s132_3.1.0_cmd
Makefile:260: Cannot find source file: ../../../../../../components/serialization/connectivity/codecs/ble/serializers
/conn_ble_l2cap_sdu_pool_1.c
Assembling file: gcc_startup_nrf52840.S
Compiling file: nrf_log_backend_rtt.c
Compiling file: nrf_log_backend_serial.c
Compiling file: ble_gatts_evt_conn.c
Compiling file: ble_gatts_struct_serialization.c
Compiling file: ble_l2cap_conn_1.c
../../../../../../components/serialization/connectivity/codecs/ble/serializers/ble_l2cap_conn_1.c:47:10: fatal error:
conn_ble_l2cap_sdu_pool_1.h: No such file or directory
#include "conn_ble_l2cap_sdu_pool_1.h" // #include "conn_ble_l2cap_sdu_pool.h"
compilation terminated.
make: *** [../../../../../../components/toolchain/gcc/Makefile.common:272: _build/nrf52840_xxaa/ble_l2cap_conn_1.c.o]
Error 1
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Microsoft.CppCommon.targets(171,5): error MSB6006: "cmd.exe"이(가)
종료되었습니다(코드: 2). [C:\pc-ble-driver-master\hex\build\compile_connectivity_1.0.0_usb_with_s132_3.1.0.vcxproj]
As shown in the above-mentioned error message, the Makefile could not find "conn_ble_l2cap_sdu_pool.c" & "conn_ble_l2cap_sdu_pool.h"
So, I opened the Makefile in the following path
(Makefile Path)
C:\Users\~~~~~\AppData\Local\Temp\pc-ble-driver\sdks\v15\nRF5_SDK_15.2.0_9412b96
\examples\connectivity\ble_connectivity\pca10056\ser_s132v3_usb_hci\armgcc
(Related Contents in the Makefile)
$(SDK_ROOT)/components/serialization/connectivity/codecs/ble/serializers/conn_ble_l2cap_sdu_pool_1.c \
And, I found "conn_ble_l2cap_sdu_pool.c" & "conn_ble_l2cap_sdu_pool.h" are located
in the following path without any path error.
C:\Users\krbong\AppData\Local\Temp\pc-ble-driver\sdks\v15\nRF5_SDK_15.2.0_9412b96
\components\serialization\connectivity\codecs\ble\serializers
Also, I checked that above-mentioned path have full read & write authority,
and I made above-mentioned folders as a exception folder for anti-virus program.
However, still build error is generated. I have no idea.
If you need additional evidence & files, I can provide you.
If you give me any answer, it will be huge help for me.
Kwonjoon Lee
