Bringing Arduino and nRF51 together
i'm trying to get running nRF51 on Arduino IDE. I have forked RFduino at the moment github.com/.../RFduino
With SDK i can compile a startup library and an simple arduino sketch like this one in README.md
I get some linker warnings i cannot resolve:
/opt/arduino-1.5.7/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-g++ -Wl,--gc-sections --specs=nano.specs -mcpu=cortex-m0 -mthumb -D__nRF51__ -DNRF51 -D__NRF51SDK_STARTUP__ -DBOARD_PCA10000 -T/opt/arduino-1.5.7/hardware/arduino/RFduino/variants/nRF51/linker_scripts/gcc/gcc_nrf51_blank_xxaa.ld -Wl,-Map,/tmp/build2854674180972588472.tmp/rdfblink.cpp.map -Wl,--cref -o /tmp/build2854674180972588472.tmp/rdfblink.cpp.elf -L/tmp/build2854674180972588472.tmp -Wl,--warn-common -Wl,--warn-section-align -Wl,--start-group /tmp/build2854674180972588472.tmp/syscalls.c.o /tmp/build2854674180972588472.tmp/rdfblink.cpp.o /tmp/build2854674180972588472.tmp/variant.cpp.o /opt/arduino-1.5.7/hardware/arduino/RFduino/variants/nRF51/libnRF51System.a /tmp/build2854674180972588472.tmp/core.a -Wl,--end-group
/opt/arduino-1.5.7/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: warning: changing start of section .heap by 4 bytes
/opt/arduino-1.5.7/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: warning: changing start of section .stack_dummy by 4 bytes
When i flash the compiled code into an PCA10000 board it doesn't start. After my last try my previous blink code was started.
A compiled sketch must be flashed manually at the moment. I hope this code is correct.
 /opt/arduino-1.5.7/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/arm-none-eabi-objcopy -O binary /tmp/build2977480947880635154.tmp/Blink.cpp.elf /tmp/build2977480947880635154.tmp/Blink.cpp.bin
JLinkExe
        r
        loadbin /tmp/build2977480947880635154.tmp/Blink.cpp.bin 00000000
        r
        g
        exit
Resulting files can be found at: github.com/.../2014110901
