Possible race in NUS service - are there limitation on where to call ble_nus_data_send() from?
In my previous question, where I wanted to atomically send a large bulk of data, the solution was to keep track of p_bus->free_buffers, in order to calculate the amount of available space in the SD.
I've noticed that p_bus->free_buffers is modified from two routines in ble_nus.c:
  • on_hvx_tx_complete() - invoked from an SD interrupt service routine (high priority), and increments  p_bus->free_buffers:
    p_bus->free_buffers += p_ble_evt->evt.gatts_evt.params.hvn_tx_complete.count;
  • ble_nus_data_send() - which in my application is periodically called from main(), and decrements  p_bus->free_buffers:
    p_bus->free_buffers -= 1;
Questions:
  • Isn't this a race condition? The inc/dec operations themselves are not atomic, and the integer p_bus->free_buffers is modified from two different execution contexts.
  • If it is a race condition, what is the best way of mitigating it? Should I only call ble_nus_send_data() from an SD interrupt handler?
    It is difficult for me to tell if this is a race condition or not, but it seems likely. Do they interrupt each other when the code runs? You can use an SD interrupt handler, probably the easiest way.
    Simon
  • Do they interrupt each other when the code runs?
    Probably - the method called from main() runs in application scheduler context (i.e. main context), and is triggered by a timer.
    Can you please elaborate on the "use SD interrupt handler"? Do you mean posting the timer event to an SD IRQ?
    Alternatively, does nRF have an atomic increment/decrement operation, which does not include disabling all interrupts?
  • Hi
    Sorry for the obscure answer. If you want to protect writes to the variable the easiest way would probably be to use a critical region (disable interrupts before updating it and enable them afterwards), like calling the ble_nus_send_data() from an interrupt handler. You could have a look through \components\libraries\atomic\nrf_atomic.h as well to see if any of the operations does what you need, but I'd recommend disabling interrupts.
    Simon
