pstorage opration
Hi,everyone, In my project ,I want to save some data when disconnect evt happens; here is my code: the problem is ths program always stuck in power_manage() function; what shell i do to fix it?thanks.
 pstorage_handle_t               handle;
 pstorage_handle_t	        block_0_handle;
 pstorage_module_param_t   param;
 uint32_t                              retval;
static void on_disconnect(ble_pwm_t * p_pwm, ble_evt_t * p_ble_evt)
        UNUSED_PARAMETER(p_ble_evt);
        p_pwm->conn_handle = BLE_CONN_HANDLE_INVALID;
        retval = pstorage_init();
    if(retval != NRF_SUCCESS)
       nrf_gpio_pin_set(LED_0);
	param.block_size  = 16;
	param.block_count = 1;
	param.cb          = example_cb_handler;
	retval = pstorage_register(&param, &handle);
	if (retval != NRF_SUCCESS)
	pstorage_block_identifier_get(&handle, 0, &block_0_handle);
            pstorage_load(dest_data_0, &block_0_handle, 16, 0);
	pstorage_wait_handle = block_0_handle.block_id;
	pstorage_wait_flag = 1;
	pstorage_clear(&block_0_handle, 16);
            while(pstorage_wait_flag) { power_manage(); }
	pstorage_store(&block_0_handle, source_data_0, 16, 0);
            while(pstorage_wait_flag) {power_manage();}
  • Hi
    I assume you have copied the example code that is provided on this thread.
    If it never gets out of the while(pstorage_wait_flag) {power_manage();} loop, then the pstorage_wait_flag is never cleared. Have you included the event handler in the example that clears the pstorage_wait_flag when the pstorage callback is received? It is the example_cb_handler in the example.
  • Yes,I have includes the example_cb_handler in the code,I have fixed the problem, the point is that I should put the code in the main.c to init and register pstorage, and before the unlimited loop, in the disconnect event handler, we should only call pstorage_clear and pstorage_store function to realize our function,there is no delay function; the stack will handle our clearing and writing operation, internally.
  • here is anther question, everytime,the pstorage_init get the same block id, if we wrtie it more than 20,000 times , will this block become a bad one? if it will, can the program automatically get another good block id,and write it smoothly? thank you
  • I have been reading into this feature to use in my application. One potential problem is I see is that the pstorage_init() is called every time a disconnect event occurs. I think you can only call this function once. I haven't implemented anything yet so this is just from reading various related materials. I would confirm this with the Nordic folks. Dan
  • hello, i have a similar problem, could you show me your sample code?
