NFC BLE pairing connection issue
Hi all,
I'm testing the ble_nfc_pairing_reference example from SDK 15.2.0
I have installed microECC and then run succesfully the application using Segger Embedded Studio on Windows.
At the first pairing, my Samsung g6 Android Smartphone can connect with the nrf52832 board, but they disconnect almost immediately (about 1 or 2 seconds). The RTT log captured from Debug interface are:
"<info> app: NFC Connection Handover BLE peripheral device example started.
<info> BUTTONS_M: LESC OOB MODE!
<info> BLE_M: Fast advertising.
<info> BLE_M: Connected.
<info> nrf_ble_lesc: Calling sd_ble_gap_lesc_dhkey_reply on conn_handle: 0
<info> BLE_M: BLE_GAP_EVT_CONN_SEC_UPDATE
<info> BLE_M: Security mode: 2
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
<info> BLE_M: BLE_GAP_EVT_AUTH_STATUS
<info> BLE_M: Authorization succeeded!
<info> BLE_M: Disonnected"
And then, at the next pairing, they can not connect:
"<info> BLE_M: Connected.
<info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133
<info> BLE_M: Authorization failed with code: 133!
<info> BLE_M: Disonnected "
I have tried also with Nexus 7 and found the same problem. So, I have 2 questions:
1. At the first pairing, why they disconnect almost immediately after a successful pairing? How we can do to keep the connection
2. Why they can not reconnect after losing the connection ? Do you have any ideas what could cause these errors? I wonder if I have missed an important step in configuration and coding.
Can you help me?
Many thanks in advance.
    It sounds like you have forgotten to erase the bond information in your phone. If you delete the bonding information on the nRF side but not on the phone, the nRF will not allow the phone to bond again as it is a known bonded peer, but lacks the bonding information.
    Best Regards,
    Marjeris
  • Hi msromero,
    I have done "erase all" before each debugging, but I always have the same problem.
    If I try to print the reason when it gets the disconnect event, it shows ¨Disconnect reason: 19¨.
    This 19 (0x13) error code relates to BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION.
    It seems to have a problem during the encryption process. The android device can't understand and then cancel the newly established connection.
    I have tested also the Heart Rate Application with BLE Pairing Using NFC Pairing and the HID Keyboard Application with BLE pairing using NFC. I found the same problem. I clicked the "button 2" to erase bonds and delete all peers but nothing new.
    I don't know how to do now.
    Has anyone run correctly these example with a perfect connection between an android device and nrf52 board. Can you help me, thanks.
  • Hi Nguyen,
    Sorry for the late reply. Yes, I don't have any issues when testing with my phone. But as I said, from the log output you attached you can see the phone is trying to connect using another security mode than the one in the example. Can you attach the log output when you use legacy OOB and legacy just works mode so I can see what it looks like?
    Best Regards,
    Marjeris
  • Hi Marjeris,
    I copy below the log output for 3 modes:
    <info> BLE_M: Disconnected
    <info> BLE_M: Disconnect reason: 19
    <info> BUTTONS_M: LEGACY OOB MODE!
    <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 132
    <info> BLE_M: Authorization failed with code: 132!
    <info> BUTTONS_M: LEGACY JUST WORKS MODE!
    Hope that you can find something.
    I can not connect directly with the phone, so I must use Adafruit Tag Reader + BLE central device as an intermediate device and the phone will send the command and data to the peripheral through this central device. But it is much more complicated.
  • Hi, any way you can provide a ble sniffer log that shows what is happening on air when using legacy OOB and legacy just works? Both the initial bond and the failing reconnect.
  • Hi Marjeris,
    I do exactly face the problem you indicate that it definitely fails to connect the same device for the second time. Will it be fixed in the future or Are there any workaround solutions for this issue ? Thanks in advice.
    This is most likely an issue with the phone implementation, Please try to capture sniffer logs and create a new thread if you are seeing similar behavior.
