Hi all,
Where can I find the default program that comes with nRF9160 DK in box?
I'd erased memory and programmed with AT command program but I would want to program as brand new board.
Thanks!
Hi all,
Thanks!
Hi Emi,
It is Asset_tracker application that is running as default when you get your nrf91 DK. (source code)
Make sure you have the latest nrfjprog and use the command: nrfjprog --program asset_tracker.hex --sectorerase -f nrf91 -r -verify
to flash this precompiled .hex file: asset_tracker.hex
That is the exact application that came with the board.
However, I would recommend you to use this precompiled .hex file: asset_tracker_updated.hex, which is the same application, but "new and improved". (it is from a newer build from the master branch)
I would also recommend you to go through the Getting started guide to see how you can get the source code/debug/flash applications to the nrf91.
//cheers
Thanks!
