Invalid HID report
Hello all!
We have custom HID with multitouch BLE device. We took HID descriptor from USB where this works pretty good, ported it to BLE and it seems not working as expected.
Can someone please point us what we doing wrong?
/**@brief Function for initializing HID Service.
static void hids_init(void)
    ret_code_t                err_code;
    ble_hids_init_t           hids_init_obj;
    static ble_hids_inp_rep_init_t inp_rep_array;
    static uint8_t rep_map_data[] =
          0x05, 0x0d,                         // USAGE_PAGE (Digitizers)
          0x09, 0x04,                         // USAGE (Touch Screen)
          0xa1, 0x01,                         // COLLECTION (Application)
          0x85, 0x01,                         //   REPORT_ID (Touch)
          0x09, 0x22,                         //   USAGE (Finger)
          0xa1, 0x02,                         //     COLLECTION (Logical)
          0x09, 0x42,                         //         USAGE (Tip Switch)
          0x09, 0x32,                         //         USAGE (In Range)
          0x15, 0x00,                         //         LOGICAL_MINIMUM (0)
          0x25, 0x01,                         //         LOGICAL_MAXIMUM (1)
          0x75, 0x01,                         //         REPORT_SIZE (1)
          0x95, 0x02,                         //         REPORT_COUNT (2)
          0x81, 0x02,                         //         INPUT (Data,Var,Abs)
          0x95, 0x06,                         //         REPORT_COUNT (6)
          0x81, 0x03,                         //         INPUT (Cnst,Ary,Abs)
          0x75, 0x10,                         //         REPORT_SIZE (16)
          0x09, 0x51,                         //         USAGE (Contact Identifier)
          0x95, 0x01,                         //         REPORT_COUNT (1)
          0x05, 0x01,                         //         USAGE_PAGE (Generic Desktop)
          0x26, 0xff, 0x0f,                   //         LOGICAL_MAXIMUM (4095)
          0x55, 0x00,                         //         UNIT_EXPONENT (0)
          0x65, 0x00,                         //         UNIT (None)
          0x09, 0x30,                         //         USAGE (X)
          0x35, 0x00,                         //         PHYSICAL_MINIMUM (0)
          0x46, 0x00, 0x05,                   //         PHYSICAL_MAXIMUM (1280)
          0x09, 0x31,                         //         USAGE (Y)
          0x46, 0xd0, 0x02,                   //         PHYSICAL_MAXIMUM (720)
          0xc0,                               //     END_COLLECTION
          0x09, 0x54,                         //    USAGE (Contact Count)
          0x75, 0x08,                         //    REPORT_SIZE (8)
          0x25, 0x0a,                         //    LOGICAL_MAXIMUM (10)
          0x09, 0x55,                         //    USAGE(Contact Count Maximum)
          0xb1, 0x02,                         //    FEATURE (Data,Var,Abs)
    memset(&inp_rep_array, 0, sizeof(inp_rep_array));
    // Initialize HID Service.
      ble_hids_inp_rep_init_t * p_input_report;
      p_input_report = &inp_rep_array;
      p_input_report->max_len = INPUT_REP_TOUCH_LEN;
      p_input_report->rep_ref.report_id = INPUT_REP_REF_TOUCH_ID;
      p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
      p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
      p_input_report->sec.wr = SEC_JUST_WORKS;
      p_input_report->sec.rd = SEC_JUST_WORKS;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler                    = on_hids_evt;
    hids_init_obj.error_handler                  = service_error_handler;
    hids_init_obj.is_kb                          = false;
    hids_init_obj.is_mouse                       = false;
    hids_init_obj.inp_rep_count                  = 1;
    hids_init_obj.p_inp_rep_array                = &inp_rep_array;
    hids_init_obj.outp_rep_count                 = 0;
    hids_init_obj.p_outp_rep_array               = NULL;
    hids_init_obj.feature_rep_count              = 0;
    hids_init_obj.p_feature_rep_array            = NULL;
    hids_init_obj.rep_map.data_len               = sizeof(rep_map_data);
    hids_init_obj.rep_map.p_data                 = rep_map_data;
    hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = (HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK);
    hids_init_obj.included_services_count        = 0;
    hids_init_obj.p_included_services_array      = NULL;
    hids_init_obj.rep_map.rd_sec         = SEC_JUST_WORKS;
    hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
    hids_init_obj.ctrl_point_wr_sec    = SEC_JUST_WORKS;
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
// Digitizer Device Page inputReport 01 (Device --> Host)
typedef struct __packed
    uint8_t DIG_TouchScreenFingerTipSwitch :1;        // Usage 0x000D0042: Tip Switch, Value = 0 to 1
    uint8_t DIG_TouchScreenFingerInRange :1;          // Usage 0x000D0032: In Range, Value = 0 to 1
    uint8_t :6;                                       // Pad
    uint16_t DIG_TouchScreenFingerContactIdentifier;  // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
    uint16_t GD_TouchScreenFingerX;                   // Usage 0x00010030: X, Value = 0 to 4095, Physical = Value x 256 / 819
    uint16_t GD_TouchScreenFingerY;                   // Usage 0x00010031: Y, Value = 0 to 4095, Physical = Value x 16 / 91
                                                      // Collection: CA:TouchScreen CL:
    uint8_t DIG_TouchScreenTipSwitch :1;              // Usage 0x000D0042: Tip Switch, Value = 0 to 1, Physical = Value x 720
    uint8_t DIG_TouchScreenInRange :1;                // Usage 0x000D0032: In Range, Value = 0 to 1, Physical = Value x 720
    uint8_t :6;                                       // Pad
    uint16_t DIG_TouchScreenContactIdentifier;        // Usage 0x000D0051: Contact Identifier, Value = 0 to 1, Physical = Value x 720
    uint16_t GD_TouchScreenX;                         // Usage 0x00010030: X, Value = 0 to 4095, Physical = Value x 256 / 819
    uint16_t GD_TouchScreenY;                         // Usage 0x00010031: Y, Value = 0 to 4095, Physical = Value x 16 / 91
    uint8_t DIG_TouchScreenContactCount;              // Usage 0x000D0054: Contact Count, Value = 0 to 10, Physical = Value x 72
  } CT_HID_Input_t;
   // Somewhere in code.
   // Create HID report.
   CT_HID_Input_t report = { 0 };
   // Populate...
   /* Send report. */
   ret_code_t err_code = ble_hids_inp_rep_send(&m_hids, INPUT_REP_TOUCH_INDEX, sizeof(report), (uint8_t *) &report, m_conn_handle);
