DFU example problem : [DFU] Error (0x85): GATT ERROR
First of all, here is my setup :
- SoC : nRF52832
- Board : BLE nano v2
- SDK : 12.3.0 version
- SD_Version : s132_nRF52_3.0.0
- Compiler : GCC
- Smartphone : GT-I9195
My problem is the following one :
I'm stuck since two weeks on a problem with the secure bootloader example I found in the SDK. I think i have all done correctly but i still can't send package to my "DfuTarg" device. When I try to send a zip file, I see "Initializing...", then "Strating DFU...", but the progress bar stay at 0% and finally I see "Disconnecting...". I don't find any solution at the step to my problem. For information, I followed this tutorial step by step : https://devzone.nordicsemi.com/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader
Here is below the commands i use before using my smarthpone and the logs I see on my smartphone when I'm proceeding the update of the firmware.
Commands :
nrfutil keys generate private_key.key
nrfutil keys display --key pk --format code private_key.key --out_file public_key.c
nrfjprog --program $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_3.0.0_softdevice.hex -f nrf52 --sectorerase
nrfjprog --program $(BOOT_DIRECTORY)/nrf52832_xxaa.hex -f nrf52 --sectorerase
nrfutil pkg generate --hw-version 52 --application-version 1 --application $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex --sd-req 0x8C --key-file $(KEY_DIRECTORY)/private_key.key app_v1_dfu_package.zip
Logs :
nRF Connect, 2019-02-21
DfuTarg (CA:33:98:66:97:AB)
I	11:57:20.589	[Server] Server started
V	11:57:20.622	Secure DFU Service (0xFE59)
V	11:57:21.037	Connecting to CA:33:98:66:97:AB...
D	11:57:21.037	gatt = device.connectGatt(autoConnect = false)
D	11:57:21.105	[Server callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	11:57:21.106	[Server] Device with address CA:33:98:66:97:AB connected
D	11:57:21.115	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	11:57:21.115	Connected to CA:33:98:66:97:AB
V	11:57:21.134	Discovering services...
D	11:57:21.134	gatt.discoverServices()
D	11:57:22.464	[Callback] Services discovered with status: 0
I	11:57:22.464	Services discovered
V	11:57:22.492	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
- Central Address Resolution [R] (0x2AA6)
Generic Attribute (0x1801)
- DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50)
- DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)
 Client Characteristic Configuration (0x2902)
V	11:57:36.869	[DFU] DFU service started
V	11:57:36.870	[DFU] Opening file...
I	11:57:37.492	[DFU] Firmware file opened successfully
V	11:57:37.492	[DFU] Connecting to DFU target...
D	11:57:37.492	[DFU] gatt = device.connectGatt(autoConnect = false)
I	11:57:37.542	[DFU] Connected to CA:33:98:66:97:AB
V	11:57:37.542	[DFU] Discovering services...
D	11:57:37.543	[DFU] gatt.discoverServices()
I	11:57:37.558	[DFU] Services discovered
D	11:57:37.579	[DFU] wait(1000)
V	11:57:38.573	[DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
D	11:57:38.573	[DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
D	11:57:38.573	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	11:57:38.650	[DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
V	11:57:38.650	[DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
A	11:57:38.650	[DFU] Notifications enabled
D	11:57:38.650	[DFU] wait(1000)
V	11:57:39.654	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	11:57:39.654	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
D	11:58:09.714	[Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I	11:58:09.714	[Server] Device disconnected
D	11:58:09.780	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I	11:58:09.780	Disconnected
D	11:58:09.782	gatt.refresh() (hidden)
E	11:58:09.783	[DFU] Error (0x85): GATT ERROR
V	11:58:09.783	[DFU] Disconnecting...
D	11:58:09.784	[DFU] gatt.disconnect()
I	11:58:09.856	[DFU] Disconnected
D	11:58:09.856	[DFU] gatt.refresh() (hidden)
D	11:58:09.856	[DFU] gatt.close()
D	11:58:09.856	[DFU] wait(600)
D	11:58:10.420	gatt.close()
D	11:58:10.421	wait(200)
V	11:58:10.624	Connecting to CA:33:98:66:97:AB...
D	11:58:10.624	gatt = device.connectGatt(autoConnect = false)
D	11:58:15.632	[Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I	11:58:15.632	[Server] Device disconnected
D	11:58:15.711	[Callback] Connection state changed with status: 133 and new state: CONNECTED (2)
E	11:58:15.711	Error 133 (0x85): GATT ERROR
V	11:58:17.000	Cancelling connection...
D	11:58:17.000	gatt.disconnect()
I	11:58:17.002	Disconnected
D	11:58:17.002	gatt.close()
D	11:58:17.033	wait(200)
I'm open to any help because I got no more ideas. Futhermore, the bootloader works correctly without DFU. I mean I can go in bootloader or application when I want when I simulate the pression on a button by connecting pin0_4. The problem is just when I try to send a zip to update the firmware.
I hope my description will be sufficient. If not, tell me what you need to know and I will answer as fast as possible.
PS : If I flash both bootloader_settings and a version 1 of the application in addition to softdevice and bootloader, the updating isn't working and I see same logs on my smartphone, even if I link the good version of the app to the bootloader_settings.
