I can not identify the location,
Functions that are not memory leak, buffer overflow, thread safe
If you understand, it will be appreciated if you can tell me.
Hi.
I do not understand your question unfortunately.
Can you please explain more :-)
What example are you looking at?
Do you have any code you can show?
Andreas
Andreas
Thank you for your reply.
There is no code that can be displayed.
As shown below, there is information "Thread-safe C library function" "C library function not thread-safe"
I would like to ask if there are other C library functions as well.
C library function not thread safe
infocenter.arm.com/.../index.jsp
Thread-safe C library functions
In addition, if you want to tell me if there is a C library function that can lead to memory leaks or buffer overflow
It means that.
Hi :-)
I can explain memory leak, buffer overflow, and thread safe for Nordic solutions (Nordic SDK) codesnippets if you post them here :-)
hitsato said:In addition, if you want to tell me if there is a C library function that can lead to memory leaks or buffer overflow
All type of C code can be used wrong and cause memory leaks or buffer overflow.
Please post your code snippet :-)
Andreas
If it posts here, it is a program of several thousand steps, since it is mostly not developed by me, it can not be excerpted and posted.
I will post as soon as a suspicious place is found.
