sd_ble_gatts_value_get and sd_ble_gatts_value_set when not in connection requires different handles
when I am not in a connection, I want to call sd_ble_gatts_value_get() and sd_ble_gatts_value_set(). Both require a connection handle.
For the  sd_ble_gatts_value_get() I must use "0" as connection handle - else it crashes
For the sd_ble_gatts_value_set() I must use "BLE_CONN_HANDLE_INVALID" (0xFFFF) - else it crashes
Why does this functions need different handles when I am not in a connection? This is very ugly, if I can not use a common connection handle for my whole program.
Is this a bug? Is there any solution to this, except the workaround of using different connection handles for the functions (have to check before every call, if the system is in a valid connection by checking a custom variable - thats bad)
Thank you,
Regards
I use SDK 15.2.
  • With sd_ble_gatts_value_get() I want to check if notifications are enabled like this:
    sd_ble_gatts_value_get(connection_handle,
                                        *p_cccd_handle,
                                        &cccd_data);
    ret_value = ble_srv_is_notification_enabled(cccd_data.p_value);
  • Crashes means "Invalid connection handle error" - system stops because I am using APP_ERROR_CHECK()
  • Hi Andre,
    My understanding is that you want to read if the CCCD is enabled or not.
    But the problem is that CCCD value is connection dependent. In a connection with a central it may be set and in another connection it may be not.It's a system attribute. You would need to be in a connection to read the system attribute.
    The application has the responsibility to keep track of the system attribute and restore it when the same central is connected, using sd_ble_gatts_sys_attr_set().
    When not in a connection, there is no point reading out the system attribute. You still can use 0 as connect handle but it is not guarantee the value is the correct one.
    For sd_ble_gatts_value_set() it's correct that you need to use BLE_CONN_HANDLE_INVALID.
