twi sensor i am not getting the data even in debug terminal
hi.
i have merged the twi and uart , but i am not getting the data over ble even in debug terminal , here is my code
void MAX30205_set_mode(void)
    ret_code_t err_code;
    /* Writing to pointer byte. */
     uint8_t reg[2] = {0x00U};
    m_xfer_done = false;
    err_code = nrf_drv_twi_tx(&m_twi, MAX_ADDR, reg, 1, false);
    while (m_xfer_done == false);
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
    NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_lm75b_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
      ret_code_t err_code = nrf_drv_twi_tx(&m_twi, MAX_ADDR, reg, sizeof(reg), false);
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    err_code = nrf_drv_twi_rx(&m_twi,MAX_ADDR, &m_sample, sizeof(m_sample));
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    nrf_pwr_mgmt_run();
static threshold_value(void)
 uint32_t threshold = 90;
 char str[80];
uint32_t length1;
   if(m_sample < threshold)
           length1 = sprintf(str,"%d", m_sample);
              ble_nus_data_send(&m_nus,str,sizeof(m_sample), m_conn_handle);
              ret_code_t err_code = nrf_drv_twi_rx(&m_twi, 0x00U, &m_sample, sizeof(m_sample));
               NRF_LOG_INFO("SUCCESS1");
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
      twi_init();
  MAX30205_set_mode();
     while (true)
    read_sensor_data();
        threshold_value();
        NRF_LOG_FLUSH();
    // Enter main loop.
    for (;;)
        idle_state_handle();
