SDK 15.2: Reading Analog Sensor Data using ADC gives value out of range
I need some help calibrating my moisture sensor analog readings using 3.3V regulated power source (VDD = 3.3). Here is my set up, borrowed from the proximity example.
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS 600
#define ADC_PRE_SCALING_COMPENSATION 6
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS 270
#define ADC_RES_10BIT 1024
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)  ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
the ADC_RESULT_IN_MILLI_VOLTS is in the 3500 mV range which is not accurate. While 3.3 / 1024 * adc_result (900) = 2.9V which is right on the money.
How can I calibrate my SAADC using the proximity example?
Thanks
