app_timer hangs after be changed intervals through GPIOTE
Now i use NRF51822 DK with code in attachment to test app_timer hangs.
Fristly , you can press button 0 to start a 100ms app_timer, and we can see it through uart(NRF_LOG);
After 5 secons, app_timer will becom 5s and continue it until next GPIOTE comes.
Secondly. Now ,we give a press on button 0 , we can  see the programming hangs. Because in normal mode, the chip will stop app_timer in running  and restart it in 100ms interval.
Lastly, we can restart 100ms app_timer quickly as next button GPIOTE comes if we donn't start 5s app_times as inuse_100ms_cal equal 50;
I describe this trouble in this blog as:
https://devzone.nordicsemi.com/f/nordic-q-a/44048/app_timer-hangs-after-i-changed-intervals-through-gpiote
Thanks.
Liu
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_beacon_main main.c
     * @ingroup ble_sdk_app_beacon
     * @brief Beacon Transmitter Sample Application main file.
     * This file contains the source code for an Beacon transmitter sample application.
    #include <stdbool.h>
    #include <stdint.h>
    #include "ble_advdata.h"
    #include "nordic_common.h"
    #include "softdevice_handler.h"
    #include "bsp.h"
    #include "app_timer.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_gpiote.h"
    #include "math.h"
    #define CENTRAL_LINK_COUNT              0                                 /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           0                                 /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                 /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
    #define APP_CFG_NON_CONN_ADV_TIMEOUT    0                                 /**< Time for which the device must be advertising in non-connectable mode (in seconds). 0 disables timeout. */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH          0x17                              /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH             0x15                              /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE                 0x02                              /**< 0x02 refers to Beacon. */
    #define APP_MEASURED_RSSI               0xC3                              /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    #define APP_COMPANY_IDENTIFIER          0x0059                            /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE                 0x01, 0x02                        /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE                 0x03, 0x04                        /**< Minor value used to identify Beacons. */
    #define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                            0x45, 0x56, 0x67, 0x78, \
                                            0x89, 0x9a, 0xab, 0xbc, \
                                            0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
    #define DEAD_BEEF                       0xDEADBEEF                        /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define APP_TIMER_PRESCALER             0                                 /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                 /**< Size of timer operation queues. */
    		APP_TIMER_DEF(m_inuse_100ms_timer_id);
        #define INUSE_100ms_TEMP_INTERVAL              	APP_TIMER_TICKS(100, APP_TIMER_PRESCALER)
        uint16_t inuse_100ms_cal =0;
    		uint8_t  app_timer_5s_flag =0;
    		#define INUSE_5s_TEMP_INTERVAL              	  APP_TIMER_TICKS(6000, APP_TIMER_PRESCALER)
    		uint8_t  app_timer_5s_first_flag =0;
    #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    #define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                /**< Position of the MSB of the Major Value in m_beacon_info array. */
    #define UICR_ADDRESS                    0x10001080                        /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
    static ble_gap_adv_params_t m_adv_params;                                 /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
        APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
        APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
        APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
        // UICR instead of using the default values. The major and minor values obtained from the UICR
        // are encoded into advertising data in big endian order (MSB First).
        // To set the UICR used by this example to a desired value, write to the address 0x10001080
        // using the nrfjprog tool. The command to be used is as follows.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
        // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
        // the following command should be used.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
        uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
        uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
        uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
        m_beacon_info[index++] = MSB_16(major_value);
        m_beacon_info[index++] = LSB_16(major_value);
        m_beacon_info[index++] = MSB_16(minor_value);
        m_beacon_info[index++] = LSB_16(minor_value);
        manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        err_code = ble_advdata_set(&advdata, NULL);
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
        m_adv_params.p_peer_addr = NULL;                             // Undirected advertisement.
        m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval    = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.timeout     = APP_CFG_NON_CONN_ADV_TIMEOUT;
        uint32_t err_code;
        err_code = sd_ble_gap_adv_start(&m_adv_params);
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
    /**@brief Function for doing power management.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    void active_acc_in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    	NRF_LOG_INFO("GPIOTE\r\n");
    //	 app_timer_5s_flag =0;
    	inuse_100ms_cal =0;
     if(app_timer_5s_flag ==1)
     app_timer_stop(m_inuse_100ms_timer_id);
     app_timer_start(m_inuse_100ms_timer_id, INUSE_100ms_TEMP_INTERVAL, NULL);
     * @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
     * and configures GPIOTE to give an interrupt on pin change.
    			static void active_gpio_change_init(void)
    			ret_code_t err_code;
    			//    APP_ERROR_CHECK(err_code);
    			//    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    			//    err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
    			nrf_drv_gpiote_in_config_t in_config1 = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);  //true????
    			in_config1.pull = GPIO_PIN_CNF_PULL_Pullup;
    			err_code = nrf_drv_gpiote_in_init(BSP_BUTTON_0, &in_config1, active_acc_in_pin_handler);
    			nrf_drv_gpiote_in_event_enable(BSP_BUTTON_0, true);
    			static void INUSE_100ms_timeout_handler(void)
    			inuse_100ms_cal++;
    			if (app_timer_5s_flag ==1)
    			NRF_LOG_INFO("5S\r\n");
    			if  (app_timer_5s_flag ==0)
    			NRF_LOG_INFO("100ms\r\n");
    			if((inuse_100ms_cal == 50) &&(app_timer_5s_flag ==0))
    			app_timer_start(m_inuse_100ms_timer_id, INUSE_5s_TEMP_INTERVAL, NULL);
    			app_timer_5s_flag =1;
     * @brief Function for application main entry.
        uint32_t err_code;
        // Initialize.
        err_code = NRF_LOG_INIT(NULL);
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    //    err_code = bsp_init(BSP_INIT_LED, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
        ble_stack_init();
        advertising_init();
        // Start execution.
        NRF_LOG_INFO("BLE Beacon started\r\n");
        advertising_start();
    	   active_gpio_change_init();
    		  err_code = app_timer_create(&m_inuse_100ms_timer_id,
                                      APP_TIMER_MODE_REPEATED,
                                       INUSE_100ms_timeout_handler);
        // Enter main loop.
        for (;; )
                power_manage();
  • i use sdk12.3 in NRF51822(S130).
    The code is my main.c.
