TWI driver strange behavior
Hi, I wrote a simple program to communicate with ICM20948 IMU .
The IMU correctly acknowledges its address.
But, when I try to read its WHO_AM_I  ID, the program halts inside the read_byte function I wrote,
at the transfer complete check ( while(m_xfer_done == false) )  under the nrf_drv_twi_tx( ... ) function.
So the code cannot continue and read the ID of the slave...( I have also verified that with logic analyzer) .
uint8_t ICM_RD_byte(uint8_t  ICMregister)
  uint8_t receivedByte;
  uint8_t pinax[] = {ICMregister};
  //m_xfer_done = false;
  err_code = nrf_drv_twi_tx(&m_twi, ICM20948_ADDRESS, pinax, sizeof(pinax), true);
    //nrf_delay_ms(1000);
  while(m_xfer_done == false);                                                   // wait for Tx + no_stop event to occur
  m_xfer_done = false;                                                            // reset the done flag for next event
  err_code = nrf_drv_twi_rx(&m_twi, ICM20948_ADDRESS, &receivedByte, 1);          // Fetch temperature data from MAX30102_DIE Register and save it to pinax[2]
  while (m_xfer_done == false);
  return receivedByte;
m_xfer_done is a boolean variable that  I have defined in my global_variables header file
#ifndef GLOBAL_VARIABLES_H
#define GLOBAL_VARIABLES_H
#ifdef __cplusplus
extern "C" {
#include "nrf_drv_twi.h"
#include "app_error.h"
#include "ICM20948.h"
#define TWI_INSTANCE_ID     0
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
static volatile bool m_xfer_done = false;
static volatile ret_code_t err_code;
static volatile bool flag = false;
#ifdef __cplusplus
#endif // GLOBAL_VARIABLES_H
I use this variable as a flag  that is updated in the TWI event handler function  in main.c file
so that I know when an event occurred. The process is almost the same with the TWI_sensor example.
void twi_event_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                NRF_LOG_INFO("NRF_DRV_TWI_XFER_RX event occured");
            else if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX)
               NRF_LOG_INFO("NRF_DRV_TWI_XFER_TX event occured");
            else if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TXRX)
                NRF_LOG_INFO("NRF_DRV_TWI_XFER_TXRX event occured");
               //data_handler(m_sample);
            m_xfer_done = true;
Strangely, even when m_xfer_done variable becomes true in the handler function after the TX event (verified that it becomes true with debugger in segger) the program halts
at while(m_xfer_done == false)  . How is this possible? I can see the m_xfer_done to become true and the while check cannot see it...
To verify that the communication works ok  I placed a delay of 1sec after the nrf_drv_twi_tx( ... ) function and removed the  while(m_xfer_done == false)
I did the same thing to the nrf_drv_twi_rx( ...) function.
and the program responds as expected and I receive the ID of the slave device correctly.
So, it must be something with this while() check
What am I doing wrong here?
Thank you for your time
