Low Voltage (1.8V) on nRF52840 cannot program chip
I have the USB Dongle (PCA10059) which after a full erase, has been giving only 1.8Volts to the GPIOs and the VDD OUT pin.
I am using the Segger j-link EDU progammer/debugger and I have connected it as:
VTref - VDD OUT
GND-GND
SWDIO-SWDIO
SWCLK-SWCLK
also I have connected the Dongle to the computer's USB port at the same time
I have searched the forum and the internet, the 2 possible solutions are:
Solution 1:
The command
(gdb) set *0x10001304 = 5
from here which doesn't see to work, I get the error:
Cannot access memory at address 0x10001304
Solution 2:
The command:
nrfjprog --memwr 0x10001304 --val 0xFFFFFFFD
which results:
while dmesg command records the following:
[ 1972.462260] nrfjprog[3893]: segfault at fffffffffffffff9 ip 00007fede43f604f sp 00007ffd9c3bc450 error 5 in libjlinkarm_unknown_nrfjprogdll.so.9.8.1[7fede43ed000+15000]
The 2nd solution in a windows 10 machine  doesn't return any errors but never changes the Voltage to the desired 3-3.3V
