We are preparing the first "production" run and we are looking on alternatives for production programming and testing, so far our factory used nRFgo for the pre-series and prototyping, I found
and
https://www.nordicsemi.com/DocLib/Content/User_Guides/getting_started/latest/UG/gs/prod_test_prog
but the nRFgo is not mentioned there... I guess that nRFgo is more intended for low volume since its fairly slow compared to the SEGGER programmers for example...?
We will be using In System programming btw.
Also on the integration module of our module (NINA B112 with nRF52932)
https://www.u-blox.com/sites/default/files/NINA-B1_SIM_%28UBX-15026175%29.pdf
on section 2.3 about flashing it does mention nRFgo on the SWD section 2.3.2, however they say something weird regarding the Bluetooth device address will be erased and needs to be rewrite through AT commands?
in general, is it a very bad idea to use nRFgo for production? the volumes we are expecting are not very high comparing to consumer electronics, roughly 1000pcs / month for the next few months.
