nRF5 SDK for Mesh v3.1.0
SEGGER Embedded Studio
Softdevice S140 v6.1.0, Softdevice S132 v6.1.0
Two nRF52832 DK, One nRF52840 DK
Windows 10 Pro
Hi, is it possible to write to Mesh Data Proxy In (Characteristic 0x2ADD) and have that data sent through the mesh, eventually ending up in a GenericOnOff Set Message that actually turns the LED on a Light Switch Server on?
Currently, I'm using the Interactive PyACI script with an nRF52840 board to provision two nRF52832 boards, one as a Light Switch Client, the other as a Light Switch Server.
- Provisioning succeeds, and app keys are added and bound to the models.
- After that, I am able to successfully set publication and subscription addresses, and verify the two 832 boards can talk to each other. Pressing button 1 on the client sets the LED on the server and pressing button 2 on the client turns the LED off.
After this point, I connect to the Light Switch Client from a Node.js Proxy Client supplied by Bluetooth in the Bluetooth Mesh Proxy Kit. The Proxy Client is able to connect to both the Server and Client nodes, and I'm able to write a proxy PDU to both, however when I write a GenericOnOff Proxy PDU to the client, the logs show RX received messages, and nothing actually happens to the server. Also, I've tried writing the GenericOnOff Proxy PDU to the server directly, which produces the same results, an RX message received, but nothing happens.
Simply put, do your proxy servers (light switch client and light switch server) support writing to the Mesh Proxy Data In characteristic? I.e. does writing to the characteristic actually translate to mesh messages that should affect the state of the LED?
Logs attached:
Interactive PyACI logs:
To control your device, use d[x], where x is the device index. Devices are indexed based on the order of the COM ports specified by the -d option. The first device, d[0], can also be accessed using device. Type d[x]. and hit tab to see the available methods. Python 3.7.2 (tags/v3.7.2:9a3ffc0492, Dec 23 2018, 23:09:28) [MSC v.1916 64 bit (AMD64)] Type 'copyright', 'credits' or 'license' for more information IPython 7.2.0 -- An enhanced Interactive Python. Type '?' for help. In [1]: db = MeshDB("database/example_database.json") In [2]: p = Provisioner(device, db) In [3]: 2019-02-27 19:40:00,844 - INFO - COM22: Success 2019-02-27 19:40:00,847 - INFO - COM22: Success 2019-02-27 19:40:00,852 - INFO - COM22: SubnetAdd: {'subnet_handle': 0} 2019-02-27 19:40:00,857 - INFO - COM22: AppkeyAdd: {'appkey_handle': 0} 2019-02-27 19:40:00,863 - INFO - COM22: AppkeyAdd: {'appkey_handle': 1} In [3]: p.scan_start() In [4]: 2019-02-27 19:40:06,438 - INFO - COM22: Success 2019-02-27 19:40:08,367 - INFO - COM22: Received UUID 3f2e408b740b17468059fdb1f7e63985 with RSSI: -41 dB 2019-02-27 19:40:08,398 - INFO - COM22: Received UUID 2b7a78cb8012ba4486acb023630c3875 with RSSI: -27 dB In [4]: p.scan_stop() In [5]: 2019-02-27 19:40:11,698 - INFO - COM22: Success In [5]: p.provision(uuid="2b7a78cb8012ba4486acb023630c3875", name="Light bulb" ...: ) In [6]: 2019-02-27 19:40:49,249 - INFO - COM22: Provision: {'context': 0} 2019-02-27 19:40:49,259 - INFO - COM22: Link established 2019-02-27 19:40:49,308 - INFO - COM22: Received capabilities 2019-02-27 19:40:49,308 - INFO - COM22: Number of elements: 1 2019-02-27 19:40:49,312 - INFO - COM22: OobUse: {'context': 0} 2019-02-27 19:40:49,509 - INFO - COM22: ECDH request received 2019-02-27 19:40:49,516 - INFO - COM22: EcdhSecret: {'context': 0} 2019-02-27 19:40:51,734 - INFO - COM22: Provisioning complete 2019-02-27 19:40:51,734 - INFO - COM22: Address(es): 0x10-0x10 2019-02-27 19:40:51,734 - INFO - COM22: Device key: 79f98625056f50a27c685316c5f5d604 2019-02-27 19:40:51,735 - INFO - COM22: Network key: 18eed9c2a56add85049ffc3c59ad0e12 2019-02-27 19:40:51,735 - INFO - COM22: Adding device key to subnet 0 2019-02-27 19:40:51,735 - INFO - COM22: Adding publication address of root element 2019-02-27 19:40:51,741 - INFO - COM22: DevkeyAdd: {'devkey_handle': 8} 2019-02-27 19:40:51,742 - INFO - COM22: AddrPublicationAdd: {'address_handle': 0} 2019-02-27 19:40:51,834 - INFO - COM22: Provisioning link closed In [6]: p.provision(uuid="3f2e408b740b17468059fdb1f7e63985", name="Light switc ...: h") In [7]: 2019-02-27 19:41:30,955 - INFO - COM22: Provision: {'context': 0} 2019-02-27 19:41:31,020 - INFO - COM22: Link established 2019-02-27 19:41:31,076 - INFO - COM22: Received capabilities 2019-02-27 19:41:31,077 - INFO - COM22: Number of elements: 3 2019-02-27 19:41:31,080 - INFO - COM22: OobUse: {'context': 0} 2019-02-27 19:41:31,286 - INFO - COM22: ECDH request received 2019-02-27 19:41:31,292 - INFO - COM22: EcdhSecret: {'context': 0} 2019-02-27 19:41:33,652 - INFO - COM22: Provisioning complete 2019-02-27 19:41:33,652 - INFO - COM22: Address(es): 0x11-0x13 2019-02-27 19:41:33,652 - INFO - COM22: Device key: 11f84c5c3bfa51078781df2925878df9 2019-02-27 19:41:33,652 - INFO - COM22: Network key: 18eed9c2a56add85049ffc3c59ad0e12 2019-02-27 19:41:33,653 - INFO - COM22: Adding device key to subnet 0 2019-02-27 19:41:33,653 - INFO - COM22: Adding publication address of root element 2019-02-27 19:41:33,658 - INFO - COM22: DevkeyAdd: {'devkey_handle': 9} 2019-02-27 19:41:33,658 - INFO - COM22: AddrPublicationAdd: {'address_handle': 1} 2019-02-27 19:41:33,759 - INFO - COM22: Provisioning link closed In [7]: cc = ConfigurationClient(db) In [8]: device.model_add(cc) In [9]: cc.publish_set(8, 0) In [10]: cc.composition_data_get() In [11]: 2019-02-27 19:42:07,272 - INFO - COM22: PacketSend: {'token': 1} 2019-02-27 19:42:07,280 - INFO - COM22: {event: MeshTxComplete, data: {'token': 1}} In [11]: cc.composition_data_get() In [12]: 2019-02-27 19:42:13,532 - INFO - COM22: PacketSend: {'token': 2} 2019-02-27 19:42:13,539 - INFO - COM22: {event: MeshTxComplete, data: {'token': 2}} 2019-02-27 19:42:13,611 - INFO - COM22.ConfigurationClient: Received composition data (page 0x00): { "cid": "0059", "pid": "0000", "vid": "0000", "crpl": 40, "features": { "relay": 0, "proxy": 0, "friend": 2, "low_power": 2 }, "elements": [ { "index": 0, "location": "0000", "models": [ { "modelId": "0000" }, { "modelId": "0002" }, { "modelId": "1000" } ] } ] } In [12]: cc.appkey_add(0) In [13]: 2019-02-27 19:42:35,112 - INFO - COM22: PacketSend: {'token': 3} 2019-02-27 19:42:35,154 - INFO - COM22: {event: MeshTxComplete, data: {'token': 3}} 2019-02-27 19:42:35,183 - INFO - COM22.ConfigurationClient: Appkey status: AccessStatus.SUCCESS 2019-02-27 19:42:35,187 - INFO - COM22.ConfigurationClient: Appkey add 0 succeded for subnet 0 at node 0010 In [13]: cc.model_app_bind(db.nodes[0].unicast_address, 0, mt.ModelId(0x1000)) ...: In [14]: 2019-02-27 19:42:48,298 - INFO - COM22: PacketSend: {'token': 4} 2019-02-27 19:42:48,308 - INFO - COM22: {event: MeshTxComplete, data: {'token': 4}} 2019-02-27 19:42:48,327 - INFO - COM22.ConfigurationClient: Model app bind status: AccessStatus.SUCCESS 2019-02-27 19:42:48,330 - INFO - COM22.ConfigurationClient: Appkey bind 0 to model 1000 at 0010 In [14]: cc.publish_set(9, 1) In [15]: cc.composition_data_get() In [16]: 2019-02-27 19:43:13,904 - INFO - COM22: PacketSend: {'token': 5} 2019-02-27 19:43:13,907 - INFO - COM22: {event: MeshTxComplete, data: {'token': 5}} 2019-02-27 19:43:13,984 - INFO - COM22.ConfigurationClient: Received composition data (page 0x00): { "cid": "0059", "pid": "0000", "vid": "0000", "crpl": 40, "features": { "relay": 0, "proxy": 0, "friend": 2, "low_power": 2 }, "elements": [ { "index": 0, "location": "0000", "models": [ { "modelId": "0000" }, { "modelId": "0002" } ] }, { "index": 1, "location": "0000", "models": [ { "modelId": "1001" } ] }, { "index": 2, "location": "0000", "models": [ { "modelId": "1001" } ] } ] } In [16]: cc.appkey_add(0) In [17]: 2019-02-27 19:43:20,485 - INFO - COM22: PacketSend: {'token': 6} 2019-02-27 19:43:20,529 - INFO - COM22: {event: MeshTxComplete, data: {'token': 6}} 2019-02-27 19:43:20,555 - INFO - COM22.ConfigurationClient: Appkey status: AccessStatus.SUCCESS 2019-02-27 19:43:20,561 - INFO - COM22.ConfigurationClient: Appkey add 0 succeded for subnet 0 at node 0011 In [17]: cc.model_app_bind(db.nodes[1].unicast_address + 1, 0, mt.ModelId(0x10 ...: 01)) In [18]: 2019-02-27 19:43:28,291 - INFO - COM22: PacketSend: {'token': 7} 2019-02-27 19:43:28,304 - INFO - COM22: {event: MeshTxComplete, data: {'token': 7}} 2019-02-27 19:43:28,319 - INFO - COM22.ConfigurationClient: Model app bind status: AccessStatus.SUCCESS 2019-02-27 19:43:28,323 - INFO - COM22.ConfigurationClient: Appkey bind 0 to model 1001 at 0012 In [18]: cc.model_publication_set(db.nodes[1].unicast_address + 1, mt.ModelId( ...: 0x1001), mt.Publish(db.nodes[0].unicast_address, index=0, ttl=1)) In [19]: 2019-02-27 19:43:45,194 - INFO - COM22: PacketSend: {'token': 8} 2019-02-27 19:43:45,246 - INFO - COM22: {event: MeshTxComplete, data: {'token': 8}} 2019-02-27 19:43:45,293 - INFO - COM22.ConfigurationClient: Model publication status: AccessStatus.SUCCESS 2019-02-27 19:43:45,297 - INFO - COM22.ConfigurationClient: Publication status for model 1001 at element 18 to {'address': 0010, 'index': 0, 'ttl': 1, 'period': 0, 'retransmit': {'count': 0, 'interval_steps': 0, 'interval': 50}, 'credentials': <FriendshipCredentials.DISABLED: 0>} In [19]: cc.publish_set(8, 0) In [20]: cc.model_publication_set(db.nodes[0].unicast_address, mt.ModelId(0x10 ...: 00), mt.Publish(db.groups[0].address, index=0, ttl=1)) In [21]: 2019-02-27 19:44:25,785 - INFO - COM22: PacketSend: {'token': 9} 2019-02-27 19:44:25,823 - INFO - COM22: {event: MeshTxComplete, data: {'token': 9}} 2019-02-27 19:44:25,879 - INFO - COM22.ConfigurationClient: Model publication status: AccessStatus.SUCCESS 2019-02-27 19:44:25,883 - INFO - COM22.ConfigurationClient: Publication status for model 1000 at element 16 to {'address': c001, 'index': 0, 'ttl': 1, 'period': 0, 'retransmit': {'count': 0, 'interval_steps': 0, 'interval': 50}, 'credentials': <FriendshipCredentials.DISABLED: 0>} In [21]: cc.publish_set(9, 1) In [22]: cc.model_subscription_add(db.nodes[1].unicast_address + 1, db.groups[ ...: 0].address, mt.ModelId(0x1001)) In [23]: 2019-02-27 19:44:40,968 - INFO - COM22: PacketSend: {'token': 10} 2019-02-27 19:44:40,987 - INFO - COM22: {event: MeshTxComplete, data: {'token': 10}} 2019-02-27 19:44:41,009 - INFO - COM22.ConfigurationClient: Model subscription status: AccessStatus.SUCCESS 2019-02-27 19:44:41,012 - INFO - COM22.ConfigurationClient: Added subscription 'c001' to model 1001 at element 0012
Light Switch Client Logs:
<t: 0>, main.c, 318, ----- BLE Mesh Light Switch Client Demo ----- <t: 16877>, main.c, 289, Initializing and adding models <t: 21702>, mesh_app_utils.c, 65, Device UUID (raw): 3F2E408B740B17468059FDB1F7E63985 <t: 21705>, mesh_app_utils.c, 70, Device UUID : 8B402E3F-0B74-4617-8059-FDB1F7E63985 <t: 5459476>, mesh_provisionee.c, 196, START prov_evt_handler <t: 5459479>, mesh_provisionee.c, 264, default <t: 5461213>, mesh_provisionee.c, 196, START prov_evt_handler <t: 5461215>, mesh_provisionee.c, 200, NRF_MESH_PROV_EVT_INVITE_RECEIVED <t: 5463901>, mesh_provisionee.c, 196, START prov_evt_handler <t: 5463904>, mesh_provisionee.c, 211, NRF_MESH_PROV_EVT_START_RECEIVED <t: 5547153>, mesh_provisionee.c, 196, START prov_evt_handler <t: 5547155>, mesh_provisionee.c, 255, NRF_MESH_PROV_EVT_COMPLETE <t: 5547972>, mesh_provisionee.c, 196, START prov_evt_handler <t: 5547974>, mesh_provisionee.c, 222, NRF_MESH_PROV_EVT_LINK_CLOSED <t: 5793834>, main.c, 112, Successfully provisioned <t: 5793839>, main.c, 123, Node Address: 0x0011 <t: 7755050>, proxy.c, 638, Adv timeout <t: 9048864>, config_server.c, 623, dsm_appkey_add(appkey_handle:0 appkey_index:0) <t: 9303854>, config_server.c, 2415, Access Info: element_index=1 model_id = 1001-FFFF model_handle=2 <t: 11996461>, main.c, 200, Button 0 pressed <t: 11996464>, main.c, 227, Sending msg: ONOFF SET 1 <t: 11997685>, main.c, 147, Acknowledged transfer success. <t: 11997688>, main.c, 173, OnOff server: 0x0010, Present OnOff: 0, Target OnOff: 1, Remaining Time: 100 ms <t: 11998825>, main.c, 173, OnOff server: 0x0010, Present OnOff: 1, Target OnOff: 1, Remaining Time: 100 ms <t: 12002451>, main.c, 178, OnOff server: 0x0010, Present OnOff: 1 <t: 12083690>, main.c, 200, Button 1 pressed <t: 12083693>, main.c, 227, Sending msg: ONOFF SET 0 <t: 12096556>, main.c, 178, OnOff server: 0x0010, Present OnOff: 0 <t: 12314691>, main.c, 147, Acknowledged transfer success. <t: 12314693>, main.c, 173, OnOff server: 0x0010, Present OnOff: 0, Target OnOff: 0, Remaining Time: 100 ms <t: 12320163>, main.c, 178, OnOff server: 0x0010, Present OnOff: 0 <t: 14129667>, proxy.c, 579, Connected <t: 14154710>, ble_softdevice_support.c, 104, Successfully updated connection parameters <t: 14399808>, mesh_gatt.c, 449, Write Event Fired<t: 14399814>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 14399816>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 14399819>, proxy.c, 611, RX <t: 14399821>, proxy.c, 553, RX GATT PDU type 0x0, len 22 <t: 14686524>, mesh_gatt.c, 449, Write Event Fired<t: 14686530>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 14686533>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 14686535>, proxy.c, 611, RX <t: 14686537>, proxy.c, 553, RX GATT PDU type 0x0, len 22 <t: 186660>, proxy.c, 595, Disconnected <t: 2946931>, proxy.c, 579, Connected <t: 2974858>, ble_softdevice_support.c, 104, Successfully updated connection parameters <t: 3315962>, mesh_gatt.c, 449, Write Event Fired<t: 3315968>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 3315970>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 3315973>, proxy.c, 611, RX <t: 3315975>, proxy.c, 553, RX GATT PDU type 0x0, len 22 <t: 3397881>, mesh_gatt.c, 449, Write Event Fired<t: 3397887>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 3397889>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 3397892>, proxy.c, 611, RX <t: 3397894>, proxy.c, 553, RX GATT PDU type 0x0, len 22 <t: 3660024>, proxy.c, 595, Disconnected <t: 7928682>, proxy.c, 579, Connected <t: 7956842>, ble_softdevice_support.c, 104, Successfully updated connection parameters <t: 8288444>, mesh_gatt.c, 449, Write Event Fired<t: 8288450>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 8288452>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 8288455>, proxy.c, 611, RX <t: 8288456>, proxy.c, 553, RX GATT PDU type 0x0, len 22 <t: 8337595>, mesh_gatt.c, 449, Write Event Fired<t: 8337601>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 8337604>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 8337606>, proxy.c, 611, RX <t: 8337608>, proxy.c, 553, RX GATT PDU type 0x0, len 22
Light Switch Server Logs:
<t: 0>, main.c, 239, ----- BLE Mesh Light Switch Server Demo -----
<t: 17626>, main.c, 219, Initializing and adding models
<t: 17629>, main.c, 114, App OnOff Model Handle: 2
<t: 22512>, mesh_app_utils.c, 65, Device UUID (raw): 2B7A78CB8012BA4486ACB023630C3875
<t: 22515>, mesh_app_utils.c, 70, Device UUID : CB787A2B-1280-44BA-86AC-B023630C3875
<t: 3676619>, mesh_provisionee.c, 196, START prov_evt_handler
<t: 3676622>, mesh_provisionee.c, 264, default
<t: 3676977>, mesh_provisionee.c, 196, START prov_evt_handler
<t: 3676980>, mesh_provisionee.c, 200, NRF_MESH_PROV_EVT_INVITE_RECEIVED
<t: 3679314>, mesh_provisionee.c, 196, START prov_evt_handler
<t: 3679316>, mesh_provisionee.c, 211, NRF_MESH_PROV_EVT_START_RECEIVED
<t: 3757680>, mesh_provisionee.c, 196, START prov_evt_handler
<t: 3757683>, mesh_provisionee.c, 255, NRF_MESH_PROV_EVT_COMPLETE
<t: 3758621>, mesh_provisionee.c, 196, START prov_evt_handler
<t: 3758624>, mesh_provisionee.c, 222, NRF_MESH_PROV_EVT_LINK_CLOSED
<t: 4008306>, main.c, 199, Successfully provisioned
<t: 4008311>, main.c, 210, Node Address: 0x0010
<t: 5970228>, proxy.c, 638, Adv timeout
<t: 7146480>, config_server.c, 623, dsm_appkey_add(appkey_handle:0 appkey_index:0)
<t: 7577640>, config_server.c, 2415, Access Info:
element_index=0 model_id = 1000-FFFF model_handle=2
<t: 11581431>, generic_onoff_server.c, 136, Server: transition_time_ms = 64
<t: 11581434>, generic_onoff_server.c, 137, Server: delay_ms = 32
<t: 11581437>, app_onoff.c, 204, msg: SET: 1
<t: 11583084>, main.c, 96, Setting GPIO value: 1
<t: 11675923>, generic_onoff_server.c, 136, Server: transition_time_ms = 64
<t: 11675926>, generic_onoff_server.c, 137, Server: delay_ms = 32
<t: 11675929>, app_onoff.c, 204, msg: SET: 0
<t: 11680853>, main.c, 96, Setting GPIO value: 0
<t: 11898948>, generic_onoff_server.c, 136, Server: transition_time_ms = 64
<t: 11898952>, generic_onoff_server.c, 137, Server: delay_ms = 32
<t: 11898954>, app_onoff.c, 204, msg: SET: 0
<t: 11903879>, main.c, 96, Setting GPIO value: 0
<t: 754803>, proxy.c, 579, Connected
<t: 779957>, ble_softdevice_support.c, 104, Successfully updated connection parameters
<t: 1810824>, mesh_gatt.c, 449, Write Event Fired<t: 1810830>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 1810833>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 1810835>, proxy.c, 611, RX
<t: 1810837>, proxy.c, 553, RX GATT PDU type 0x0, len 22
<t: 1917319>, mesh_gatt.c, 449, Write Event Fired<t: 1917325>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 1917327>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 1917330>, proxy.c, 611, RX
<t: 1917332>, proxy.c, 553, RX GATT PDU type 0x0, len 22
<t: 2220422>, proxy.c, 595, Disconnected
<t: 4586245>, proxy.c, 579, Connected
<t: 4613772>, ble_softdevice_support.c, 104, Successfully updated connection parameters
<t: 4931939>, mesh_gatt.c, 449, Write Event Fired<t: 4931946>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 4931948>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 4931951>, proxy.c, 611, RX
<t: 4931952>, proxy.c, 553, RX GATT PDU type 0x0, len 22
<t: 5153121>, mesh_gatt.c, 449, Write Event Fired<t: 5153127>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 5153130>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 5153133>, proxy.c, 611, RX
<t: 5153134>, proxy.c, 553, RX GATT PDU type 0x0, len 22
<t: 5800285>, proxy.c, 595, Disconnected
<t: 6326083>, proxy.c, 579, Connected
<t: 6353738>, ble_softdevice_support.c, 104, Successfully updated connection parameters
<t: 6553939>, mesh_gatt.c, 449, Write Event Fired<t: 6553943>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 6553945>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 6553948>, proxy.c, 611, RX
<t: 6553954>, proxy.c, 553, RX GATT PDU type 0x0, len 22
<t: 6685009>, mesh_gatt.c, 449, Write Event Fired<t: 6685015>, mesh_gatt.c, 455, Valid PDU Length and Type<t: 6685017>, mesh_gatt.c, 465, RX not in progress, First Segment<t: 6685020>, proxy.c, 611, RX
<t: 6685022>, proxy.c, 553, RX GATT PDU type 0x0, len 22
<t: 7102798>, proxy.c, 595, Disconnected
Serial Example logs (provisioner in the PyACI script):
<t: 0>, main.c, 77, ----- Bluetooth Mesh Serial Interface Application -----
<t: 13394>, main.c, 63, Enabling ECDH offloading...
<t: 13397>, main.c, 66, Initializing serial interface...
<t: 13399>, serial_handler_prov.c, 267, Generating encryption keypair...
<t: 18240>, main.c, 86, Initialization complete!
<t: 18243>, mesh_app_utils.c, 65, Device UUID (raw): 645DAD1ABA4EDF4C947905A8F7E66189
<t: 18247>, mesh_app_utils.c, 70, Device UUID : 1AAD5D64-4EBA-4CDF-9479-05A8F7E66189
<t: 18256>, main.c, 97, Bluetooth Mesh Serial Interface Application started!
<t: 7340560>, net_packet.c, 230, Unencrypted data: : 00018000000212270A3B324529EC8E7DE082
<t: 7340565>, transport.c, 849, Got segment 0
<t: 7341500>, net_packet.c, 230, Unencrypted data: : 000180000022C86C0C0408CE263E4CC1F23C
<t: 7341504>, transport.c, 849, Got segment 1
<t: 7342396>, net_packet.c, 230, Unencrypted data: : 000180000042CACB
<t: 7342399>, transport.c, 849, Got segment 2
<t: 7342410>, transport.c, 934, Message decrypted
<t: 8047172>, transport.c, 1233, TX:SAR packet: 88BDA930BEFF779CF7AD9D53EF1269A1E3E0B3484BE4965B
<t: 8048569>, net_packet.c, 230, Unencrypted data: : 000100000C00000003
<t: 8049526>, net_packet.c, 230, Unencrypted data: : 000100A97A75792EE6F071400B
<t: 8049532>, transport.c, 934, Message decrypted
<t: 8480187>, net_packet.c, 230, Unencrypted data: : 0001003662A3AA25FC3B9A1271C36EEF
<t: 8480193>, transport.c, 934, Message decrypted
<t: 9318922>, net_packet.c, 230, Unencrypted data: : 0001800000027B4EAB3E37E4E4407399D24E
<t: 9318926>, transport.c, 849, Got segment 0
<t: 9319766>, net_packet.c, 230, Unencrypted data: : 0001800000229E658D41183C229552CDA4EF
<t: 9319770>, transport.c, 849, Got segment 1
<t: 9320661>, net_packet.c, 230, Unencrypted data: : 000180000042F702C8D7BE4541B7BB021B3C
<t: 9320665>, transport.c, 849, Got segment 2
<t: 9320675>, transport.c, 934, Message decrypted
<t: 9533956>, transport.c, 1233, TX:SAR packet: 55A2E9DFFF84A3367CAD0F310ED70632A09EF23E0B01066F
<t: 9535403>, net_packet.c, 230, Unencrypted data: : 000100002000000003
<t: 9536166>, net_packet.c, 230, Unencrypted data: : 0001008089882DC2AD15719053
<t: 9536172>, transport.c, 934, Message decrypted
<t: 9790603>, net_packet.c, 230, Unencrypted data: : 0001001F637623DA06E6F3408C6EA8EF
<t: 9790609>, transport.c, 934, Message decrypted
<t: 10343612>, transport.c, 1233, TX:SAR packet: CBCCADDE08CB2443AC1A47E102AC4CF6
<t: 10345295>, net_packet.c, 230, Unencrypted data: : 000100002C00000003
<t: 10346055>, net_packet.c, 230, Unencrypted data: : 000180001C016C9B407512F5C27B51DD3651
<t: 10346059>, transport.c, 849, Got segment 0
<t: 10346772>, net_packet.c, 230, Unencrypted data: : 000180001C2120B68E248FB4
<t: 10346776>, transport.c, 849, Got segment 1
<t: 10346785>, transport.c, 934, Message decrypted
<t: 11673682>, transport.c, 1233, TX:SAR packet: F260072C4CA5FCB7D58D2D4763561131
<t: 11674907>, net_packet.c, 230, Unencrypted data: : 000100003800000003
<t: 11675842>, net_packet.c, 230, Unencrypted data: : 000180001C0111384FCEF72BDD4042C05BE5
<t: 11675846>, transport.c, 849, Got segment 0
<t: 11676630>, net_packet.c, 230, Unencrypted data: : 000180001C2128433D39634E
<t: 11676634>, transport.c, 849, Got segment 1
<t: 11676643>, transport.c, 934, Message decrypted
<t: 12172505>, net_packet.c, 230, Unencrypted data: : 000100185FCC85BA191A6F979B1001C1
<t: 12172511>, transport.c, 934, Message decrypted
<t: 12483443>, net_packet.c, 230, Unencrypted data: : 00106E43D91F87F5EAE25A8511
<t: 12484072>, net_packet.c, 230, Unencrypted data: : 00126EC200FA2C1FAC59ADE5
<t: 12485212>, net_packet.c, 230, Unencrypted data: : C0016E7CA991517687767870
<t: 12488836>, net_packet.c, 230, Unencrypted data: : C0016E50DB34AE3B4C31
<t: 12570678>, net_packet.c, 230, Unencrypted data: : 00106E5DBF7DA94652141AAC73
<t: 12577896>, net_packet.c, 230, Unencrypted data: : 00106E10D4EC273A9703388739
<t: 12578374>, net_packet.c, 230, Unencrypted data: : 00126E938FC233A8EC4626B7
<t: 12582894>, net_packet.c, 230, Unencrypted data: : C0016E7774C70C76C848
<t: 12584579>, net_packet.c, 230, Unencrypted data: : 00106EBCFE55FE914007419AF2
<t: 12599119>, net_packet.c, 230, Unencrypted data: : 00106E0FED2FEC92A79CDE5A89
<t: 12628155>, net_packet.c, 230, Unencrypted data: : 00106E0BE3749C81187E14BBCA
<t: 12685694>, net_packet.c, 230, Unencrypted data: : 00106E49CBE30AF61992504413
<t: 12800920>, net_packet.c, 230, Unencrypted data: : 00106EDFA617626E5AE383FFFD
<t: 12801039>, net_packet.c, 230, Unencrypted data: : 00126E066CC5CDDEE176B3E7
<t: 12806512>, net_packet.c, 230, Unencrypted data: : C0016EDCE1092C357308
Node.js Proxy Client logs:
VM150 app.js:362 setBluetoothButtons: connected=false,selected_device=null VM150 app.js:412 enableButton: btn_scan VM150 app.js:406 disableButton: btn_connection VM150 app.js:406 disableButton: btn_submit VM150 app.js:270 deriveProxyPdu VM150 app.js:274 access_payload=d50a0048656c6c6f VM150 app.js:279 upper_transport_pdu=3b9e1f8b6826d78fe9ec4ef0 VM150 app.js:285 lower_transport_pdu=6e3b9e1f8b6826d78fe9ec4ef0 VM150 app.js:290 EncDST="f646" EncTransportPDU="00431cdbe713ffadcebc718adb" VM150 app.js:296 obfuscated_ctl_ttl_seq_src="bb5e9a832968" VM150 app.js:300 finalised_network_pdu=f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM150 app.js:306 proxy_pdu=00f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM150 app.js:270 deriveProxyPdu VM150 app.js:274 access_payload=82030101 VM150 app.js:279 upper_transport_pdu=6c971ec298b0093c VM150 app.js:285 lower_transport_pdu=6e6c971ec298b0093c VM150 app.js:290 EncDST="f646" EncTransportPDU="001415daaee369737d" VM150 app.js:296 obfuscated_ctl_ttl_seq_src="5abfd964b7cd" VM150 app.js:300 finalised_network_pdu=f45abfd964b7cdf646001415daaee369737dc9651473 VM150 app.js:306 proxy_pdu=00f45abfd964b7cdf646001415daaee369737dc9651473 VM150 app.js:81 Scanning.... VM150 app.js:87 startScan VM150 app.js:94 > Name: nRF5x Mesh Switch VM150 app.js:95 > Id: hFeUTcOXueyLaYz2RZX0mg== VM150 app.js:96 > Connected: false VM150 app.js:98 BluetoothDevice {id: "hFeUTcOXueyLaYz2RZX0mg==", name: "nRF5x Mesh Switch", gatt: BluetoothRemoteGATTServer, ongattserverdisconnected: null} VM150 app.js:111 Connected to hFeUTcOXueyLaYz2RZX0mg== VM150 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM150 app.js:406 disableButton: btn_scan VM150 app.js:412 enableButton: btn_connection VM150 app.js:159 discoverSvcsAndChars server=[object BluetoothRemoteGATTServer] VM150 app.js:162 Getting Characteristics... VM150 app.js:165 > Service: 00001828-0000-1000-8000-00805f9b34fb VM150 app.js:171 >> Characteristic: 00002add-0000-1000-8000-00805f9b34fb VM150 app.js:171 >> Characteristic: 00002ade-0000-1000-8000-00805f9b34fb VM150 app.js:181 Last characteristic discovered VM150 app.js:119 service discovery has completed VM150 app.js:387 clearMessage VM150 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM150 app.js:406 disableButton: btn_scan VM150 app.js:412 enableButton: btn_connection VM150 app.js:412 enableButton: btn_submit VM150 app.js:387 clearMessage VM150 app.js:270 deriveProxyPdu VM150 app.js:274 access_payload=82030101 VM150 app.js:279 upper_transport_pdu=6c971ec298b0093c VM150 app.js:285 lower_transport_pdu=6e6c971ec298b0093c VM150 app.js:290 EncDST="f646" EncTransportPDU="001415daaee369737d" VM150 app.js:296 obfuscated_ctl_ttl_seq_src="5abfd964b7cd" VM150 app.js:300 finalised_network_pdu=f45abfd964b7cdf646001415daaee369737dc9651473 VM150 app.js:306 proxy_pdu=00f45abfd964b7cdf646001415daaee369737dc9651473 VM150 app.js:338 sent proxy pdu OK VM150 app.js:270 deriveProxyPdu VM150 app.js:274 access_payload=82030101 VM150 app.js:279 upper_transport_pdu=6c971ec298b0093c VM150 app.js:285 lower_transport_pdu=6e6c971ec298b0093c VM150 app.js:290 EncDST="f646" EncTransportPDU="001415daaee369737d" VM150 app.js:296 obfuscated_ctl_ttl_seq_src="5abfd964b7cd" VM150 app.js:300 finalised_network_pdu=f45abfd964b7cdf646001415daaee369737dc9651473 VM150 app.js:306 proxy_pdu=00f45abfd964b7cdf646001415daaee369737dc9651473 VM150 app.js:338 sent proxy pdu OK Navigated to https://127.0.0.1:8000/index.htm VM162 app.js:362 setBluetoothButtons: connected=false,selected_device=null VM162 app.js:412 enableButton: btn_scan VM162 app.js:406 disableButton: btn_connection VM162 app.js:406 disableButton: btn_submit VM162 app.js:270 deriveProxyPdu VM162 app.js:274 access_payload=d50a0048656c6c6f VM162 app.js:279 upper_transport_pdu=3b9e1f8b6826d78fe9ec4ef0 VM162 app.js:285 lower_transport_pdu=6e3b9e1f8b6826d78fe9ec4ef0 VM162 app.js:290 EncDST="f646" EncTransportPDU="00431cdbe713ffadcebc718adb" VM162 app.js:296 obfuscated_ctl_ttl_seq_src="bb5e9a832968" VM162 app.js:300 finalised_network_pdu=f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM162 app.js:306 proxy_pdu=00f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM162 app.js:81 Scanning.... VM162 app.js:87 startScan VM162 app.js:94 > Name: nRF5x Mesh Light VM162 app.js:95 > Id: jCVVKv7qbtmZ5LoGYylIXg== VM162 app.js:96 > Connected: false VM162 app.js:98 BluetoothDevice {id: "jCVVKv7qbtmZ5LoGYylIXg==", name: "nRF5x Mesh Light", gatt: BluetoothRemoteGATTServer, ongattserverdisconnected: null} VM162 app.js:111 Connected to jCVVKv7qbtmZ5LoGYylIXg== VM162 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM162 app.js:406 disableButton: btn_scan VM162 app.js:412 enableButton: btn_connection VM162 app.js:159 discoverSvcsAndChars server=[object BluetoothRemoteGATTServer] VM162 app.js:162 Getting Characteristics... VM162 app.js:165 > Service: 00001828-0000-1000-8000-00805f9b34fb VM162 app.js:171 >> Characteristic: 00002add-0000-1000-8000-00805f9b34fb VM162 app.js:171 >> Characteristic: 00002ade-0000-1000-8000-00805f9b34fb VM162 app.js:181 Last characteristic discovered VM162 app.js:119 service discovery has completed VM162 app.js:387 clearMessage VM162 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM162 app.js:406 disableButton: btn_scan VM162 app.js:412 enableButton: btn_connection VM162 app.js:412 enableButton: btn_submit VM162 app.js:387 clearMessage VM162 app.js:270 deriveProxyPdu VM162 app.js:274 access_payload=82030101 VM162 app.js:279 upper_transport_pdu=6c971ec298b0093c VM162 app.js:285 lower_transport_pdu=6e6c971ec298b0093c VM162 app.js:290 EncDST="f646" EncTransportPDU="001415daaee369737d" VM162 app.js:296 obfuscated_ctl_ttl_seq_src="5abfd964b7cd" VM162 app.js:300 finalised_network_pdu=f45abfd964b7cdf646001415daaee369737dc9651473 VM162 app.js:306 proxy_pdu=00f45abfd964b7cdf646001415daaee369737dc9651473 VM162 app.js:270 deriveProxyPdu VM162 app.js:274 access_payload=82030101 VM162 app.js:279 upper_transport_pdu=6c971ec298b0093c VM162 app.js:285 lower_transport_pdu=6e6c971ec298b0093c VM162 app.js:290 EncDST="f646" EncTransportPDU="001415daaee369737d" VM162 app.js:296 obfuscated_ctl_ttl_seq_src="5abfd964b7cd" VM162 app.js:300 finalised_network_pdu=f45abfd964b7cdf646001415daaee369737dc9651473 VM162 app.js:306 proxy_pdu=00f45abfd964b7cdf646001415daaee369737dc9651473 VM162 app.js:338 sent proxy pdu OK VM162 app.js:270 deriveProxyPdu VM162 app.js:274 access_payload=82030101 VM162 app.js:279 upper_transport_pdu=6c971ec298b0093c VM162 app.js:285 lower_transport_pdu=6e6c971ec298b0093c VM162 app.js:290 EncDST="f646" EncTransportPDU="001415daaee369737d" VM162 app.js:296 obfuscated_ctl_ttl_seq_src="5abfd964b7cd" VM162 app.js:300 finalised_network_pdu=f45abfd964b7cdf646001415daaee369737dc9651473 VM162 app.js:306 proxy_pdu=00f45abfd964b7cdf646001415daaee369737dc9651473 VM162 app.js:338 sent proxy pdu OK Navigated to https://127.0.0.1:8000/index.htm VM174 app.js:362 setBluetoothButtons: connected=false,selected_device=null VM174 app.js:412 enableButton: btn_scan VM174 app.js:406 disableButton: btn_connection VM174 app.js:406 disableButton: btn_submit VM174 app.js:270 deriveProxyPdu VM174 app.js:274 access_payload=d50a0048656c6c6f VM174 app.js:279 upper_transport_pdu=3b9e1f8b6826d78fe9ec4ef0 VM174 app.js:285 lower_transport_pdu=6e3b9e1f8b6826d78fe9ec4ef0 VM174 app.js:290 EncDST="f646" EncTransportPDU="00431cdbe713ffadcebc718adb" VM174 app.js:296 obfuscated_ctl_ttl_seq_src="bb5e9a832968" VM174 app.js:300 finalised_network_pdu=f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM174 app.js:306 proxy_pdu=00f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM174 app.js:81 Scanning.... VM174 app.js:87 startScan VM174 app.js:94 > Name: nRF5x Mesh Switch VM174 app.js:95 > Id: hFeUTcOXueyLaYz2RZX0mg== VM174 app.js:96 > Connected: false VM174 app.js:98 BluetoothDevice {id: "hFeUTcOXueyLaYz2RZX0mg==", name: "nRF5x Mesh Switch", gatt: BluetoothRemoteGATTServer, ongattserverdisconnected: null} VM174 app.js:111 Connected to hFeUTcOXueyLaYz2RZX0mg== VM174 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM174 app.js:406 disableButton: btn_scan VM174 app.js:412 enableButton: btn_connection VM174 app.js:159 discoverSvcsAndChars server=[object BluetoothRemoteGATTServer] VM174 app.js:270 deriveProxyPdu VM174 app.js:274 access_payload=82020101 VM174 app.js:279 upper_transport_pdu=6c961ec237b67257 VM174 app.js:285 lower_transport_pdu=6e6c961ec237b67257 VM174 app.js:290 EncDST="f646" EncTransportPDU="001414daae4c6f0816" VM174 app.js:296 obfuscated_ctl_ttl_seq_src="48f15ecdf8bd" VM174 app.js:300 finalised_network_pdu=f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM174 app.js:306 proxy_pdu=00f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM174 app.js:162 Getting Characteristics... VM174 app.js:165 > Service: 00001828-0000-1000-8000-00805f9b34fb VM174 app.js:171 >> Characteristic: 00002add-0000-1000-8000-00805f9b34fb VM174 app.js:171 >> Characteristic: 00002ade-0000-1000-8000-00805f9b34fb VM174 app.js:181 Last characteristic discovered VM174 app.js:119 service discovery has completed VM174 app.js:387 clearMessage VM174 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM174 app.js:406 disableButton: btn_scan VM174 app.js:412 enableButton: btn_connection VM174 app.js:412 enableButton: btn_submit VM174 app.js:387 clearMessage VM174 app.js:270 deriveProxyPdu VM174 app.js:274 access_payload=82020101 VM174 app.js:279 upper_transport_pdu=6c961ec237b67257 VM174 app.js:285 lower_transport_pdu=6e6c961ec237b67257 VM174 app.js:290 EncDST="f646" EncTransportPDU="001414daae4c6f0816" VM174 app.js:296 obfuscated_ctl_ttl_seq_src="48f15ecdf8bd" VM174 app.js:300 finalised_network_pdu=f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM174 app.js:306 proxy_pdu=00f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM174 app.js:338 sent proxy pdu OK VM174 app.js:270 deriveProxyPdu VM174 app.js:274 access_payload=82020101 VM174 app.js:279 upper_transport_pdu=6c961ec237b67257 VM174 app.js:285 lower_transport_pdu=6e6c961ec237b67257 VM174 app.js:290 EncDST="f646" EncTransportPDU="001414daae4c6f0816" VM174 app.js:296 obfuscated_ctl_ttl_seq_src="48f15ecdf8bd" VM174 app.js:300 finalised_network_pdu=f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM174 app.js:306 proxy_pdu=00f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM174 app.js:338 sent proxy pdu OK Navigated to https://127.0.0.1:8000/index.htm VM186 app.js:362 setBluetoothButtons: connected=false,selected_device=null VM186 app.js:412 enableButton: btn_scan VM186 app.js:406 disableButton: btn_connection VM186 app.js:406 disableButton: btn_submit VM186 app.js:270 deriveProxyPdu VM186 app.js:274 access_payload=d50a0048656c6c6f VM186 app.js:279 upper_transport_pdu=3b9e1f8b6826d78fe9ec4ef0 VM186 app.js:285 lower_transport_pdu=6e3b9e1f8b6826d78fe9ec4ef0 VM186 app.js:290 EncDST="f646" EncTransportPDU="00431cdbe713ffadcebc718adb" VM186 app.js:296 obfuscated_ctl_ttl_seq_src="bb5e9a832968" VM186 app.js:300 finalised_network_pdu=f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM186 app.js:306 proxy_pdu=00f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM186 app.js:270 deriveProxyPdu VM186 app.js:274 access_payload=82020101 VM186 app.js:279 upper_transport_pdu=6c961ec237b67257 VM186 app.js:285 lower_transport_pdu=6e6c961ec237b67257 VM186 app.js:290 EncDST="f646" EncTransportPDU="001414daae4c6f0816" VM186 app.js:296 obfuscated_ctl_ttl_seq_src="48f15ecdf8bd" VM186 app.js:300 finalised_network_pdu=f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM186 app.js:306 proxy_pdu=00f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM186 app.js:81 Scanning.... VM186 app.js:87 startScan VM186 app.js:94 > Name: nRF5x Mesh Light VM186 app.js:95 > Id: jCVVKv7qbtmZ5LoGYylIXg== VM186 app.js:96 > Connected: false VM186 app.js:98 BluetoothDevice {id: "jCVVKv7qbtmZ5LoGYylIXg==", name: "nRF5x Mesh Light", gatt: BluetoothRemoteGATTServer, ongattserverdisconnected: null} VM186 app.js:111 Connected to jCVVKv7qbtmZ5LoGYylIXg== VM186 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM186 app.js:406 disableButton: btn_scan VM186 app.js:412 enableButton: btn_connection VM186 app.js:159 discoverSvcsAndChars server=[object BluetoothRemoteGATTServer] VM186 app.js:162 Getting Characteristics... VM186 app.js:165 > Service: 00001828-0000-1000-8000-00805f9b34fb VM186 app.js:171 >> Characteristic: 00002add-0000-1000-8000-00805f9b34fb VM186 app.js:171 >> Characteristic: 00002ade-0000-1000-8000-00805f9b34fb VM186 app.js:181 Last characteristic discovered VM186 app.js:119 service discovery has completed VM186 app.js:387 clearMessage VM186 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM186 app.js:406 disableButton: btn_scan VM186 app.js:412 enableButton: btn_connection VM186 app.js:412 enableButton: btn_submit VM186 app.js:387 clearMessage VM186 app.js:270 deriveProxyPdu VM186 app.js:274 access_payload=82020101 VM186 app.js:279 upper_transport_pdu=6c961ec237b67257 VM186 app.js:285 lower_transport_pdu=6e6c961ec237b67257 VM186 app.js:290 EncDST="f646" EncTransportPDU="001414daae4c6f0816" VM186 app.js:296 obfuscated_ctl_ttl_seq_src="48f15ecdf8bd" VM186 app.js:300 finalised_network_pdu=f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM186 app.js:306 proxy_pdu=00f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM186 app.js:338 sent proxy pdu OK VM186 app.js:270 deriveProxyPdu VM186 app.js:274 access_payload=82020101 VM186 app.js:279 upper_transport_pdu=6c961ec237b67257 VM186 app.js:285 lower_transport_pdu=6e6c961ec237b67257 VM186 app.js:290 EncDST="f646" EncTransportPDU="001414daae4c6f0816" VM186 app.js:296 obfuscated_ctl_ttl_seq_src="48f15ecdf8bd" VM186 app.js:300 finalised_network_pdu=f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM186 app.js:306 proxy_pdu=00f448f15ecdf8bdf646001414daae4c6f08160dd36ffe VM186 app.js:338 sent proxy pdu OK Navigated to https://127.0.0.1:8000/index.htm VM198 app.js:362 setBluetoothButtons: connected=false,selected_device=null VM198 app.js:412 enableButton: btn_scan VM198 app.js:406 disableButton: btn_connection VM198 app.js:406 disableButton: btn_submit VM198 app.js:270 deriveProxyPdu VM198 app.js:274 access_payload=d50a0048656c6c6f VM198 app.js:279 upper_transport_pdu=3b9e1f8b6826d78fe9ec4ef0 VM198 app.js:285 lower_transport_pdu=6e3b9e1f8b6826d78fe9ec4ef0 VM198 app.js:290 EncDST="f646" EncTransportPDU="00431cdbe713ffadcebc718adb" VM198 app.js:296 obfuscated_ctl_ttl_seq_src="bb5e9a832968" VM198 app.js:300 finalised_network_pdu=f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM198 app.js:306 proxy_pdu=00f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 VM198 app.js:270 deriveProxyPdu VM198 app.js:274 access_payload=82020001 VM198 app.js:279 upper_transport_pdu=f541da82797a0d62 VM198 app.js:285 lower_transport_pdu=6ef541da82797a0d62 VM198 app.js:290 EncDST="5d9e" EncTransportPDU="008dc31eee02a37723" VM198 app.js:296 obfuscated_ctl_ttl_seq_src="1e8ae71471c3" VM198 app.js:300 finalised_network_pdu=f41e8ae71471c35d9e008dc31eee02a37723394a231d VM198 app.js:306 proxy_pdu=00f41e8ae71471c35d9e008dc31eee02a37723394a231d VM198 app.js:81 Scanning.... VM198 app.js:87 startScan VM198 app.js:94 > Name: nRF5x Mesh Light VM198 app.js:95 > Id: jCVVKv7qbtmZ5LoGYylIXg== VM198 app.js:96 > Connected: false VM198 app.js:98 BluetoothDevice {id: "jCVVKv7qbtmZ5LoGYylIXg==", name: "nRF5x Mesh Light", gatt: BluetoothRemoteGATTServer, ongattserverdisconnected: null} VM198 app.js:111 Connected to jCVVKv7qbtmZ5LoGYylIXg== VM198 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM198 app.js:406 disableButton: btn_scan VM198 app.js:412 enableButton: btn_connection VM198 app.js:159 discoverSvcsAndChars server=[object BluetoothRemoteGATTServer] VM198 app.js:162 Getting Characteristics... VM198 app.js:165 > Service: 00001828-0000-1000-8000-00805f9b34fb VM198 app.js:171 >> Characteristic: 00002add-0000-1000-8000-00805f9b34fb VM198 app.js:171 >> Characteristic: 00002ade-0000-1000-8000-00805f9b34fb VM198 app.js:181 Last characteristic discovered VM198 app.js:119 service discovery has completed VM198 app.js:387 clearMessage VM198 app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] VM198 app.js:406 disableButton: btn_scan VM198 app.js:412 enableButton: btn_connection VM198 app.js:412 enableButton: btn_submit VM198 app.js:387 clearMessage VM198 app.js:270 deriveProxyPdu VM198 app.js:274 access_payload=82020001 VM198 app.js:279 upper_transport_pdu=f541da82797a0d62 VM198 app.js:285 lower_transport_pdu=6ef541da82797a0d62 VM198 app.js:290 EncDST="5d9e" EncTransportPDU="008dc31eee02a37723" VM198 app.js:296 obfuscated_ctl_ttl_seq_src="1e8ae71471c3" VM198 app.js:300 finalised_network_pdu=f41e8ae71471c35d9e008dc31eee02a37723394a231d VM198 app.js:306 proxy_pdu=00f41e8ae71471c35d9e008dc31eee02a37723394a231d VM198 app.js:338 sent proxy pdu OK VM198 app.js:270 deriveProxyPdu VM198 app.js:274 access_payload=82020001 VM198 app.js:279 upper_transport_pdu=f541da82797a0d62 VM198 app.js:285 lower_transport_pdu=6ef541da82797a0d62 VM198 app.js:290 EncDST="5d9e" EncTransportPDU="008dc31eee02a37723" VM198 app.js:296 obfuscated_ctl_ttl_seq_src="1e8ae71471c3" VM198 app.js:300 finalised_network_pdu=f41e8ae71471c35d9e008dc31eee02a37723394a231d VM198 app.js:306 proxy_pdu=00f41e8ae71471c35d9e008dc31eee02a37723394a231d VM198 app.js:338 sent proxy pdu OK Navigated to https://127.0.0.1:8000/index.htm app.js:362 setBluetoothButtons: connected=false,selected_device=null app.js:412 enableButton: btn_scan app.js:406 disableButton: btn_connection app.js:406 disableButton: btn_submit app.js:270 deriveProxyPdu app.js:274 access_payload=d50a0048656c6c6f app.js:279 upper_transport_pdu=3b9e1f8b6826d78fe9ec4ef0 app.js:285 lower_transport_pdu=6e3b9e1f8b6826d78fe9ec4ef0 app.js:290 EncDST="f646" EncTransportPDU="00431cdbe713ffadcebc718adb" app.js:296 obfuscated_ctl_ttl_seq_src="bb5e9a832968" app.js:300 finalised_network_pdu=f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 app.js:306 proxy_pdu=00f4bb5e9a832968f64600431cdbe713ffadcebc718adb5ea8b4b2 app.js:81 Scanning.... app.js:87 startScan app.js:94 > Name: nRF5x Mesh Switch app.js:95 > Id: hFeUTcOXueyLaYz2RZX0mg== app.js:96 > Connected: false app.js:98 BluetoothDevice {id: "hFeUTcOXueyLaYz2RZX0mg==", name: "nRF5x Mesh Switch", gatt: BluetoothRemoteGATTServer, ongattserverdisconnected: null} app.js:111 Connected to hFeUTcOXueyLaYz2RZX0mg== app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] app.js:406 disableButton: btn_scan app.js:412 enableButton: btn_connection app.js:159 discoverSvcsAndChars server=[object BluetoothRemoteGATTServer] app.js:162 Getting Characteristics... app.js:165 > Service: 00001828-0000-1000-8000-00805f9b34fb app.js:171 >> Characteristic: 00002add-0000-1000-8000-00805f9b34fb app.js:171 >> Characteristic: 00002ade-0000-1000-8000-00805f9b34fb app.js:181 Last characteristic discovered app.js:119 service discovery has completed app.js:387 clearMessage app.js:362 setBluetoothButtons: connected=true,selected_device=[object BluetoothDevice] app.js:406 disableButton: btn_scan app.js:412 enableButton: btn_connection app.js:412 enableButton: btn_submit app.js:387 clearMessage app.js:270 deriveProxyPdu app.js:274 access_payload=82020101 app.js:279 upper_transport_pdu=6c961ec237b67257 app.js:285 lower_transport_pdu=6e6c961ec237b67257 app.js:290 EncDST="f646" EncTransportPDU="001414daae4c6f0816" app.js:296 obfuscated_ctl_ttl_seq_src="48f15ecdf8bd" app.js:300 finalised_network_pdu=f448f15ecdf8bdf646001414daae4c6f08160dd36ffe app.js:306 proxy_pdu=00f448f15ecdf8bdf646001414daae4c6f08160dd36ffe app.js:270 deriveProxyPdu app.js:274 access_payload=82020101 app.js:279 upper_transport_pdu=f541db8214c399ff app.js:285 lower_transport_pdu=6ef541db8214c399ff app.js:290 EncDST="5d9e" EncTransportPDU="008dc31fee6f1ae3be" app.js:296 obfuscated_ctl_ttl_seq_src="aeccc966a33b" app.js:300 finalised_network_pdu=f4aeccc966a33b5d9e008dc31fee6f1ae3beff0053f5 app.js:306 proxy_pdu=00f4aeccc966a33b5d9e008dc31fee6f1ae3beff0053f5 app.js:270 deriveProxyPdu app.js:274 access_payload=82020101 app.js:279 upper_transport_pdu=f541db8214c399ff app.js:285 lower_transport_pdu=6ef541db8214c399ff app.js:290 EncDST="5d9e" EncTransportPDU="008dc31fee6f1ae3be" app.js:296 obfuscated_ctl_ttl_seq_src="aeccc966a33b" app.js:300 finalised_network_pdu=f4aeccc966a33b5d9e008dc31fee6f1ae3beff0053f5 app.js:306 proxy_pdu=00f4aeccc966a33b5d9e008dc31fee6f1ae3beff0053f5 app.js:338 sent proxy pdu OK app.js:270 deriveProxyPdu app.js:274 access_payload=82020101 app.js:279 upper_transport_pdu=f541db8214c399ff app.js:285 lower_transport_pdu=6ef541db8214c399ff app.js:290 EncDST="5d9e" EncTransportPDU="008dc31fee6f1ae3be" app.js:296 obfuscated_ctl_ttl_seq_src="aeccc966a33b" app.js:300 finalised_network_pdu=f4aeccc966a33b5d9e008dc31fee6f1ae3beff0053f5 app.js:306 proxy_pdu=00f4aeccc966a33b5d9e008dc31fee6f1ae3beff0053f5 app.js:338 sent proxy pdu OK
