nRF9160 DK testing
nRF9160 DK: I followed the userguide , devzone.nordicsemi.com/.../getting-started-with-nrf9160-dk
I done with 2 examples: AT Client and Asset Tracker examples. I passed Build and Run. Then, used nRF Connect to check, but nothing came. AT commands didnt work, AssetTracker neither. The led3 and led4 were OFF. Whats wrong?
The LTE didnt ON yet!
I am using the gcc arm 7-2018 ( i couldnt run with version 8-2018)
Can you tell me why, did I do something wrong?
Hng
Cypod Solution
942 06 177
Horten
  • Hi Øyvind,
    Can we have more SIM card for testing?
    hng
  • Each SIM can be used freely on any device, but since its tied to an account on nrfcloud to prepay for more data, you have to go through this portal to expand the data package on your SIM. When the SIM reaches the 10 MB limit, nrfcloud.com should provide a notice about this where you can buy more data.
    Contact your local telecom company if you want another subscription
    Øyvind
  • Hi Øyvind,
    I changed to another TALE-SIM of Telia, and programmed SecureBoot and At_Client, and I got respond. I think, the problems came from the iBasic eSIM. I will try to look for GPS/LTE SIM card. and test again
    Tusen hjertelig takk for hjelpen
    hng
  • Hei Hoang!
    Bare hyggelig! :)
    If you do get any more issues, please paste the output of the LTE Link Monitor here, and we can have a look at the AT responses.
    God helg!
    Oeyvind
  • Hi Øyvind,
    I tried again step by step to understand more about nrf9160 DK
    1.
    nRF9160: Secure Boot
    Connect nRF9160 DK , turn on and SW5 to nRF91: Build and Run
    Preparing target for download
    Executing script TargetInterface.resetAndStop()
    Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Reset: Reset device via AIRCR.SYSRESETREQ.
    Downloading ‘zephyr.elf’ to J-Link
    Programming 13.3 KB of addresses 00000000 — 0000353f
    Programming 0.1 KB of addresses 00003540 — 000035f3
    J-Link: Flash download: Bank 0 @ 0x00000000: Skipped. Contents already match
    Download successful
    Run: nRF Connect v2.6.2 - LTE Link Monitor , Select device
    2019-03-02T09:46:15.689Z DEBUG modem << Secure Boot: configure peripherals\x0D\x0A
    2019-03-02T09:46:15.710Z DEBUG modem << Secure Boot: MSP_NS ffffffff\x0D\x0A
    2019-03-02T09:46:15.730Z DEBUG modem << Secure Boot: prepare to jump to Non-Secure image\x0D\x0A
    2019-03-02T09:46:15.750Z DEBUG modem << ***** Booting Zephyr OS v1.13.99-ncs2 *****\x0D\x0A
    2019-03-02T09:46:15.771Z DEBUG modem << Secure Boot: configure flash\x0D\x0A
    2019-03-02T09:46:15.794Z DEBUG modem << Secure Boot: SPU: set region 0 as Secure\x0D\x0A
    2019-03-02T09:46:15.815Z DEBUG modem << Secure Boot: SPU: set region 1 as Secure\x0D\x0A
    2019-03-02T09:46:15.835Z DEBUG modem << Secure Boot: SPU: set region 2 as Secure\x0D\x0A
    2019-03-02T09:46:15.857Z DEBUG modem << Secure Boot: SPU: set region 3 as Secure\x0D\x0A
    2019-03-02T09:46:15.876Z DEBUG modem << Secure Boot: SPU: set region 4 as Secure\x0D\x0A
    2019-03-02T09:46:15.897Z DEBUG modem << Secure Boot: SPU: set region 5 as Secure\x0D\x0A
    2019-03-02T09:46:15.918Z DEBUG modem << Secure Boot: SPU: set region 6 as Secure\x0D\x0A
    2019-03-02T09:46:15.939Z DEBUG modem << Secure Boot: SPU: set region 7 as Secure\x0D\x0A
    2019-03-02T09:46:15.960Z DEBUG modem << Secure Boot: SPU: set Flash region 8 as Non-Secure\x0D\x0A
    2019-03-02T09:46:15.980Z DEBUG modem << Secure Boot: SPU: set Flash region 9 as Non-Secure\x0D\x0A
    2019-03-02T09:46:15.999Z DEBUG modem << Secure Boot: SPU: set Flash region 10 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.019Z DEBUG modem << Secure Boot: SPU: set Flash region 11 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.039Z DEBUG modem << Secure Boot: SPU: set Flash region 12 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.060Z DEBUG modem << Secure Boot: SPU: set Flash region 13 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.079Z DEBUG modem << Secure Boot: SPU: set Flash region 14 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.099Z DEBUG modem << Secure Boot: SPU: set Flash region 15 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.119Z DEBUG modem << Secure Boot: SPU: set Flash region 16 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.138Z DEBUG modem << Secure Boot: SPU: set Flash region 17 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.159Z DEBUG modem << Secure Boot: SPU: set Flash region 18 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.179Z DEBUG modem << Secure Boot: SPU: set Flash region 19 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.201Z DEBUG modem << Secure Boot: SPU: set Flash region 20 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.224Z DEBUG modem << Secure Boot: SPU: set Flash region 21 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.248Z DEBUG modem << Secure Boot: SPU: set Flash region 22 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.270Z DEBUG modem << Secure Boot: SPU: set Flash region 23 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.292Z DEBUG modem << Secure Boot: SPU: set Flash region 24 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.314Z DEBUG modem << Secure Boot: SPU: set Flash region 25 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.334Z DEBUG modem << Secure Boot: SPU: set Flash region 26 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.353Z DEBUG modem << Secure Boot: SPU: set Flash region 27 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.374Z DEBUG modem << Secure Boot: SPU: set Flash region 28 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.393Z DEBUG modem << Secure Boot: SPU: set Flash region 29 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.413Z DEBUG modem << Secure Boot: SPU: set Flash region 30 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.435Z DEBUG modem << Secure Boot: SPU: set Flash region 31 as Non-Secure\x0D\x0A
    2019-03-02T09:46:16.454Z DEBUG modem << Secure Boot: configure SRAM\x0D\x0A
    2019-03-02T09:46:16.474Z DEBUG modem << Secure Boot: SPU: set SRAM region 0 as Secure\x0D\x0A
    2019-03-02T09:46:16.496Z DEBUG modem << Secure Boot: SPU: set SRAM region 1 as Secure\x0D\x0A
    LED3 and LED4 are OFF
    Is it correct for SecureBoot?
