Unable to build documentation for Connect SDK
I tried to build the Connect SDK documentation according to the guide: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/doc_build.html
I did this on Windows 7 and also on Ubuntu (18.04.2 LTS) none of them did succeed.
(The SDK itself is set up correctly, I'm able to build and flash samples (e.g. at_client).
I did all the stuff described in chapter "Before you start". When I do step 7 of "Building documentation output", the following error occurs in the terminal (see terminal output below).
fabian@fabian-OptiPlex-980:~/Documents/nrfprojects/ncs/nrf/doc/_build$ ninja nrf
[1/4] cd /home/fabian/Documents/nrfprojects/ncs/nrf/doc/nrf && /home/fabian/bin/cmake-3.13.1-Linux-x86_6...uild/nrf/rst/doc/nrf *.rst:include:/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/rst/doc/nrf
File not found: /images/ndef_msg.svg
  referenced by: /home/fabian/Documents/nrfprojects/ncs/nrf/include/nfc/ndef/nfc.rst
File not found: /images/ndef_header_flags.svg
[2/4] cd /home/fabian/Documents/nrfprojects/ncs/nrf/doc && /home/fabian/bin/cmake-3.13.1-Linux-x86_64/bi...nrf/Kconfig.nrf /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/rst/doc/nrf/reference/kconfig/
warning: the int symbol BLECTLR_PRIO (defined at subsys/bluetooth/controller/Kconfig:3) has a non-int default BT_RX_PRIO (undefined)
warning: the int symbol BT_GATT_HIDS_MAX_CLIENT_COUNT (defined at subsys/bluetooth/services/Kconfig.hids:9) has a non-int range [1 (undefined), BT_MAX_CONN (undefined)]
warning: the int symbol MQTT_SOCKET_LOG_LEVEL (defined at /home/fabian/Documents/nrfprojects/ncs/zephyr/subsys/net/Kconfig.template.log_config.net:50) has a non-int default LOG_DEFAULT_LEVEL (undefined)
warning: the int symbol AT_HOST_THREAD_PRIO (defined at lib/at_host/Kconfig:66) has a non-int range [0 (undefined), NUM_PREEMPT_PRIORITIES (undefined)]
warning: the int symbol ETH_RTT_LOG_LEVEL (defined at /home/fabian/Documents/nrfprojects/ncs/zephyr/subsys/net/Kconfig.template.log_config.net:50) has a non-int default LOG_DEFAULT_LEVEL (undefined)
warning: <choice BT_LL_CHOICE> (defined at ../nrfxlib/ble_controller/Kconfig:10) defined without a prompt
[4/4] cd /home/fabian/Documents/nrfprojects/ncs/nrf/doc && /home/fabian/bin/cmake-3.13.1-Linux-x86_64/bi...rfprojects/ncs/nrf/doc/static/html/index.html /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/html
FAILED: CMakeFiles/nrf-html
cd /home/fabian/Documents/nrfprojects/ncs/nrf/doc && /home/fabian/bin/cmake-3.13.1-Linux-x86_64/bin/cmake -E env ZEPHYR_BUILD=/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/zephyr ZEPHYR_OUTPUT=/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/html/zephyr NRF_BASE=/home/fabian/Documents/nrfprojects/ncs/nrf NRF_BUILD=/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf NRF_OUTPUT=/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/html/nrf NRF_RST_SRC=/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/rst/doc/nrf MCUBOOT_OUTPUT=/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/html/mcuboot NRFXLIB_OUTPUT=/home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/html/nrfxlib /home/fabian/.local/bin/sphinx-build -w /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/sphinx.log -N -b html -d /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/doctrees /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/rst/doc/nrf /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/html/nrf && /home/fabian/bin/cmake-3.13.1-Linux-x86_64/bin/cmake -P /home/fabian/Documents/nrfprojects/ncs/zephyr/cmake/util/fmerge.cmake /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/doc.log /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/doxy.log /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/nrf/sphinx.log && /home/fabian/bin/cmake-3.13.1-Linux-x86_64/bin/cmake -E copy /home/fabian/Documents/nrfprojects/ncs/nrf/doc/static/html/index.html /home/fabian/Documents/nrfprojects/ncs/nrf/doc/_build/html
Running Sphinx v1.8.4
loading intersphinx inventory from ../../../../html/zephyr/objects.inv...
loading intersphinx inventory from ../../../../html/mcuboot/objects.inv...
loading intersphinx inventory from ../../../../html/nrfxlib/objects.inv...
building [mo]: targets for 0 po files that are out of date
building [html]: targets for 435 source files that are out of date
updating environment: 435 added, 0 changed, 0 removed
reading sources... [  0%] applications
reading sources... [  0%] applications/asset_tracker/README
reading sources... [  0%] doc/changelog
reading sources... [  0%] doc/release-notes-0.1.0
reading sources... [  1%] doc/release-notes-0.3.0
reading sources... [  1%] doc_build
reading sources... [  1%] doc_styleguide
reading sources... [  1%] doc_templates
reading sources... [  2%] documentation
reading sources... [  2%] examples
reading sources... [  2%] getting_started
reading sources... [  2%] gs_ins_fork
reading sources... [  2%] gs_ins_linux
reading sources... [  3%] gs_ins_os
reading sources... [  3%] gs_ins_windows
reading sources... [  3%] gs_installing
reading sources... [  3%] gs_programming
reading sources... [  4%] gs_testing
reading sources... [  4%] include/bluetooth/conn_ctx
reading sources... [  4%] include/bluetooth/gatt_dm
reading sources... [  4%] include/bluetooth/gatt_pool
reading sources... [  5%] include/bluetooth/scan
reading sources... [  5%] include/bluetooth/services/hids
reading sources... [  5%] include/bluetooth/services/hids_c
reading sources... [  5%] include/bluetooth/services/nus
reading sources... [  5%] include/bluetooth/services/nus_c
reading sources... [  6%] include/bluetooth/services/throughput
reading sources... [  6%] include/dk_buttons_and_leds
reading sources... [  6%] include/nfc/ndef/nfc
reading sources... [  6%] include/nfc/ndef/nfc_ndef
reading sources... [  7%] include/nfc/ndef/nfc_text
reading sources... [  7%] include/nfc/ndef/nfc_uri
reading sources... [  7%] include/nrf_cloud
reading sources... [  7%] include/nrf_esb
reading sources... [  8%] index
reading sources... [  8%] introduction
reading sources... [  8%] libraries
reading sources... [  8%] mcuboot
reading sources... [  8%] nrfxlib
reading sources... [  9%] reference/kconfig/CONFIG_AT_HOST_LIBRARY
reading sources... [  9%] reference/kconfig/CONFIG_AT_HOST_SOCKET_BUF_SIZE
reading sources... [  9%] reference/kconfig/CONFIG_AT_HOST_TERMINATION
reading sources... [  9%] reference/kconfig/CONFIG_AT_HOST_THREAD_PRIO
reading sources... [ 10%] reference/kconfig/CONFIG_AT_HOST_UART
reading sources... [ 10%] reference/kconfig/CONFIG_AT_HOST_UART_0
reading sources... [ 10%] reference/kconfig/CONFIG_AT_HOST_UART_1
reading sources... [ 10%] reference/kconfig/CONFIG_AT_HOST_UART_2
reading sources... [ 11%] reference/kconfig/CONFIG_AT_HOST_UART_BUF_SIZE
reading sources... [ 11%] reference/kconfig/CONFIG_BLECTLR_PRIO
reading sources... [ 11%] reference/kconfig/CONFIG_BLECTLR_RX_STACK_SIZE
reading sources... [ 11%] reference/kconfig/CONFIG_BLECTLR_SIGNAL_STACK_SIZE
reading sources... [ 11%] reference/kconfig/CONFIG_BLE_CONTROLLER_S112
reading sources... [ 12%] reference/kconfig/CONFIG_BLE_CONTROLLER_S132
reading sources... [ 12%] reference/kconfig/CONFIG_BLE_CONTROLLER_S140
reading sources... [ 12%] reference/kconfig/CONFIG_BSD_LIB
reading sources... [ 12%] reference/kconfig/CONFIG_BSD_LIBRARY
reading sources... [ 13%] reference/kconfig/CONFIG_BSD_LIBRARY_TRACE_ENABLED
reading sources... [ 13%] reference/kconfig/CONFIG_BT_CONN_CTX
reading sources... [ 13%] reference/kconfig/CONFIG_BT_CONN_CTX_LOG_LEVEL
reading sources... [ 13%] reference/kconfig/CONFIG_BT_CONN_CTX_LOG_LEVEL_DBG
reading sources... [ 14%] reference/kconfig/CONFIG_BT_CONN_CTX_LOG_LEVEL_ERR
reading sources... [ 14%] reference/kconfig/CONFIG_BT_CONN_CTX_LOG_LEVEL_INF
reading sources... [ 14%] reference/kconfig/CONFIG_BT_CONN_CTX_LOG_LEVEL_OFF
reading sources... [ 14%] reference/kconfig/CONFIG_BT_CONN_CTX_LOG_LEVEL_WRN
reading sources... [ 14%] reference/kconfig/CONFIG_BT_CONN_CTX_MEM_BUF_ALIGN
reading sources... [ 15%] reference/kconfig/CONFIG_BT_GATT_CCC_POOL_SIZE
reading sources... [ 15%] reference/kconfig/CONFIG_BT_GATT_CHRC_POOL_SIZE
reading sources... [ 15%] reference/kconfig/CONFIG_BT_GATT_DM
reading sources... [ 15%] reference/kconfig/CONFIG_BT_GATT_DM_DATA_PRINT
reading sources... [ 16%] reference/kconfig/CONFIG_BT_GATT_DM_LOG_LEVEL
reading sources... [ 16%] reference/kconfig/CONFIG_BT_GATT_DM_LOG_LEVEL_DBG
reading sources... [ 16%] reference/kconfig/CONFIG_BT_GATT_DM_LOG_LEVEL_ERR
reading sources... [ 16%] reference/kconfig/CONFIG_BT_GATT_DM_LOG_LEVEL_INF
reading sources... [ 17%] reference/kconfig/CONFIG_BT_GATT_DM_LOG_LEVEL_OFF
reading sources... [ 17%] reference/kconfig/CONFIG_BT_GATT_DM_LOG_LEVEL_WRN
reading sources... [ 17%] reference/kconfig/CONFIG_BT_GATT_DM_MAX_ATTRS
reading sources... [ 17%] reference/kconfig/CONFIG_BT_GATT_DM_MAX_MEM_CHUNKS
reading sources... [ 17%] reference/kconfig/CONFIG_BT_GATT_HIDS
reading sources... [ 18%] reference/kconfig/CONFIG_BT_GATT_HIDS_ATTR_MAX
reading sources... [ 18%] reference/kconfig/CONFIG_BT_GATT_HIDS_C
reading sources... [ 18%] reference/kconfig/CONFIG_BT_GATT_HIDS_C_LOG_LEVEL
reading sources... [ 18%] reference/kconfig/CONFIG_BT_GATT_HIDS_C_LOG_LEVEL_DBG
reading sources... [ 19%] reference/kconfig/CONFIG_BT_GATT_HIDS_C_LOG_LEVEL_ERR
reading sources... [ 19%] reference/kconfig/CONFIG_BT_GATT_HIDS_C_LOG_LEVEL_INF
reading sources... [ 19%] reference/kconfig/CONFIG_BT_GATT_HIDS_C_LOG_LEVEL_OFF
reading sources... [ 19%] reference/kconfig/CONFIG_BT_GATT_HIDS_C_LOG_LEVEL_WRN
reading sources... [ 20%] reference/kconfig/CONFIG_BT_GATT_HIDS_C_REPORTS_MAX
reading sources... [ 20%] reference/kconfig/CONFIG_BT_GATT_HIDS_FEATURE_REP_MAX
reading sources... [ 20%] reference/kconfig/CONFIG_BT_GATT_HIDS_INPUT_REP_MAX
reading sources... [ 20%] reference/kconfig/CONFIG_BT_GATT_HIDS_LOG_LEVEL
reading sources... [ 20%] reference/kconfig/CONFIG_BT_GATT_HIDS_LOG_LEVEL_DBG
reading sources... [ 21%] reference/kconfig/CONFIG_BT_GATT_HIDS_LOG_LEVEL_ERR
reading sources... [ 21%] reference/kconfig/CONFIG_BT_GATT_HIDS_LOG_LEVEL_INF
reading sources... [ 21%] reference/kconfig/CONFIG_BT_GATT_HIDS_LOG_LEVEL_OFF
reading sources... [ 21%] reference/kconfig/CONFIG_BT_GATT_HIDS_LOG_LEVEL_WRN
reading sources... [ 22%] reference/kconfig/CONFIG_BT_GATT_HIDS_MAX_CLIENT_COUNT
reading sources... [ 22%] reference/kconfig/CONFIG_BT_GATT_HIDS_OUTPUT_REP_MAX
reading sources... [ 22%] reference/kconfig/CONFIG_BT_GATT_LBS
reading sources... [ 22%] reference/kconfig/CONFIG_BT_GATT_LBS_POLL_BUTTON
reading sources... [ 22%] reference/kconfig/CONFIG_BT_GATT_NUS
reading sources... [ 23%] reference/kconfig/CONFIG_BT_GATT_NUS_C
reading sources... [ 23%] reference/kconfig/CONFIG_BT_GATT_NUS_C_LOG_LEVEL
reading sources... [ 23%] reference/kconfig/CONFIG_BT_GATT_NUS_C_LOG_LEVEL_DBG
reading sources... [ 23%] reference/kconfig/CONFIG_BT_GATT_NUS_C_LOG_LEVEL_ERR
reading sources... [ 24%] reference/kconfig/CONFIG_BT_GATT_NUS_C_LOG_LEVEL_INF
reading sources... [ 24%] reference/kconfig/CONFIG_BT_GATT_NUS_C_LOG_LEVEL_OFF
reading sources... [ 24%] reference/kconfig/CONFIG_BT_GATT_NUS_C_LOG_LEVEL_WRN
reading sources... [ 24%] reference/kconfig/CONFIG_BT_GATT_POOL
reading sources... [ 25%] reference/kconfig/CONFIG_BT_GATT_POOL_STATS
reading sources... [ 25%] reference/kconfig/CONFIG_BT_GATT_THROUGHPUT
reading sources... [ 25%] reference/kconfig/CONFIG_BT_GATT_UUID128_POOL_SIZE
reading sources... [ 25%] reference/kconfig/CONFIG_BT_GATT_UUID16_POOL_SIZE
reading sources... [ 25%] reference/kconfig/CONFIG_BT_GATT_UUID32_POOL_SIZE
reading sources... [ 26%] reference/kconfig/CONFIG_BT_LL_NRFXLIB
reading sources... [ 26%] reference/kconfig/CONFIG_BT_SCAN
reading sources... [ 26%] reference/kconfig/CONFIG_BT_SCAN_ADDRESS_CNT
reading sources... [ 26%] reference/kconfig/CONFIG_BT_SCAN_APPEARANCE_CNT
reading sources... [ 27%] reference/kconfig/CONFIG_BT_SCAN_FILTER_ENABLE
reading sources... [ 27%] reference/kconfig/CONFIG_BT_SCAN_LOG_LEVEL
reading sources... [ 27%] reference/kconfig/CONFIG_BT_SCAN_LOG_LEVEL_DBG
reading sources... [ 27%] reference/kconfig/CONFIG_BT_SCAN_LOG_LEVEL_ERR
reading sources... [ 28%] reference/kconfig/CONFIG_BT_SCAN_LOG_LEVEL_INF
reading sources... [ 28%] reference/kconfig/CONFIG_BT_SCAN_LOG_LEVEL_OFF
reading sources... [ 28%] reference/kconfig/CONFIG_BT_SCAN_LOG_LEVEL_WRN
reading sources... [ 28%] reference/kconfig/CONFIG_BT_SCAN_NAME_CNT
reading sources... [ 28%] reference/kconfig/CONFIG_BT_SCAN_NAME_MAX_LEN
reading sources... [ 29%] reference/kconfig/CONFIG_BT_SCAN_SHORT_NAME_CNT
reading sources... [ 29%] reference/kconfig/CONFIG_BT_SCAN_SHORT_NAME_MAX_LEN
reading sources... [ 29%] reference/kconfig/CONFIG_BT_SCAN_UUID_CNT
reading sources... [ 29%] reference/kconfig/CONFIG_CJSON_LIB
reading sources... [ 30%] reference/kconfig/CONFIG_CR_LF_TERMINATION
reading sources... [ 30%] reference/kconfig/CONFIG_CR_TERMINATION
reading sources... [ 30%] reference/kconfig/CONFIG_CUSTOM_DTS_OVERLAY_CMAKE_FILE
reading sources... [ 30%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_EVENT_LOG_BUF_LEN
reading sources... [ 31%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_LOG_LEVEL
reading sources... [ 31%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_LOG_LEVEL_DBG
reading sources... [ 31%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_LOG_LEVEL_ERR
reading sources... [ 31%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_LOG_LEVEL_INF
reading sources... [ 31%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_LOG_LEVEL_OFF
reading sources... [ 32%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_LOG_LEVEL_WRN
reading sources... [ 32%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_MAX_EVENT_CNT
reading sources... [ 32%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_PROFILER_ENABLED
reading sources... [ 32%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_PROFILE_EVENT_DATA
reading sources... [ 33%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_SHOW_EVENTS
reading sources... [ 33%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_SHOW_EVENT_HANDLERS
reading sources... [ 33%] reference/kconfig/CONFIG_DESKTOP_EVENT_MANAGER_TRACE_EVENT_EXECUTION
reading sources... [ 33%] reference/kconfig/CONFIG_DK_LIBRARY
reading sources... [ 34%] reference/kconfig/CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL
reading sources... [ 34%] reference/kconfig/CONFIG_DK_LIBRARY_INVERT_BUTTONS
reading sources... [ 34%] reference/kconfig/CONFIG_DK_LIBRARY_INVERT_LEDS
reading sources... [ 34%] reference/kconfig/CONFIG_DK_LIBRARY_LOG_LEVEL
reading sources... [ 34%] reference/kconfig/CONFIG_DK_LIBRARY_LOG_LEVEL_DBG
reading sources... [ 35%] reference/kconfig/CONFIG_DK_LIBRARY_LOG_LEVEL_ERR
reading sources... [ 35%] reference/kconfig/CONFIG_DK_LIBRARY_LOG_LEVEL_INF
reading sources... [ 35%] reference/kconfig/CONFIG_DK_LIBRARY_LOG_LEVEL_OFF
reading sources... [ 35%] reference/kconfig/CONFIG_DK_LIBRARY_LOG_LEVEL_WRN
reading sources... [ 36%] reference/kconfig/CONFIG_ETH_POLL_ACTIVE_PERIOD_MS
reading sources... [ 36%] reference/kconfig/CONFIG_ETH_POLL_PERIOD_MS
reading sources... [ 36%] reference/kconfig/CONFIG_ETH_RTT
reading sources... [ 36%] reference/kconfig/CONFIG_ETH_RTT_CHANNEL
reading sources... [ 37%] reference/kconfig/CONFIG_ETH_RTT_DEBUG_HEX_DUMP
reading sources... [ 37%] reference/kconfig/CONFIG_ETH_RTT_DOWN_BUFFER_SIZE
reading sources... [ 37%] reference/kconfig/CONFIG_ETH_RTT_DRV_NAME
reading sources... [ 37%] reference/kconfig/CONFIG_ETH_RTT_LOG_LEVEL
reading sources... [ 37%] reference/kconfig/CONFIG_ETH_RTT_LOG_LEVEL_DBG
reading sources... [ 38%] reference/kconfig/CONFIG_ETH_RTT_LOG_LEVEL_DEFAULT
reading sources... [ 38%] reference/kconfig/CONFIG_ETH_RTT_LOG_LEVEL_ERR
reading sources... [ 38%] reference/kconfig/CONFIG_ETH_RTT_LOG_LEVEL_INF
reading sources... [ 38%] reference/kconfig/CONFIG_ETH_RTT_LOG_LEVEL_OFF
reading sources... [ 39%] reference/kconfig/CONFIG_ETH_RTT_LOG_LEVEL_WRN
reading sources... [ 39%] reference/kconfig/CONFIG_ETH_RTT_MAC_ADDR
reading sources... [ 39%] reference/kconfig/CONFIG_ETH_RTT_MTU
reading sources... [ 39%] reference/kconfig/CONFIG_ETH_RTT_UP_BUFFER_SIZE
reading sources... [ 40%] reference/kconfig/CONFIG_EVENT_MANAGER
reading sources... [ 40%] reference/kconfig/CONFIG_GPS_SIM
reading sources... [ 40%] reference/kconfig/CONFIG_GPS_SIM_BASE_LATITUDE
reading sources... [ 40%] reference/kconfig/CONFIG_GPS_SIM_BASE_LONGITUDE
reading sources... [ 40%] reference/kconfig/CONFIG_GPS_SIM_BASE_TIMESTAMP
reading sources... [ 41%] reference/kconfig/CONFIG_GPS_SIM_DEV_NAME
reading sources... [ 41%] reference/kconfig/CONFIG_GPS_SIM_DYNAMIC_VALUES
reading sources... [ 41%] reference/kconfig/CONFIG_GPS_SIM_ELLIPSOID
reading sources... [ 41%] reference/kconfig/CONFIG_GPS_SIM_FIX_TIME
reading sources... [ 42%] reference/kconfig/CONFIG_GPS_SIM_GPIO_CONTROLLER
reading sources... [ 42%] reference/kconfig/CONFIG_GPS_SIM_GPIO_PIN
reading sources... [ 42%] reference/kconfig/CONFIG_GPS_SIM_LOG_LEVEL
reading sources... [ 42%] reference/kconfig/CONFIG_GPS_SIM_LOG_LEVEL_DBG
reading sources... [ 42%] reference/kconfig/CONFIG_GPS_SIM_LOG_LEVEL_ERR
reading sources... [ 43%] reference/kconfig/CONFIG_GPS_SIM_LOG_LEVEL_INF
reading sources... [ 43%] reference/kconfig/CONFIG_GPS_SIM_LOG_LEVEL_OFF
reading sources... [ 43%] reference/kconfig/CONFIG_GPS_SIM_LOG_LEVEL_WRN
reading sources... [ 43%] reference/kconfig/CONFIG_GPS_SIM_MAX_STEP
reading sources... [ 44%] reference/kconfig/CONFIG_GPS_SIM_PSEUDO_RANDOM
reading sources... [ 44%] reference/kconfig/CONFIG_GPS_SIM_THREAD_PRIORITY
reading sources... [ 44%] reference/kconfig/CONFIG_GPS_SIM_THREAD_STACK_SIZE
reading sources... [ 44%] reference/kconfig/CONFIG_GPS_SIM_TRIGGER
reading sources... [ 45%] reference/kconfig/CONFIG_GPS_SIM_TRIGGER_TIMER_MSEC
reading sources... [ 45%] reference/kconfig/CONFIG_GPS_SIM_TRIGGER_USE_BUTTON
reading sources... [ 45%] reference/kconfig/CONFIG_GPS_SIM_TRIGGER_USE_TIMER
reading sources... [ 45%] reference/kconfig/CONFIG_LF_TERMINATION
reading sources... [ 45%] reference/kconfig/CONFIG_LTE_AUTO_INIT_AND_CONNECT
reading sources... [ 46%] reference/kconfig/CONFIG_LTE_EDRX_REQ
reading sources... [ 46%] reference/kconfig/CONFIG_LTE_EDRX_REQ_ACTT_TYPE
reading sources... [ 46%] reference/kconfig/CONFIG_LTE_EDRX_REQ_VALUE
reading sources... [ 46%] reference/kconfig/CONFIG_LTE_LINK_CONTROL
reading sources... [ 47%] reference/kconfig/CONFIG_LTE_LINK_CONTROL_LOG_LEVEL
reading sources... [ 47%] reference/kconfig/CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG
reading sources... [ 47%] reference/kconfig/CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR
reading sources... [ 47%] reference/kconfig/CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF
reading sources... [ 48%] reference/kconfig/CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF
reading sources... [ 48%] reference/kconfig/CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN
reading sources... [ 48%] reference/kconfig/CONFIG_LTE_LOCK_BANDS
reading sources... [ 48%] reference/kconfig/CONFIG_LTE_PSM_REQ_RAT
reading sources... [ 48%] reference/kconfig/CONFIG_LTE_PSM_REQ_RPTAU
reading sources... [ 49%] reference/kconfig/CONFIG_MAX_LENGTH_OF_CUSTOM_EVENTS_DESCRIPTIONS
reading sources... [ 49%] reference/kconfig/CONFIG_MAX_NUMBER_OF_CUSTOM_EVENTS
reading sources... [ 49%] reference/kconfig/CONFIG_MQTT_KEEPALIVE
reading sources... [ 49%] reference/kconfig/CONFIG_MQTT_LIB_TLS
reading sources... [ 50%] reference/kconfig/CONFIG_MQTT_MAX_CLIENTS
reading sources... [ 50%] reference/kconfig/CONFIG_MQTT_MAX_PACKET_LENGTH
reading sources... [ 50%] reference/kconfig/CONFIG_MQTT_SOCKET_LIB
reading sources... [ 50%] reference/kconfig/CONFIG_MQTT_SOCKET_LOG_LEVEL
reading sources... [ 51%] reference/kconfig/CONFIG_MQTT_SOCKET_LOG_LEVEL_DBG
reading sources... [ 51%] reference/kconfig/CONFIG_MQTT_SOCKET_LOG_LEVEL_DEFAULT
reading sources... [ 51%] reference/kconfig/CONFIG_MQTT_SOCKET_LOG_LEVEL_ERR
reading sources... [ 51%] reference/kconfig/CONFIG_MQTT_SOCKET_LOG_LEVEL_INF
reading sources... [ 51%] reference/kconfig/CONFIG_MQTT_SOCKET_LOG_LEVEL_OFF
reading sources... [ 52%] reference/kconfig/CONFIG_MQTT_SOCKET_LOG_LEVEL_WRN
reading sources... [ 52%] reference/kconfig/CONFIG_NDEF_FILE_SIZE
reading sources... [ 52%] reference/kconfig/CONFIG_NFCT_IRQ_PRIORITY
reading sources... [ 52%] reference/kconfig/CONFIG_NFC_NDEF
reading sources... [ 53%] reference/kconfig/CONFIG_NFC_NDEF_MSG
reading sources... [ 53%] reference/kconfig/CONFIG_NFC_NDEF_MSG_WITH_NLEN
reading sources... [ 53%] reference/kconfig/CONFIG_NFC_NDEF_RECORD
reading sources... [ 53%] reference/kconfig/CONFIG_NFC_NDEF_TEXT_RECORD
reading sources... [ 54%] reference/kconfig/CONFIG_NFC_NDEF_URI_MSG
reading sources... [ 54%] reference/kconfig/CONFIG_NFC_NDEF_URI_REC
reading sources... [ 54%] reference/kconfig/CONFIG_NFC_PLATFORM_LOG_LEVEL
reading sources... [ 54%] reference/kconfig/CONFIG_NFC_PLATFORM_LOG_LEVEL_DBG
reading sources... [ 54%] reference/kconfig/CONFIG_NFC_PLATFORM_LOG_LEVEL_ERR
reading sources... [ 55%] reference/kconfig/CONFIG_NFC_PLATFORM_LOG_LEVEL_INF
reading sources... [ 55%] reference/kconfig/CONFIG_NFC_PLATFORM_LOG_LEVEL_OFF
reading sources... [ 55%] reference/kconfig/CONFIG_NFC_PLATFORM_LOG_LEVEL_WRN
reading sources... [ 55%] reference/kconfig/CONFIG_NFC_T2T_LIB_ENABLED
reading sources... [ 56%] reference/kconfig/CONFIG_NFC_T4T_LIB_ENABLED
reading sources... [ 56%] reference/kconfig/CONFIG_NRFXLIB_CRYPTO
reading sources... [ 56%] reference/kconfig/CONFIG_NRFXLIB_NFC
reading sources... [ 56%] reference/kconfig/CONFIG_NRF_CC310_BL
reading sources... [ 57%] reference/kconfig/CONFIG_NRF_CC310_BL_INTERRUPTS
reading sources... [ 57%] reference/kconfig/CONFIG_NRF_CLOUD
reading sources... [ 57%] reference/kconfig/CONFIG_NRF_CLOUD_CERTIFICATES_FILE
reading sources... [ 57%] reference/kconfig/CONFIG_NRF_CLOUD_HOST_NAME
reading sources... [ 57%] reference/kconfig/CONFIG_NRF_CLOUD_IPV6
reading sources... [ 58%] reference/kconfig/CONFIG_NRF_CLOUD_LOG
reading sources... [ 58%] reference/kconfig/CONFIG_NRF_CLOUD_LOG_LEVEL
reading sources... [ 58%] reference/kconfig/CONFIG_NRF_CLOUD_PORT
reading sources... [ 58%] reference/kconfig/CONFIG_NRF_CLOUD_PROVISION_CERTIFICATES
reading sources... [ 59%] reference/kconfig/CONFIG_NRF_CLOUD_SEC_TAG
reading sources... [ 59%] reference/kconfig/CONFIG_NRF_COAP_ACK_RANDOM_FACTOR
reading sources... [ 59%] reference/kconfig/CONFIG_NRF_COAP_ACK_TIMEOUT
reading sources... [ 59%] reference/kconfig/CONFIG_NRF_COAP_ENABLE_OBSERVE_CLIENT
reading sources... [ 60%] reference/kconfig/CONFIG_NRF_COAP_ENABLE_OBSERVE_SERVER
reading sources... [ 60%] reference/kconfig/CONFIG_NRF_COAP_LIB
reading sources... [ 60%] reference/kconfig/CONFIG_NRF_COAP_LOG_LEVEL
reading sources... [ 60%] reference/kconfig/CONFIG_NRF_COAP_MAX_NUMBER_OF_OPTIONS
reading sources... [ 60%] reference/kconfig/CONFIG_NRF_COAP_MAX_RETRANSMIT_COUNT
reading sources... [ 61%] reference/kconfig/CONFIG_NRF_COAP_MAX_TRANSMISSION_SPAN
reading sources... [ 61%] reference/kconfig/CONFIG_NRF_COAP_MESSAGE_DATA_MAX_SIZE
reading sources... [ 61%] reference/kconfig/CONFIG_NRF_COAP_MESSAGE_QUEUE_SIZE
reading sources... [ 61%] reference/kconfig/CONFIG_NRF_COAP_OBSERVE_MAX_NUM_OBSERVABLES
reading sources... [ 62%] reference/kconfig/CONFIG_NRF_COAP_OBSERVE_MAX_NUM_OBSERVERS
reading sources... [ 62%] reference/kconfig/CONFIG_NRF_COAP_PORT_COUNT
reading sources... [ 62%] reference/kconfig/CONFIG_NRF_COAP_RESOURCE_MAX_DEPTH
reading sources... [ 62%] reference/kconfig/CONFIG_NRF_COAP_RESOURCE_MAX_NAME_LEN
reading sources... [ 62%] reference/kconfig/CONFIG_NRF_COAP_SESSION_COUNT
reading sources... [ 63%] reference/kconfig/CONFIG_NRF_COAP_VERSION
reading sources... [ 63%] reference/kconfig/CONFIG_NRF_ESB
reading sources... [ 63%] reference/kconfig/CONFIG_NRF_ESB_ADDR_HANG_BUGFIX
reading sources... [ 63%] reference/kconfig/CONFIG_NRF_ESB_BUGFIX_TIMER0
reading sources... [ 64%] reference/kconfig/CONFIG_NRF_ESB_BUGFIX_TIMER1
reading sources... [ 64%] reference/kconfig/CONFIG_NRF_ESB_BUGFIX_TIMER2
reading sources... [ 64%] reference/kconfig/CONFIG_NRF_ESB_BUGFIX_TIMER3
reading sources... [ 64%] reference/kconfig/CONFIG_NRF_ESB_BUGFIX_TIMER4
reading sources... [ 65%] reference/kconfig/CONFIG_NRF_ESB_MAX_PAYLOAD_LENGTH
reading sources... [ 65%] reference/kconfig/CONFIG_NRF_ESB_PIPE_COUNT
reading sources... [ 65%] reference/kconfig/CONFIG_NRF_ESB_PPI_BUGFIX1
reading sources... [ 65%] reference/kconfig/CONFIG_NRF_ESB_PPI_BUGFIX2
reading sources... [ 65%] reference/kconfig/CONFIG_NRF_ESB_PPI_BUGFIX3
reading sources... [ 66%] reference/kconfig/CONFIG_NRF_ESB_PPI_RX_TIMEOUT
reading sources... [ 66%] reference/kconfig/CONFIG_NRF_ESB_PPI_TIMER_START
reading sources... [ 66%] reference/kconfig/CONFIG_NRF_ESB_PPI_TIMER_STOP
reading sources... [ 66%] reference/kconfig/CONFIG_NRF_ESB_PPI_TX_START
reading sources... [ 67%] reference/kconfig/CONFIG_NRF_ESB_RX_FIFO_SIZE
reading sources... [ 67%] reference/kconfig/CONFIG_NRF_ESB_SYS_TIMER0
reading sources... [ 67%] reference/kconfig/CONFIG_NRF_ESB_SYS_TIMER1
reading sources... [ 67%] reference/kconfig/CONFIG_NRF_ESB_SYS_TIMER2
reading sources... [ 68%] reference/kconfig/CONFIG_NRF_ESB_SYS_TIMER3
reading sources... [ 68%] reference/kconfig/CONFIG_NRF_ESB_SYS_TIMER4
reading sources... [ 68%] reference/kconfig/CONFIG_NRF_ESB_TX_FIFO_SIZE
reading sources... [ 68%] reference/kconfig/CONFIG_NRF_OBERON
reading sources... [ 68%] reference/kconfig/CONFIG_NULL_TERMINATION
reading sources... [ 69%] reference/kconfig/CONFIG_PROFILER
reading sources... [ 69%] reference/kconfig/CONFIG_PROFILER_CUSTOM_EVENT_BUF_LEN
reading sources... [ 69%] reference/kconfig/CONFIG_PROFILER_NORDIC
reading sources... [ 69%] reference/kconfig/CONFIG_PROFILER_NORDIC_COMMAND_BUFFER_SIZE
reading sources... [ 70%] reference/kconfig/CONFIG_PROFILER_NORDIC_DATA_BUFFER_SIZE
reading sources... [ 70%] reference/kconfig/CONFIG_PROFILER_NORDIC_INFO_BUFFER_SIZE
reading sources... [ 70%] reference/kconfig/CONFIG_PROFILER_NORDIC_RTT_CHANNEL_COMMANDS
reading sources... [ 70%] reference/kconfig/CONFIG_PROFILER_NORDIC_RTT_CHANNEL_DATA
reading sources... [ 71%] reference/kconfig/CONFIG_PROFILER_NORDIC_RTT_CHANNEL_INFO
reading sources... [ 71%] reference/kconfig/CONFIG_PROFILER_NORDIC_STACK_SIZE
reading sources... [ 71%] reference/kconfig/CONFIG_PROFILER_NORDIC_START_LOGGING_ON_SYSTEM_START
reading sources... [ 71%] reference/kconfig/CONFIG_PROFILER_NORDIC_THREAD_PRIORITY
reading sources... [ 71%] reference/kconfig/CONFIG_PROFILER_SYSVIEW
reading sources... [ 72%] reference/kconfig/CONFIG_SB_CRYPTO_ALGORITHM
reading sources... [ 72%] reference/kconfig/CONFIG_SB_CRYPTO_CC310_ECDSA_SECP256R1
reading sources... [ 72%] reference/kconfig/CONFIG_SB_CRYPTO_CC310_SHA256
reading sources... [ 72%] reference/kconfig/CONFIG_SB_CRYPTO_OBERON_ECDSA_SECP256R1
reading sources... [ 73%] reference/kconfig/CONFIG_SB_CRYPTO_OBERON_SHA256
reading sources... [ 73%] reference/kconfig/CONFIG_SB_CUSTOM_COMPATIBILITY_ID
reading sources... [ 73%] reference/kconfig/CONFIG_SB_C_RUNTIME_SETUP_VARIANT_CUSTOM
reading sources... [ 73%] reference/kconfig/CONFIG_SB_C_RUNTIME_SETUP_VARIANT_MDK
reading sources... [ 74%] reference/kconfig/CONFIG_SB_C_RUNTIME_SETUP_VARIANT_ZEPHYR
reading sources... [ 74%] reference/kconfig/CONFIG_SB_DEBUG_PORT_SEGGER_RTT
reading sources... [ 74%] reference/kconfig/CONFIG_SB_DEBUG_PORT_UART
reading sources... [ 74%] reference/kconfig/CONFIG_SB_DEBUG_PRINTF_BUF_LEN
reading sources... [ 74%] reference/kconfig/CONFIG_SB_ECDSA
reading sources... [ 75%] reference/kconfig/CONFIG_SB_FIRMWARE_INFO_OFFSET
reading sources... [ 75%] reference/kconfig/CONFIG_SB_FIRMWARE_VERSION
reading sources... [ 75%] reference/kconfig/CONFIG_SB_FLASH_PROTECT
reading sources... [ 75%] reference/kconfig/CONFIG_SB_HARDWARE_ID
reading sources... [ 76%] reference/kconfig/CONFIG_SB_HASH_LEN
reading sources... [ 76%] reference/kconfig/CONFIG_SB_INFO_VERSION
reading sources... [ 76%] reference/kconfig/CONFIG_SB_MAGIC_COMMON
reading sources... [ 76%] reference/kconfig/CONFIG_SB_MAGIC_FIRMWARE_INFO
reading sources... [ 77%] reference/kconfig/CONFIG_SB_MAGIC_LEN
reading sources... [ 77%] reference/kconfig/CONFIG_SB_MAGIC_POINTER
reading sources... [ 77%] reference/kconfig/CONFIG_SB_MAGIC_VALIDATION_INFO
reading sources... [ 77%] reference/kconfig/CONFIG_SB_PRIVATE_KEY_PROVIDED
reading sources... [ 77%] reference/kconfig/CONFIG_SB_PUBLIC_KEY_FILES
reading sources... [ 78%] reference/kconfig/CONFIG_SB_PUBLIC_KEY_HASH_LEN
reading sources... [ 78%] reference/kconfig/CONFIG_SB_PUBLIC_KEY_LEN
reading sources... [ 78%] reference/kconfig/CONFIG_SB_RSA
reading sources... [ 78%] reference/kconfig/CONFIG_SB_SEGGER_RTT_BUFFER_SIZE_DOWN
reading sources... [ 79%] reference/kconfig/CONFIG_SB_SEGGER_RTT_BUFFER_SIZE_UP
reading sources... [ 79%] reference/kconfig/CONFIG_SB_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS
reading sources... [ 79%] reference/kconfig/CONFIG_SB_SEGGER_RTT_MAX_NUM_UP_BUFFERS
reading sources... [ 79%] reference/kconfig/CONFIG_SB_SEGGER_RTT_MEMCPY_USE_BYTELOOP
reading sources... [ 80%] reference/kconfig/CONFIG_SB_SEGGER_RTT_MODE
reading sources... [ 80%] reference/kconfig/CONFIG_SB_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL
reading sources... [ 80%] reference/kconfig/CONFIG_SB_SEGGER_RTT_MODE_NO_BLOCK_SKIP
reading sources... [ 80%] reference/kconfig/CONFIG_SB_SEGGER_RTT_MODE_NO_BLOCK_TRIM
reading sources... [ 80%] reference/kconfig/CONFIG_SB_SEGGER_RTT_PRINTF_BUFFER_SIZE
reading sources... [ 81%] reference/kconfig/CONFIG_SB_SIGNATURE_LEN
reading sources... [ 81%] reference/kconfig/CONFIG_SB_SIGNING_COMMAND
reading sources... [ 81%] reference/kconfig/CONFIG_SB_SIGNING_CUSTOM
reading sources... [ 81%] reference/kconfig/CONFIG_SB_SIGNING_KEY_FILE
reading sources... [ 82%] reference/kconfig/CONFIG_SB_SIGNING_OPENSSL
reading sources... [ 82%] reference/kconfig/CONFIG_SB_SIGNING_PUBLIC_KEY
reading sources... [ 82%] reference/kconfig/CONFIG_SB_SIGNING_PYTHON
reading sources... [ 82%] reference/kconfig/CONFIG_SB_VALIDATION_METADATA_OFFSET
reading sources... [ 82%] reference/kconfig/CONFIG_SB_VENDOR_SYSTEM_INIT
reading sources... [ 83%] reference/kconfig/CONFIG_SECURE_BOOT
reading sources... [ 83%] reference/kconfig/CONFIG_SECURE_BOOT_CRYPTO
reading sources... [ 83%] reference/kconfig/CONFIG_SECURE_BOOT_DEBUG
reading sources... [ 83%] reference/kconfig/CONFIG_SENSOR
reading sources... [ 84%] reference/kconfig/CONFIG_SENSOR_SIM
reading sources... [ 84%] reference/kconfig/CONFIG_SENSOR_SIM_DEV_NAME
reading sources... [ 84%] reference/kconfig/CONFIG_SENSOR_SIM_DYNAMIC_VALUES
reading sources... [ 84%] reference/kconfig/CONFIG_SENSOR_SIM_LOG_LEVEL
reading sources... [ 85%] reference/kconfig/CONFIG_SENSOR_SIM_LOG_LEVEL_DBG
reading sources... [ 85%] reference/kconfig/CONFIG_SENSOR_SIM_LOG_LEVEL_ERR
reading sources... [ 85%] reference/kconfig/CONFIG_SENSOR_SIM_LOG_LEVEL_INF
reading sources... [ 85%] reference/kconfig/CONFIG_SENSOR_SIM_LOG_LEVEL_OFF
reading sources... [ 85%] reference/kconfig/CONFIG_SENSOR_SIM_LOG_LEVEL_WRN
reading sources... [ 86%] reference/kconfig/CONFIG_SENSOR_SIM_STATIC_VALUES
reading sources... [ 86%] reference/kconfig/CONFIG_SENSOR_SIM_THREAD_PRIORITY
reading sources... [ 86%] reference/kconfig/CONFIG_SENSOR_SIM_THREAD_STACK_SIZE
reading sources... [ 86%] reference/kconfig/CONFIG_SENSOR_SIM_TRIGGER
reading sources... [ 87%] reference/kconfig/CONFIG_SENSOR_SIM_TRIGGER_TIMER_MSEC
reading sources... [ 87%] reference/kconfig/CONFIG_SENSOR_SIM_TRIGGER_USE_BUTTON
reading sources... [ 87%] reference/kconfig/CONFIG_SENSOR_SIM_TRIGGER_USE_TIMER
reading sources... [ 87%] reference/kconfig/choice_0
reading sources... [ 88%] reference/kconfig/choice_1
reading sources... [ 88%] reference/kconfig/choice_10
reading sources... [ 88%] reference/kconfig/choice_11
reading sources... [ 88%] reference/kconfig/choice_12
reading sources... [ 88%] reference/kconfig/choice_13
reading sources... [ 89%] reference/kconfig/choice_14
reading sources... [ 89%] reference/kconfig/choice_15
reading sources... [ 89%] reference/kconfig/choice_16
reading sources... [ 89%] reference/kconfig/choice_17
reading sources... [ 90%] reference/kconfig/choice_18
reading sources... [ 90%] reference/kconfig/choice_19
reading sources... [ 90%] reference/kconfig/choice_2
reading sources... [ 90%] reference/kconfig/choice_20
reading sources... [ 91%] reference/kconfig/choice_21
reading sources... [ 91%] reference/kconfig/choice_22
reading sources... [ 91%] reference/kconfig/choice_23
reading sources... [ 91%] reference/kconfig/choice_24
reading sources... [ 91%] reference/kconfig/choice_25
reading sources... [ 92%] reference/kconfig/choice_26
reading sources... [ 92%] reference/kconfig/choice_27
reading sources... [ 92%] reference/kconfig/choice_28
reading sources... [ 92%] reference/kconfig/choice_29
reading sources... [ 93%] reference/kconfig/choice_3
reading sources... [ 93%] reference/kconfig/choice_4
reading sources... [ 93%] reference/kconfig/choice_5
reading sources... [ 93%] reference/kconfig/choice_8
reading sources... [ 94%] reference/kconfig/choice_9
reading sources... [ 94%] reference/kconfig/index
reading sources... [ 94%] release_notes
reading sources... [ 94%] samples
reading sources... [ 94%] samples/bluetooth/central_hids/README
reading sources... [ 95%] samples/bluetooth/central_uart/README
reading sources... [ 95%] samples/bluetooth/peripheral_hids_keyboard/README
reading sources... [ 95%] samples/bluetooth/peripheral_hids_mouse/README
reading sources... [ 95%] samples/bluetooth/peripheral_lbs/README
reading sources... [ 96%] samples/bluetooth/peripheral_uart/README
reading sources... [ 96%] samples/bluetooth/throughput/README
reading sources... [ 96%] samples/esb/README
reading sources... [ 96%] samples/nfc/record_text/README
reading sources... [ 97%] samples/nfc/writable_ndef_msg/README
reading sources... [ 97%] samples/nrf9160/coap_client/README
reading sources... [ 97%] samples/nrf9160/lte_ble_gateway/README
reading sources... [ 97%] samples/nrf9160/mqtt_simple/README
reading sources... [ 97%] samples/nrf9160/secure_boot/README
reading sources... [ 98%] samples/nrf_desktop/README
reading sources... [ 98%] templates/cheat_sheet
reading sources... [ 98%] templates/customservice_README
reading sources... [ 98%] templates/sample_README
reading sources... [ 99%] ug_bootloader
reading sources... [ 99%] ug_esb
reading sources... [ 99%] ug_nrf9160
reading sources... [ 99%] user_guides
reading sources... [100%] zephyr
looking for now-outdated files... none found
pickling environment... done
checking consistency... done
preparing documents... done
writing output... [  0%] applications
writing output... [  0%] applications/asset_tracker/README
writing output... [  0%] doc/changelog
writing output... [  0%] doc/release-notes-0.1.0
writing output... [  1%] doc/release-notes-0.3.0
writing output... [  1%] doc_build
writing output... [  1%] doc_styleguide
writing output... [  1%] doc_templates
writing output... [  2%] documentation
writing output... [  2%] examples
writing output... [  2%] getting_started
writing output... [  2%] gs_ins_fork
writing output... [  2%] gs_ins_linux
writing output... [  3%] gs_ins_os
writing output... [  3%] gs_ins_windows
writing output... [  3%] gs_installing
writing output... [  3%] gs_programming
writing output... [  4%] gs_testing
writing output... [  4%] include/bluetooth/conn_ctx
writing output... [  4%] include/bluetooth/gatt_dm
writing output... [  4%] include/bluetooth/gatt_pool
writing output... [  5%] include/bluetooth/scan
writing output... [  5%] include/bluetooth/services/hids
writing output... [  5%] include/bluetooth/services/hids_c
writing output... [  5%] include/bluetooth/services/nus
writing output... [  5%] include/bluetooth/services/nus_c
writing output... [  6%] include/bluetooth/services/throughput
writing output... [  6%] include/dk_buttons_and_leds
writing output... [  6%] include/nfc/ndef/nfc
writing output... [  6%] include/nfc/ndef/nfc_ndef
writing output... [  7%] include/nfc/ndef/nfc_text
writing output... [  7%] include/nfc/ndef/nfc_uri
writing output... [  7%] include/nrf_cloud
Exception occurred:
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinxcontrib/mscgen.py", line 78, in run_cmd
    if err.errno != getattr(errno, 'ENOEXEC', 0):
NameError: name 'errno' is not defined
The full traceback has been saved in /tmp/sphinx-err-waammrfs.log, if you want to report the issue to the developers.
Please also report this if it was a user error, so that a better error message can be provided next time.
A bug report can be filed in the tracker at <https://github.com/sphinx-doc/sphinx/issues>. Thanks!
The mentioned log-File at the end of the terminal ouptut is also attached.
# Sphinx version: 1.8.4
# Python version: 3.6.7 (CPython)
# Docutils version: 0.14
# Jinja2 version: 2.10
# Last messages:
#   writing output... [  6%] include/nfc/ndef/nfc
#   writing output... [  6%] include/nfc/ndef/nfc_ndef
#   writing output... [  7%] include/nfc/ndef/nfc_text
#   writing output... [  7%] include/nfc/ndef/nfc_uri
#   writing output... [  7%] include/nrf_cloud
# Loaded extensions:
#   sphinx.ext.mathjax (1.8.4) from /home/fabian/.local/lib/python3.6/site-packages/sphinx/ext/mathjax.py
#   alabaster (0.7.12) from /home/fabian/.local/lib/python3.6/site-packages/alabaster/__init__.py
#   sphinx.ext.intersphinx (1.8.4) from /home/fabian/.local/lib/python3.6/site-packages/sphinx/ext/intersphinx.py
#   breathe (4.9.1) from /home/fabian/.local/lib/python3.6/site-packages/breathe/__init__.py
#   sphinx.ext.ifconfig (1.8.4) from /home/fabian/.local/lib/python3.6/site-packages/sphinx/ext/ifconfig.py
#   sphinxcontrib.mscgen (unknown version) from /home/fabian/.local/lib/python3.6/site-packages/sphinxcontrib/mscgen.py
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinxcontrib/mscgen.py", line 75, in run_cmd
    p = Popen(cmd, stdout=PIPE, stdin=PIPE, stderr=PIPE)
  File "/usr/lib/python3.6/subprocess.py", line 709, in __init__
    restore_signals, start_new_session)
  File "/usr/lib/python3.6/subprocess.py", line 1344, in _execute_child
    raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'mscgen': 'mscgen'
During handling of the above exception, another exception occurred:
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/cmd/build.py", line 304, in build_main
    app.build(args.force_all, filenames)
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/application.py", line 341, in build
    self.builder.build_update()
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/builders/__init__.py", line 347, in build_update
    len(to_build))
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/builders/__init__.py", line 412, in build
    self.write(docnames, list(updated_docnames), method)
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/builders/__init__.py", line 593, in write
    self._write_serial(sorted(docnames))
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/builders/__init__.py", line 604, in _write_serial
    self.write_doc(docname, doctree)
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/builders/html.py", line 731, in write_doc
    self.docwriter.write(doctree, destination)
  File "/home/fabian/.local/lib/python3.6/site-packages/docutils/writers/__init__.py", line 80, in write
    self.translate()
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinx/writers/html.py", line 58, in translate
    self.document.walkabout(visitor)
  File "/home/fabian/.local/lib/python3.6/site-packages/docutils/nodes.py", line 174, in walkabout
    if child.walkabout(visitor):
  File "/home/fabian/.local/lib/python3.6/site-packages/docutils/nodes.py", line 166, in walkabout
    visitor.dispatch_visit(self)
  File "/home/fabian/.local/lib/python3.6/site-packages/docutils/nodes.py", line 1882, in dispatch_visit
    return method(node)
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinxcontrib/mscgen.py", line 195, in html_visit_mscgen
    render_msc_html(self, node, node['code'])
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinxcontrib/mscgen.py", line 170, in render_msc_html
    fname, outfn, id = render_msc(self, code, 'png', prefix)
  File "/home/fabian/.local/lib/python3.6/site-packages/sphinxcontrib/mscgen.py", line 154, in render_msc
    if not run_cmd(self.builder, mscgen_args, 'mscgen', 'mscgen', code):
Anyone an idea what is going wrong or what I'm possibly doing wrong?
Thanks for your help!
