The output report used for capslock LEDs is abnormal when I combine HID keyboard and mouse to one device(nrf52840, s140).
Hi guys, help me please.....
I want to build a device act like both keyboards and mouse. I've made some progress that the device can connect to my PC(win10) successfully and I can send keys to my PC, but there are two problems:
1, The output report is abnormal, when I get the report type in the callback function(on_hid_rep_char_write), I get 1(BLE_HIDS_REP_TYPE_INPUT)and it should be 2(BLE_HIDS_REP_TYPE_OUTPUT)。
2,I send a right-click action to PC but nothing happens.
My codes:
#include "HIDService.h"
#include "app_error.h"
#include "nrf_log.h"
#define BASE_USB_HID_SPEC_VERSION           0x0101                                     	/**< Version number of base USB HID Specification implemented by this application. */
#define MODIFIER_KEY_POS                    0                                          	/**< Position of the modifier byte in the Input Report. */
#define SCAN_CODE_POS                       2                                          	/**< The start position of the key scan code in a HID Report. */
#define INPUT_REPORT_KEYS_MAX_LEN           8                                          	/**< Maximum length of the Input Report characteristic. */
#define OUTPUT_REPORT_MAX_LEN               1                                          	/**< Maximum length of Output Report. */
bool              			m_in_boot_mode = false;  									/**< Current protocol mode. */
extern uint16_t 			m_conn_handle;												/**< Handle of the current connection. */
BLE_HIDS_DEF(m_hids,                                                					/**< Structure used to identify the HID service. */
             NRF_SDH_BLE_TOTAL_LINK_COUNT,
             INPUT_REPORT_KEYS_MAX_LEN,
             OUTPUT_REPORT_MAX_LEN,
			 4);
static uint8_t report_map_data[] = {
	0x05, 0x01,       // USAGE_PAGE (Generic Desktop)
	0x09, 0x06,       // USAGE (Keyboard)
	0xa1, 0x01,       // COLLECTION (Application)
	0x85, 0x01,       //   REPORT_ID (1)
	0x05, 0x07,       //   Usage page(Key Codes)
	0x19, 0xe0,       //   Usage Minimum (224)
	0x29, 0xe7,       //   Usage Maximum (231)
	0x15, 0x00,       //   Logical Minimum (0)
	0x25, 0x01,       //   Logical Maximum (1)
	0x95, 0x08,       //   Report Count (8)
	0x75, 0x01,       //   Report Size (1)
	0x81, 0x02,       //   Input (Data, Variable, Absolute)
	0x95, 0x01,       //   Report Count (1)
	0x75, 0x08,       //   Report Size (8)
	0x81, 0x01,       //   Input (Constant) reserved byte(1)
	0x05, 0x08,       //   Usage Page (Page for LEDs)
	0x19, 0x01,       //   Usage Minimum (1)
	0x29, 0x05,       //   Usage Maximum (5)
	0x95, 0x05,       //   Report Count (5)
	0x91, 0x02,       //   Output (Data, Variable, Absolute), Led report
	0x75, 0x03,       //   Report Size (3)
	0x91, 0x01,       //   Output (Data, Variable, Absolute), Led report padding
	0x05, 0x07,       //   Usage Page (Key codes)
	0x25, 0x65,       //   Logical Maximum (101)
	0x19, 0x00,       //   Usage Minimum (0)
	0x29, 0x65,       //   Usage Maximum (101)
	0x95, 0x06,       //   Report Count (6)
	0x81, 0x00,       //   Input (Data, Array) Key array(6 bytes)
	0x09, 0x05,       //   Usage (Vendor Defined)
	0x26, 0xFF, 0x00, //   Logical Maximum (255)
	0x75, 0x08,       //   Report Count (2)
	0x95, 0x02,       //   Report Size (8 bit)
	0xB1, 0x02,       //   Feature (Data, Variable, Absolute)
	0xc0,             // END_COLLECTION
	0x09, 0x02,       // USAGE (Mouse)
	0x85, 0x02,		  //   REPORT_ID (2)
	0x09, 0x01,       //   USAGE (Pointer)
	0xA1, 0x00,       //   COLLECTION (Physical)
	0x05, 0x09,       //     USAGE_PAGE (Button)
	0x19, 0x01,       //     USAGE_MINIMUM
	0x29, 0x03,       //     USAGE_MAXIMUM
	0x15, 0x00,       //     LOGICAL_MINIMUM (0)
	0x25, 0x01,       //     LOGICAL_MAXIMUM (1)
	0x95, 0x03,       //     REPORT_COUNT (3)
	0x75, 0x01,       //     REPORT_SIZE (1)
	0x81, 0x02,       //     INPUT (Data,Var,Abs)
	0x95, 0x01,       //     REPORT_COUNT (1)
	0x75, 0x05,       //     REPORT_SIZE (5)
	0x81, 0x03,       //     INPUT (Const,Var,Abs)
	0x09, 0x30,       //     USAGE (X)
	0x09, 0x31,       //     USAGE (Y)
	0x09, 0x38,       //     USAGE (Wheel)
	0x15, 0x81,       //     LOGICAL_MINIMUM (-127)
	0x25, 0x7F,       //     LOGICAL_MAXIMUM (127)
	0x75, 0x08,       //     REPORT_SIZE (8)
	0x81, 0x06,       //     INPUT (Data,Var,Rel)
	0xC0,             //   END_COLLECTION
	0xC0,             // END COLLECTION
/**@brief Function for handling the HID Report Characteristic Write event.
 * @param[in]   p_evt   HID service event.
static void on_hid_rep_char_write(ble_hids_evt_t * p_evt){
    if (p_evt->params.char_write.char_id.rep_type != BLE_HIDS_REP_TYPE_OUTPUT){
		//!!!!!!!!! should not enter this branch
		NRF_LOG_INFO("rep_type: %d", p_evt->params.char_write.char_id.rep_type);
		return;
	ret_code_t err_code;
    uint8_t  report_val;
    uint8_t  report_index = p_evt->params.char_write.char_id.rep_index;
    if (report_index != 1){
		NRF_LOG_INFO("report_index: %d", report_index);
		return;
    // This code assumes that the output report is one byte long. Hence the following
    // static assert is made.
    STATIC_ASSERT(OUTPUT_REPORT_MAX_LEN == 1);
	err_code = ble_hids_outp_rep_get(&m_hids, report_index, OUTPUT_REPORT_MAX_LEN, 0, m_conn_handle, &report_val);
    if (((report_val & 0x02) != 0)){
        NRF_LOG_INFO("Caps Lock is turned On!");
    }else{
		NRF_LOG_INFO("Caps Lock is turned Off!");
/**@brief Function for handling HID events.
 * @details This function will be called for all HID events which are passed to the application.
 * @param[in]   p_hids  HID service structure.
 * @param[in]   p_evt   Event received from the HID service.
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
            m_in_boot_mode = true;
        case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
        case BLE_HIDS_EVT_REP_CHAR_WRITE:
			on_hid_rep_char_write(p_evt);
        case BLE_HIDS_EVT_NOTIF_ENABLED:
            // No implementation needed.
/**@brief Function for handling Service errors.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for initializing HID Service.
void hid_init(void){
    ble_hids_init_t            hids_init_obj;
    ble_hids_inp_rep_init_t  * p_input_report;
    ble_hids_outp_rep_init_t * p_output_report;
    uint8_t                    hid_info_flags;
    static ble_hids_inp_rep_init_t  input_report_array[2];
    static ble_hids_outp_rep_init_t output_report_array[1];
    memset((void *)input_report_array, 0, sizeof(input_report_array));
    memset((void *)output_report_array, 0, sizeof(input_report_array));
    // Initialize HID Service
    p_input_report                      = &input_report_array[0];
    p_input_report->max_len             = 8;
    p_input_report->rep_ref.report_id   = 1;
    p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.write_perm);
    p_output_report                      = &output_report_array[0];
    p_output_report->max_len             = 1;
    p_output_report->rep_ref.report_id   = 1;
    p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.write_perm);
	p_input_report                      = &input_report_array[1];
    p_input_report->max_len             = 4;
    p_input_report->rep_ref.report_id   = 2;
    hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler                    = on_hids_evt;
    hids_init_obj.error_handler                  = service_error_handler;
    hids_init_obj.is_kb                          = true;
    hids_init_obj.is_mouse                       = true;
    hids_init_obj.inp_rep_count                  = 2;
    hids_init_obj.p_inp_rep_array                = input_report_array;
    hids_init_obj.outp_rep_count                 = 1;
    hids_init_obj.p_outp_rep_array               = output_report_array;
    hids_init_obj.feature_rep_count              = 0;
    hids_init_obj.p_feature_rep_array            = NULL;
    hids_init_obj.rep_map.data_len               = sizeof(report_map_data);
    hids_init_obj.rep_map.p_data                 = report_map_data;
    hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = hid_info_flags;
    hids_init_obj.included_services_count        = 0;
    hids_init_obj.p_included_services_array      = NULL;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.rep_map.security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.rep_map.security_mode.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.hid_information.security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.hid_information.security_mode.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_boot_kb_inp_rep.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.write_perm);
	BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_mouse_inp_rep.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_mouse_inp_rep.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_mouse_inp_rep.write_perm);
	BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_ctrl_point.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_ctrl_point.write_perm);
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
static void handle_hid_error(ret_code_t err_code){
	if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
		NRF_LOG_INFO("handle_hid_error err_code: %d", err_code);
        APP_ERROR_HANDLER(err_code);
void send_keys(uint8_t * p_keys, uint8_t size, uint8_t modifier){
    uint8_t  data[INPUT_REPORT_KEYS_MAX_LEN];
	ASSERT(size <= INPUT_REPORT_KEYS_MAX_LEN - SCAN_CODE_POS);
	memset(data, 0, sizeof(data));
	memcpy(data + SCAN_CODE_POS, p_keys, size);
	data[MODIFIER_KEY_POS] = modifier;
	if (m_in_boot_mode){
		err_code = ble_hids_boot_kb_inp_rep_send(&m_hids, INPUT_REPORT_KEYS_MAX_LEN, data, m_conn_handle);
	}else{
		err_code = ble_hids_inp_rep_send(&m_hids, 0, INPUT_REPORT_KEYS_MAX_LEN, data, m_conn_handle);
	handle_hid_error(err_code);
void send_mouse_movement(uint8_t btns, uint8_t x, uint8_t y, uint8_t wheel){
    uint8_t  data[4] = {btns, x, y, wheel};
	NRF_LOG_INFO("send_mouse_movement btns: %d, x: %d, y: %d, wheel:%d", btns, x, y, wheel);
		err_code = ble_hids_boot_mouse_inp_rep_send(&m_hids, btns, (int8_t)x, (int8_t)y, 0, NULL, m_conn_handle);
	}else{
		err_code = ble_hids_inp_rep_send(&m_hids, 1, 4, data, m_conn_handle);
void send_mouse_moving(uint8_t x, uint8_t y, uint8_t wheel){
	send_mouse_movement(0, x, y, wheel);
void send_mouse_btns(bool left_btn, bool right_btn, bool middle_btn){
	uint8_t state = 0x00;
	state = left_btn   ? (state + 0x01) : state;
	state = middle_btn ? (state + 0x02) : state;
	state = right_btn  ? (state + 0x04) : state;
	send_mouse_movement(state, 0, 0, 0);
void test_hid_send_keys(uint8_t key){
	NRF_LOG_INFO("send key begin");
	send_keys(&key, 1, 0x00);
	send_keys(NULL, 0, 0x00);
	NRF_LOG_INFO("send key end");
	//this test succeed.
void test_hid_send_mouse(void){
	NRF_LOG_INFO("send mouse begin");
	send_mouse_btns(false, true, false);
	send_mouse_btns(false, false, false);
	NRF_LOG_INFO("send mouse end");
	//this test failed, nothing happens in PC.
Thanks!
