SAADC Offset Calibration errors and input resistance
nrf52832.
SDK14.2
Segger ES V3.34a
With an initial prototype batch of 30, we have noticed 4 modules that have incorrect voltage readings, reading low ("Bad Modules").
Normally we implement the calibration routine for the offset, but found when we disabled this routine the 4 low reading parts improved in performance, but still had errors.  This lead to debugging and capturing the ADC readings with/without the calibration routine enabled and comparing bad modules with good modules.
We noted the ADC Counts from three of the ADC pins  An0, An1, An2
On the bad module we noticed the following.
The calibration offset was made worse by ~300 steps after calibration.
The input impedance w.r.t 0V for Ain0 was lower on a bad module which affected the potential divider reading.
 Ain2 s/c to 0V had a greater negative offset to start with compared with a good module, (prior to calibration)
Settings on both modules
//set configuration for saadc channel 0
channel_0_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
channel_0_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
channel_0_config.gain = NRF_SAADC_GAIN1_5;
channel_0_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
channel_0_config.acq_time = NRF_SAADC_ACQTIME_3US;
channel_0_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;
channel_0_config.pin_p = (nrf_saadc_input_t)(NRF_SAADC_INPUT_AIN0);
channel_0_config.pin_n = NRF_SAADC_INPUT_DISABLED;
//set configuration for saadc channel 1
channel_1_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
channel_1_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
channel_1_config.gain = NRF_SAADC_GAIN1_5;
channel_1_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
channel_1_config.acq_time = NRF_SAADC_ACQTIME_3US;
channel_1_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;
channel_1_config.pin_p = (nrf_saadc_input_t)(NRF_SAADC_INPUT_AIN1);
channel_1_config.pin_n = NRF_SAADC_INPUT_DISABLED;
//set configuration for saadc channel 2
channel_2_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
channel_2_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
channel_2_config.gain = NRF_SAADC_GAIN1_5;
channel_2_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
channel_2_config.acq_time = NRF_SAADC_ACQTIME_3US;
channel_2_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;
channel_2_config.pin_p = (nrf_saadc_input_t)(NRF_SAADC_INPUT_AIN2);
channel_2_config.pin_n = NRF_SAADC_INPUT_DISABLED;
//Configure SAADC
/saadc_config.low_power_mode = False; //Disable low power mode.
saadc_config.resolution = NRF_SAADC_RESOLUTION_14BIT; //Set SAADC resolution to 14-bit.
saadc_config.oversample = NRF_SAADC_OVERSAMPLE_32X; //Set oversample to 32x.
We are using 0.1% resisters for the p.d.
Ain0 - p.d with 82.5K and 7.5K
Ain1 - LM61
An2 - 100K pull down to 0V
Results
Applied voltage constant to Ain0 and Ain1  'with and without' calibration for comparison
Bad module -
Ain                        No CAL                                          WITH  CAL                       DIFF
0                            5857                                                   5532                            -325
1                            4714                                                   4438                            -276
2                            -20                                                       -330                            -310
Good module -
0                            5699                                                 5704                              5
1                            4830                                                 4836                              6
2                            -8                                                       -2                                  7
Are there any chip revisions that could cause such a loading of the A/D input and also cause the calibration routine to make things worse.
What is done internally to carry out the calibration routine?
Any help suggestions or thoughts?
