NRF24LE1 how to set PWM frequency?
To what values should I set the PWMCON register to so that the PWM0 and PWM1 frequency is output at 20Khz with duty cycle varying between 1 to 2ms. Now specifically I am asking this after reading the data sheet because the tables mentioned are not clearing giving information. How do I decipher the table given here:
Please clearly disclose information in the data sheets. Also give an example to show how to set to particular frequency and pulse width.
Let me tell you how I decipher this as a newbie. Now CCLK is 16,000,000 for 16Mhz clock. I chose PWM0 as output so bit 0 is 1 and bit 1 is 0. Now I need to find out what PWMCON is so the formula for PWMCON for 20Khz PWM freq will be. (16000000/(255 x 20000))-1 = 160/51 -1 which is approximately 2. Hence PWMCON[5:2] will be 0010. There fore PWMCON will be 11001001 which is 0xC9. But this dint work when I put in this value for PWMCON as the servo did not rotate. Here is my code.
#include "reg24le1.h" // I/O header file for NRF24LE1
#include "hal_delay.h" // header file containing delay functions
// main function
void main()
int i = 0, j = 0; // loop variable
P0DIR = 0; // Port 0 as output
PWMCON = 0xc9; // enable PWM1
// infinte loop
while(1)
for(i= 180; i--; i > 0)
PWMDC0 = i ; // change duty cycle
delay_ms(10); // delay of 10 ms
  • It does not go that far down. From the documentation:
    The following table shows how the PWM frequency (or period length) and the PWM duty cycle are controlled
    by the PWM SFR registers. PWM frequency range is approximately 4 kHz-254 kHz.
  • Is there a way that I can generate a way by software methods using timers. Generally in arduino they have a software library based PWM. They use timers. How can use timers to generate a 50Hz PWM?
  • We do not have a softPWM library available for the nRF24L-series devices. You'll have to manually use the timer to generate the pulse.
    Håkon
  • Here is a 15ms timer delay pulse. How do I change it to get a 20ms delay pulse and thus a 50Hz pulse?
    #include <stdlib.h> // standard library
    #include <string.h> // library containing string functions
    #include <stdio.h> // standard I/O library
    sfr16 DPTR = 0X82; // declare functional register DPTR
    // main function
    void main()
    int i = 0;
    P1DIR = 0; // Port1 as output
    P10 = 0; // Pin 0 of Port 1 low
    EA = 1; // Enable global interrupt
    TMOD = 0X01 ; // timer0 in 16bit mode1
    TR0 = 1; // start timer
    // infinite loop
    while(1)
    TH0 = 0; // initialise timer register upper byte
    TL0 = 0; // initialise timer register lower byte
    while(TF0 == 0); // wait for timer overflow flag
    TF0 = 0; // clear flag
    P10 =1; // make Pin0 of Port1 high
    P10 = 0; // make Pin0 of Port1 low
  • Could you try this instead?
    #include <stdio.h>
    #include <stdint.h>
    #include "nrf24le1.h"
    void timer0_init(void)
      TMOD |= 0x01; //16 bit timer
      TR0 = 1; //start timer
      ET0=1; //enable interrupt
    void t0_interrupt(void) interrupt 1
      // Timer increments every 2*12 CPU clock cycles
      // Timer starts counting down from 65535
      // 6666 * 1,5 us = 9999 us
      uint16_t timer_val = 0xFFFF - 6666;
      P10 ^= 1;
      TL0 = (uint8_t) (timer_val & 0xFF);
      TH0 = (uint8_t) ((timer_val >> 8) & 0xFF);
    void main(void)
        // Configure TXD pin as output.
        // P0.5, P0.3 and P1.0 are configured as outputs to make the example run on
        // either 24-pin, 32-pin or 48-pin nRF24LE1 variants.
        P0DIR = 0x00;
        P1DIR = 0x00;
        CLKCTRL |=  0x1;
        // Enable global interrupts
        EA = 1;
        timer0_init();
        for(;;)
    This should generate a 50 hz pulse.
    Håkon
