I am developing against a custom board built around the NRF52840. I am trying to store and retrieve values from flash using the fds module. I am not seeing any errors either in the function calls or in the fds event handler. The only thing I seem to be able to do is to iterate over all records and to delete them. I have the following test code extracted from my code base:
/** @enum record_handles
*** @brief list of handles for flash stored records
enum record_handles {
CONF_BEGIN = 0x100, ///< valid ids start at 0x0001 so the next item will be valid
CONF_MOVEMENT_THRES, ///< movement threshold handle @see sample.c
CONF_TIME_THRES, ///< movement time threshold @see sample.c
CONF_IDLE_TIMEOUT, ///< activity timeout @see standby.c
CONF_BAR_THRES, ///< average value when off bar
CONF_BAR_RANGE, ///< variation for off bar value
CONF_BAR_ENABLED, ///< switch on and off bar
CONF_SAMPLE_MODE, ///< 1, 3 or 5 tof sensors in use
CONF_SENSOR_ID, ///< handle for the sensor id
CONF_LAST, ///< max for last is 0xC000, peer manager uses this and above
/** @enum default values for records
*** @brief constants or default values used in configuration
enum record_defaults {
CONF_BEGIN_DEF = 0x0,
CONF_MOVEMENT_THRES_DEF = 30, ///< (mm) movement threshold @see sample.c
CONF_TIME_THRES_DEF = 10, ///< (sec) movement time threshold @see sample.c
CONF_IDLE_TIMEOUT_DEF = 600, ///< (sec) activity timeout @see standby.c
CONF_BAR_THRES_DEF = 260, ///< average value when off bar- off bar: 252-268
CONF_BAR_RANGE_DEF = 12, ///< variation for off bar value
CONF_BAR_ENABLED_DEF = true, ///< switch on and off bar
CONF_SAMPLE_MODE_DEF = 1, ///< 1, 3 or 5 tof sensors in use
CONF_SENSOR_ID_DEF = 0x37313030, ///< value for the sensor id
#define CONF_FILEHANDLE 0xF010 ///< conf file handle - range 0x0000 to 0xbfff
bool conf_is_started2 = false;
bool conf_write_done2 = false;
/** @brief configuration storage event handler
*** @param[in] the fds event structure
void on_FDS_event(fds_evt_t const *p_evt) {
NRF_LOG_INFO("fds event: %d %d\r\n", p_evt->id, (p_evt->result));
switch (p_evt->id) {
case FDS_EVT_INIT:
if (p_evt->result == FDS_SUCCESS) {
conf_is_started2 = true;
case FDS_EVT_WRITE:
conf_write_done2 = true;
NRF_LOG_INFO("EVT_WRITE: %d", p_evt->result);
if (p_evt->result != FDS_SUCCESS) {
NRF_LOG_INFO("conf evt: failed write 0x%x", p_evt->result);
case FDS_EVT_UPDATE:
NRF_LOG_INFO("conf evt: failed update 0x%x", p_evt->result);
case FDS_EVT_DEL_RECORD:
NRF_LOG_INFO("conf evt: failed del rec 0x%x", p_evt->result);
case FDS_EVT_DEL_FILE:
NRF_LOG_INFO("conf evt: failed del file 0x%x", p_evt->result);
case FDS_EVT_GC:
NRF_LOG_INFO("conf evt: failed GC 0x%x", p_evt->result);
void conf_2dump(void) {
fds_record_desc_t desc;
fds_find_token_t tok;
NRF_LOG_INFO("DUMPING...");
memset(&tok, 0x00, sizeof(fds_find_token_t));
memset(&desc, 0x00, sizeof(fds_record_desc_t ));
while(fds_record_iterate(&desc, &tok) != FDS_ERR_NOT_FOUND) {
NRF_LOG_INFO("Exists record: %d", desc.record_id);
NRF_LOG_INFO("DUMPED.");
int main(void) {
memset(NRF_SECTION_START_ADDR(rtt), 0, NRF_SECTION_LENGTH(rtt));
log_init();
fds_stat_t stat;
fds_record_t record;
ret_code_t err_code;
const uint32_t record_def_values[9] = {CONF_BEGIN_DEF,
CONF_MOVEMENT_THRES_DEF,
CONF_TIME_THRES_DEF,
CONF_IDLE_TIMEOUT_DEF,
CONF_BAR_THRES,
CONF_BAR_RANGE,
CONF_BAR_ENABLED,
CONF_SAMPLE_MODE_DEF,
CONF_SENSOR_ID_DEF};
// register a handler
err_code = fds_register(on_FDS_event);
if (err_code != FDS_SUCCESS) {
NRF_LOG_INFO("conf init: failed to register event handler0x%x", err_code);
return err_code;
// init the fds api
err_code = fds_init();
NRF_LOG_INFO("conf init: failed to init the api 0x%x", err_code);
return err_code;
while (!conf_is_started2)
fds_stat(&stat);
conf_2dump();
fds_record_delete(&desc);
conf_2dump();
for (int i = CONF_BEGIN + 1; i < CONF_LAST; i++) {
record.file_id = CONF_FILEHANDLE;
record.key = i;
record.data.p_data = &record_def_values[i - CONF_BEGIN];;
record.data.length_words = 1; //32bit width words
err_code = fds_record_write(&desc, &record);
while(!conf_write_done2)
conf_2dump();
a typical run produces:
<info> app: fds event: 0 0 <info> app: DUMPING... <info> app: Exists record: 9 <info> app: Exists record: 10 <info> app: Exists record: 11 <info> app: Exists record: 12 <info> app: Exists record: 13 <info> app: Exists record: 14 <info> app: Exists record: 15 <info> app: Exists record: 16 <info> app: DUMPED. <info> app: Exists record: 9 <info> app: fds event: 3 0 <info> app: Exists record: 10 <info> app: fds event: 3 0 <info> app: Exists record: 11 <info> app: fds event: 3 0 <info> app: Exists record: 12 <info> app: fds event: 3 0 <info> app: Exists record: 13 <info> app: fds event: 3 0 <info> app: Exists record: 14 <info> app: fds event: 1 0 <info> app: EVT_WRITE: 0 <info> app: fds event: 1 0 <info> app: EVT_WRITE: 0 <info> app: fds event: 1 0 <info> app: EVT_WRITE: 0 <info> app: fds event: 1 0 <info> app: EVT_WRITE: 0 <info> app: DUMPING... <info> app: Exists record: 17 <info> app: Exists record: 18 <info> app: Exists record: 19 <info> app: Exists record: 20 <info> app: Exists record: 21 <info> app: Exists record: 22 <info> app: Exists record: 23 <info> app: Exists record: 24 <info> app: DUMPED.
I am developing against SDK 15.0 using SES
Many thanks in advance
Paul
