Device not advertising when added DFU service into the applcation.
I am trying to add DFU service to my custom application, I have taken ble_app_hrs_s132 with DFU as a reference and added all the required files and made required changes in my application but when I flashed the code into the board, the board is not advertising.
I am using nRF52832 board, sdk v11.
The below one is the code.
Could anyone help me in solving this.
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#define BLE_DFU_APP_SUPPORT
#ifdef BLE_DFU_APP_SUPPORT  //added
#include "ble_dfu.h"
#include "dfu_app_handler.h"
#endif // BLE_DFU_APP_SUPPORT
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h" //added
#include "ble_hci.h"
#include "ble_srv_common.h" //added
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "boards.h" //added
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h" //added
#include "app_button.h"
#include "pstorage.h" //added
#include "app_trace.h" //added
#include "ble_nus.h"
#include "app_uart.h"
#include "nrf_uarte.h"
#include "bsp.h"
#include "app_fifo.h"
#include "bsp_btn_ble.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#define EVENT_SIZE 20
#define QUEUE_SIZE 5
#define UART_CONFIG_115200 115200
#define UART_CONFIG_57600  57600
#define UART_CONFIG_38400  38400
#define UART_CONFIG_9600   9600
#define UART_CONFIG_19200  19200
#define IS_SRVC_CHANGED_CHARACT_PRESENT 1                                          /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define DEVICE_NAME                     "DEBUG_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL               7.5 //MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               7.5 //MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(7500, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define MAX_PKT_SIZE                    20
#define MAX_SIZE                        1024                                        /** < Maximum no.of bytes in 2kB Memory. */
/*********************added for DFU*************/
#define DFU_REV_MAJOR                    0x00                                       /** DFU Major revision number to be exposed. */
#define DFU_REV_MINOR                    0x01                                       /** DFU Minor revision number to be exposed. */
#define DFU_REVISION                     ((DFU_REV_MAJOR << 8) | DFU_REV_MINOR)     /** DFU Revision number to be exposed. Combined of major and minor versions. */
#define APP_SERVICE_HANDLE_START         0x000C                                     /**< Handle of first application specific service when when service changed characteristic is present. */
#define BLE_HANDLE_MAX                   0xFFFF                                     /**< Max handle value in BLE. */
STATIC_ASSERT(IS_SRVC_CHANGED_CHARACT_PRESENT);  /** When having DFU Service support in application the Service Changed Characteristic should always be present. */
static dm_application_instance_t         m_app_handle;
static ble_dfu_t                         m_dfus;                                    /**< Structure used to identify the DFU service. */
typedef struct _my_queue
       int         head;
       int         tail;
       int         count;
       unsigned char  buffer[MAX_SIZE];
   } MY_QUEUE;
/* Queue implementation */
//#define StructQueueInit(q,N) (  (q)->head  = (N), \
//                                (q)->tail  = (N), \
//                                (q)->count =  0   )
//#define StructQueueAdd(q,N) ( (q)->count++,            \
//                              ( ((q)->head < (N-1)) ?  \
//                                  ((q)->head++)     :  \
//                                  ((q)->head=0)     ), \
//                              &(q)->buffer[(q)->head]  )
//#define StructQueueRemove(q,N) ( (q)->count--,            \
//                                 ( ((q)->tail < (N-1)) ?  \
//                                     ((q)->tail++)     :  \
//                                     ((q)->tail=0)     ), \
//                                 &(q)->buffer[(q)->tail]  )
#define StructQueuePeekTail(q,N) ( ((q)->tail < (N-1))         ?  \
                                     &(q)->buffer[(q)->tail+1] :  \
                                     &(q)->buffer[0]              )
#define StructQueueIsFull(q,N) ( (q)->count >= N )
#define StructQueueIsNotFull(q,N) ( (q)->count < N )
#define StructQueueIsEmpty(q,N) ( (q)->count == 0 )
#define StructQueueIsNotEmpty(q,N) ( (q)->count != 0 )
#define StructQueueCount(q,N) ( (q)->count )
#define StructQueueSpaceAvailable(c,q,N) ( ((q)->count + c) <= N )
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
void start_timer(void);
static uint8_t data_array[32];
MY_QUEUE UartQueue;
uint8_t received_pkts=0,intr_count=1,buff_over_wrt=0;
static uint16_t bytereceivedCount ;
void StructQueueInit(MY_QUEUE * q)
   (q)->head  = 0;                              //(  (q)->head  = (N), \
   (q)->tail  = 0;                              //(q)->tail  = (N), \
   (q)->count = 0;                              //(q)->count =  0   )
void StructQueueAdd(MY_QUEUE * q, uint8_t inByte)
  (q)->count++;
  if((q)->head < (MAX_SIZE-1))            //( ((q)->head < (MAX_SIZE-1)) ?
    (q)->head++  ;                        //((q)->head++)     :
    ((q)->head=0);                        //((q)->head=0)     ),
   if((q)->head == (q)->tail)
      printf("\r\nBuffer overrun !!\r\n");
  (q)->buffer[(q)->head]  = inByte;       //&(q)->buffer[(q)->head]
   bytereceivedCount++;
int flag=0,                     /* */
    flag1=0;                    /* */
void StructQueueRemove(MY_QUEUE * q, uint8_t * inByte)
  (q)->count--;
   *inByte = (q)->buffer[(q)->tail] ;
    if ((q)->tail < (MAX_SIZE-1))
     ((q)->tail++) ;
     (q)->tail=0;
  NRF_TIMER2->MODE = TIMER_MODE_MODE_Counter;              // Set the timer in Counter Mode
  NRF_TIMER2->TASKS_CLEAR = 1;                             // clear the task first to be usable for later
	NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;		   //Set counter to 16 bit resolution
	NRF_TIMER2->CC[0] = 7;                                   //Set value for TIMER2 compare register 0
	NRF_TIMER2->CC[1] = 0;                                   //Set value for TIMER2 compare register 1
  // Enable interrupt on Timer 2, both for CC[0] and CC[1] compare match events
	NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos) | (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
  NVIC_EnableIRQ(TIMER2_IRQn);
  NRF_TIMER2->TASKS_START = 1;               // Start TIMER2
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for stopping advertising.
static void advertising_stop(void)
    uint32_t err_code;
    err_code = sd_ble_gap_adv_stop();
/**@brief Function for loading application-specific context after establishing a secure connection.
 * @details This function will load the application context and check if the ATT table is marked as
 *          changed. If the ATT table is marked as changed, a Service Changed Indication
 *          is sent to the peer if the Service Changed CCCD is set to indicate.
 * @param[in] p_handle The Device Manager handle that identifies the connection for which the context
 *                     should be loaded.
static void app_context_load(dm_handle_t const * p_handle)
    uint32_t                 err_code;
    static uint32_t          context_data;
    dm_application_context_t context;
    context.len    = sizeof(context_data);
    context.p_data = (uint8_t *)&context_data;
    err_code = dm_application_context_get(p_handle, &context);
    if (err_code == NRF_SUCCESS)
        // Send Service Changed Indication if ATT table has changed.
        if ((context_data & (DFU_APP_ATT_TABLE_CHANGED << DFU_APP_ATT_TABLE_POS)) != 0)
            err_code = sd_ble_gatts_service_changed(m_conn_handle, APP_SERVICE_HANDLE_START, BLE_HANDLE_MAX);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != BLE_ERROR_INVALID_CONN_HANDLE) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != BLE_ERROR_NO_TX_PACKETS) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING))
                APP_ERROR_HANDLER(err_code);
        err_code = dm_application_context_delete(p_handle);
    else if (err_code == DM_NO_APP_CONTEXT)
        // No context available. Ignore.
/** @snippet [DFU BLE Reset prepare] */
/**@brief Function for preparing for system reset.
 * @details This function implements @ref dfu_app_reset_prepare_t. It will be called by
 *          @ref dfu_app_handler.c before entering the bootloader/DFU.
 *          This allows the current running application to shut down gracefully.
static void reset_prepare(void)
    uint32_t err_code;
    if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
        // Disconnect from peer.
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        // If not connected, the device will be advertising. Hence stop the advertising.
        advertising_stop();
    err_code = ble_conn_params_stop();
    nrf_delay_ms(500);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    /* ### HANDS-ON CODE END ### */ ////
    for (uint32_t i = 0; i < length; i++)
        while(app_uart_put(p_data[i]) != NRF_SUCCESS);
    while(app_uart_put('\n') != NRF_SUCCESS);
/**@brief Function for handling the Device Manager events.
 * @param[in] p_evt  Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
                                           dm_event_t const  * p_event,
                                           ret_code_t        event_result)
    APP_ERROR_CHECK(event_result);
    if (p_event->event_id == DM_EVT_LINK_SECURED)
        app_context_load(p_handle);
    return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
 * @param[in] erase_bonds  Indicates whether bonding information should be cleared from
 *                         persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
    dm_init_param_t        init_param = {.clear_persistent_data = erase_bonds};
    dm_application_param_t register_param;
    // Initialize persistent storage module.
    err_code = pstorage_init();
    err_code = dm_init(&init_param);
    register_param.evt_handler            = device_manager_evt_handler;
    register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
    err_code = dm_register(&m_app_handle, &register_param);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
    /** @snippet [DFU BLE Service initialization] */
    ble_dfu_init_t   dfus_init;
    // Initialize the Device Firmware Update Service.
    memset(&dfus_init, 0, sizeof(dfus_init));
    dfus_init.evt_handler   = dfu_app_on_dfu_evt;
    dfus_init.error_handler = NULL;
    dfus_init.revision      = DFU_REVISION;
    err_code = ble_dfu_init(&m_dfus, &dfus_init);
    dfu_app_reset_prepare_set(reset_prepare);
    dfu_app_dm_appl_instance_set(m_app_handle);
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
    if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for the application's SoftDevice event handler.
 * @param[in] p_ble_evt SoftDevice event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
        case BLE_GAP_EVT_CONNECTED:
//        case BLE_GAP_EVT_DISCONNECTED:
//            err_code = bsp_indication_set(BSP_INDICATE_IDLE);
//            APP_ERROR_CHECK(err_code);
//            m_conn_handle = BLE_CONN_HANDLE_INVALID;
//            break;
//        case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
//            // Pairing not supported
//            err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
//            break;
//        case BLE_GATTS_EVT_SYS_ATTR_MISSING:
//            // No system attributes have been stored.
//            err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
//            break;
            // No implementation needed.
/**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
 *        event handler.
 * @details This function is called from the SoftDevice event interrupt handler after a
 *          SoftDevice event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
    /** @snippet [Propagating BLE Stack events to DFU Service] */
    ble_dfu_on_ble_evt(&m_dfus, p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 *          event has been received.
 * @param[in] sys_evt  System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
    pstorage_sys_event_handler(sys_evt);
    ble_advertising_on_sys_evt(sys_evt);
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    ble_enable_params.gatts_enable_params.service_changed = 1;
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
            err_code = ble_advertising_restart_without_whitelist();
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
    uint8_t   tempByte;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
           app_uart_get(&tempByte);
           StructQueueAdd(&UartQueue,tempByte);
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud57600
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scanrsp;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = false;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Application main function.
    uint32_t err_code;
    bool erase_bonds;
  	uint8_t index=0;
    uint16_t  icounter =0;
    // Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    ble_stack_init();
		device_manager_init(erase_bonds);//added
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    StructQueueInit (&UartQueue);
	  printf("\r\nUART Start!\r\n");
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    start_timer();
    nrf_delay_ms(1000);
    // Enter main loop.
    	for (;;)
       icounter++;
			 //nrf_delay_ms(100);
			// printf("\r\n Count %u\r\n",icounter);
			 if(( icounter > 10000))
           err_code = ble_nus_string_send(&m_nus, data_array,index);
           index = 0;
           icounter = 0;
			   while(UartQueue.count >0)
          StructQueueRemove(&UartQueue,&data_array[index++]);
         if( index > 16)
           index = 0;
           icounter = 0;
         power_manage();
  • Hi Hung,
    I Debugged the code as you said.
    // Initialze driver.
    I am getting error in the above function and the err_code  it is throwing is 0x00000008.
    Could you please help me in fixing this?
  • If you go to the Reference of the function nrf_drv_gpiote_init() in nrf_drv_gpiote.h you can find this:
    * @brief Function for initializing the GPIOTE module.
    * @details Only static configuration is supported to prevent the shared
    * resource being customized by the initiator.
    * @retval NRF_SUCCESS If initialization was successful.
    * @retval NRF_ERROR_INVALID_STATE If the driver was already initialized.
    ret_code_t nrf_drv_gpiote_init(void);
    And error code 0x08 is equal to NRF_ERROR_INVALID_STATE
    This meant you already initialize the gpiote driver some where else. Please check in your code.
