Device not advertising when added DFU service into the applcation.
I am trying to add DFU service to my custom application, I have taken ble_app_hrs_s132 with DFU as a reference and added all the required files and made required changes in my application but when I flashed the code into the board, the board is not advertising.
I am using nRF52832 board, sdk v11.
The below one is the code.
Could anyone help me in solving this.
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#define BLE_DFU_APP_SUPPORT
#ifdef BLE_DFU_APP_SUPPORT  //added
#include "ble_dfu.h"
#include "dfu_app_handler.h"
#endif // BLE_DFU_APP_SUPPORT
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h" //added
#include "ble_hci.h"
#include "ble_srv_common.h" //added
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "boards.h" //added
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h" //added
#include "app_button.h"
#include "pstorage.h" //added
#include "app_trace.h" //added
#include "ble_nus.h"
#include "app_uart.h"
#include "nrf_uarte.h"
#include "bsp.h"
#include "app_fifo.h"
#include "bsp_btn_ble.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#define EVENT_SIZE 20
#define QUEUE_SIZE 5
#define UART_CONFIG_115200 115200
#define UART_CONFIG_57600  57600
#define UART_CONFIG_38400  38400
#define UART_CONFIG_9600   9600
#define UART_CONFIG_19200  19200
#define IS_SRVC_CHANGED_CHARACT_PRESENT 1                                          /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
#define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define DEVICE_NAME                     "DEBUG_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL               7.5 //MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               7.5 //MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(7500, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define MAX_PKT_SIZE                    20
#define MAX_SIZE                        1024                                        /** < Maximum no.of bytes in 2kB Memory. */
/*********************added for DFU*************/
#define DFU_REV_MAJOR                    0x00                                       /** DFU Major revision number to be exposed. */
#define DFU_REV_MINOR                    0x01                                       /** DFU Minor revision number to be exposed. */
#define DFU_REVISION                     ((DFU_REV_MAJOR << 8) | DFU_REV_MINOR)     /** DFU Revision number to be exposed. Combined of major and minor versions. */
#define APP_SERVICE_HANDLE_START         0x000C                                     /**< Handle of first application specific service when when service changed characteristic is present. */
#define BLE_HANDLE_MAX                   0xFFFF                                     /**< Max handle value in BLE. */
STATIC_ASSERT(IS_SRVC_CHANGED_CHARACT_PRESENT);  /** When having DFU Service support in application the Service Changed Characteristic should always be present. */
static dm_application_instance_t         m_app_handle;
static ble_dfu_t                         m_dfus;                                    /**< Structure used to identify the DFU service. */
typedef struct _my_queue
       int         head;
       int         tail;
       int         count;
       unsigned char  buffer[MAX_SIZE];
   } MY_QUEUE;
/* Queue implementation */
//#define StructQueueInit(q,N) (  (q)->head  = (N), \
//                                (q)->tail  = (N), \
//                                (q)->count =  0   )
//#define StructQueueAdd(q,N) ( (q)->count++,            \
//                              ( ((q)->head < (N-1)) ?  \
//                                  ((q)->head++)     :  \
//                                  ((q)->head=0)     ), \
//                              &(q)->buffer[(q)->head]  )
//#define StructQueueRemove(q,N) ( (q)->count--,            \
//                                 ( ((q)->tail < (N-1)) ?  \
//                                     ((q)->tail++)     :  \
//                                     ((q)->tail=0)     ), \
//                                 &(q)->buffer[(q)->tail]  )
#define StructQueuePeekTail(q,N) ( ((q)->tail < (N-1))         ?  \
                                     &(q)->buffer[(q)->tail+1] :  \
                                     &(q)->buffer[0]              )
#define StructQueueIsFull(q,N) ( (q)->count >= N )
#define StructQueueIsNotFull(q,N) ( (q)->count < N )
#define StructQueueIsEmpty(q,N) ( (q)->count == 0 )
#define StructQueueIsNotEmpty(q,N) ( (q)->count != 0 )
#define StructQueueCount(q,N) ( (q)->count )
#define StructQueueSpaceAvailable(c,q,N) ( ((q)->count + c) <= N )
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
void start_timer(void);
static uint8_t data_array[32];
MY_QUEUE UartQueue;
uint8_t received_pkts=0,intr_count=1,buff_over_wrt=0;
static uint16_t bytereceivedCount ;
void StructQueueInit(MY_QUEUE * q)
   (q)->head  = 0;                              //(  (q)->head  = (N), \
   (q)->tail  = 0;                              //(q)->tail  = (N), \
   (q)->count = 0;                              //(q)->count =  0   )
void StructQueueAdd(MY_QUEUE * q, uint8_t inByte)
  (q)->count++;
  if((q)->head < (MAX_SIZE-1))            //( ((q)->head < (MAX_SIZE-1)) ?
    (q)->head++  ;                        //((q)->head++)     :
    ((q)->head=0);                        //((q)->head=0)     ),
   if((q)->head == (q)->tail)
      printf("\r\nBuffer overrun !!\r\n");
  (q)->buffer[(q)->head]  = inByte;       //&(q)->buffer[(q)->head]
   bytereceivedCount++;
int flag=0,                     /* */
    flag1=0;                    /* */
void StructQueueRemove(MY_QUEUE * q, uint8_t * inByte)
  (q)->count--;
   *inByte = (q)->buffer[(q)->tail] ;
    if ((q)->tail < (MAX_SIZE-1))
     ((q)->tail++) ;
     (q)->tail=0;
  NRF_TIMER2->MODE = TIMER_MODE_MODE_Counter;              // Set the timer in Counter Mode
  NRF_TIMER2->TASKS_CLEAR = 1;                             // clear the task first to be usable for later
	NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;		   //Set counter to 16 bit resolution
	NRF_TIMER2->CC[0] = 7;                                   //Set value for TIMER2 compare register 0
	NRF_TIMER2->CC[1] = 0;                                   //Set value for TIMER2 compare register 1
  // Enable interrupt on Timer 2, both for CC[0] and CC[1] compare match events
	NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos) | (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
  NVIC_EnableIRQ(TIMER2_IRQn);
  NRF_TIMER2->TASKS_START = 1;               // Start TIMER2
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for stopping advertising.
static void advertising_stop(void)
    uint32_t err_code;
    err_code = sd_ble_gap_adv_stop();
/**@brief Function for loading application-specific context after establishing a secure connection.
 * @details This function will load the application context and check if the ATT table is marked as
 *          changed. If the ATT table is marked as changed, a Service Changed Indication
 *          is sent to the peer if the Service Changed CCCD is set to indicate.
 * @param[in] p_handle The Device Manager handle that identifies the connection for which the context
 *                     should be loaded.
static void app_context_load(dm_handle_t const * p_handle)
    uint32_t                 err_code;
    static uint32_t          context_data;
    dm_application_context_t context;
    context.len    = sizeof(context_data);
    context.p_data = (uint8_t *)&context_data;
    err_code = dm_application_context_get(p_handle, &context);
    if (err_code == NRF_SUCCESS)
        // Send Service Changed Indication if ATT table has changed.
        if ((context_data & (DFU_APP_ATT_TABLE_CHANGED << DFU_APP_ATT_TABLE_POS)) != 0)
            err_code = sd_ble_gatts_service_changed(m_conn_handle, APP_SERVICE_HANDLE_START, BLE_HANDLE_MAX);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != BLE_ERROR_INVALID_CONN_HANDLE) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != BLE_ERROR_NO_TX_PACKETS) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING))
                APP_ERROR_HANDLER(err_code);
        err_code = dm_application_context_delete(p_handle);
    else if (err_code == DM_NO_APP_CONTEXT)
        // No context available. Ignore.
/** @snippet [DFU BLE Reset prepare] */
/**@brief Function for preparing for system reset.
 * @details This function implements @ref dfu_app_reset_prepare_t. It will be called by
 *          @ref dfu_app_handler.c before entering the bootloader/DFU.
 *          This allows the current running application to shut down gracefully.
static void reset_prepare(void)
    uint32_t err_code;
    if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
        // Disconnect from peer.
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        // If not connected, the device will be advertising. Hence stop the advertising.
        advertising_stop();
    err_code = ble_conn_params_stop();
    nrf_delay_ms(500);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    /* ### HANDS-ON CODE END ### */ ////
    for (uint32_t i = 0; i < length; i++)
        while(app_uart_put(p_data[i]) != NRF_SUCCESS);
    while(app_uart_put('\n') != NRF_SUCCESS);
/**@brief Function for handling the Device Manager events.
 * @param[in] p_evt  Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
                                           dm_event_t const  * p_event,
                                           ret_code_t        event_result)
    APP_ERROR_CHECK(event_result);
    if (p_event->event_id == DM_EVT_LINK_SECURED)
        app_context_load(p_handle);
    return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
 * @param[in] erase_bonds  Indicates whether bonding information should be cleared from
 *                         persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
    dm_init_param_t        init_param = {.clear_persistent_data = erase_bonds};
    dm_application_param_t register_param;
    // Initialize persistent storage module.
    err_code = pstorage_init();
    err_code = dm_init(&init_param);
    register_param.evt_handler            = device_manager_evt_handler;
    register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
    err_code = dm_register(&m_app_handle, &register_param);
    uint32_t       err_code;
    ble_nus_init_t nus_init;
    /** @snippet [DFU BLE Service initialization] */
    ble_dfu_init_t   dfus_init;
    // Initialize the Device Firmware Update Service.
    memset(&dfus_init, 0, sizeof(dfus_init));
    dfus_init.evt_handler   = dfu_app_on_dfu_evt;
    dfus_init.error_handler = NULL;
    dfus_init.revision      = DFU_REVISION;
    err_code = ble_dfu_init(&m_dfus, &dfus_init);
    dfu_app_reset_prepare_set(reset_prepare);
    dfu_app_dm_appl_instance_set(m_app_handle);
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
    if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for the application's SoftDevice event handler.
 * @param[in] p_ble_evt SoftDevice event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
        case BLE_GAP_EVT_CONNECTED:
//        case BLE_GAP_EVT_DISCONNECTED:
//            err_code = bsp_indication_set(BSP_INDICATE_IDLE);
//            APP_ERROR_CHECK(err_code);
//            m_conn_handle = BLE_CONN_HANDLE_INVALID;
//            break;
//        case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
//            // Pairing not supported
//            err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
//            break;
//        case BLE_GATTS_EVT_SYS_ATTR_MISSING:
//            // No system attributes have been stored.
//            err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
//            break;
            // No implementation needed.
/**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
 *        event handler.
 * @details This function is called from the SoftDevice event interrupt handler after a
 *          SoftDevice event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_conn_params_on_ble_evt(p_ble_evt);
    ble_nus_on_ble_evt(&m_nus, p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
    /** @snippet [Propagating BLE Stack events to DFU Service] */
    ble_dfu_on_ble_evt(&m_dfus, p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 *          event has been received.
 * @param[in] sys_evt  System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
    pstorage_sys_event_handler(sys_evt);
    ble_advertising_on_sys_evt(sys_evt);
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    ble_enable_params.gatts_enable_params.service_changed = 1;
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
            err_code = ble_advertising_restart_without_whitelist();
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
    uint8_t   tempByte;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
           app_uart_get(&tempByte);
           StructQueueAdd(&UartQueue,tempByte);
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
    const app_uart_comm_params_t comm_params =
        RX_PIN_NUMBER,
        TX_PIN_NUMBER,
        RTS_PIN_NUMBER,
        CTS_PIN_NUMBER,
        APP_UART_FLOW_CONTROL_DISABLED,
        false,
        UART_BAUDRATE_BAUDRATE_Baud57600
    APP_UART_FIFO_INIT( &comm_params,
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scanrsp;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = false;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for placing the application in low power state while waiting for events.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Application main function.
    uint32_t err_code;
    bool erase_bonds;
  	uint8_t index=0;
    uint16_t  icounter =0;
    // Initialize.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    uart_init();
    ble_stack_init();
		device_manager_init(erase_bonds);//added
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    StructQueueInit (&UartQueue);
	  printf("\r\nUART Start!\r\n");
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    start_timer();
    nrf_delay_ms(1000);
    // Enter main loop.
    	for (;;)
       icounter++;
			 //nrf_delay_ms(100);
			// printf("\r\n Count %u\r\n",icounter);
			 if(( icounter > 10000))
           err_code = ble_nus_string_send(&m_nus, data_array,index);
           index = 0;
           icounter = 0;
			   while(UartQueue.count >0)
          StructQueueRemove(&UartQueue,&data_array[index++]);
         if( index > 16)
           index = 0;
           icounter = 0;
         power_manage();
  • Hi Kishor,
    When your code doesn't work as expected, for example not advertising, you can debug.
    To debug, you can follow this guide.  We want to know which function  at which file causing assertion and with which error code.
  • Hi Hung,
    Thanks for the reply, I am able to solve the issue.
    I have added
    p_ble_enable_params->common_enable_params.vs_uuid_count = 2; in softdevice_handler.c then it is advertising.
    Now I am facing another issue where in the same code I have added a gpio interrupt, but when configuring  input pin for enabling interrupt it is restarting the system.
    ///**@brief Function for initializing the GPIOTE handler module.
    // Button event handler.
    static void button_duration_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
       static uint32_t button_pushed_time;
    		static uint32_t button_released_time;
    		static uint32_t button_pressed_time;
    	   uint32_t err_code;
        if (action == APP_BUTTON_PUSH)
    					        //err_code = app_timer_start(m_led_a_timer_id, APP_TIMER_TICKS(200, APP_TIMER_PRESCALER), NULL);
    			            printf("\r\n in the button handler");
    								  app_timer_cnt_get(&button_pushed_time);
    					        button_pushed_time=app_timer_sec(button_pushed_time);
    			            while(!nrf_gpio_pin_read(13));
    			             app_timer_cnt_get(&button_released_time);
    			             button_released_time=app_timer_sec(button_released_time);
    							   	app_timer_cnt_diff_compute(button_released_time, button_pushed_time, &button_pressed_time);
    					         if((button_pressed_time<3))
    							    	nrf_drv_gpiote_out_clear(19);
                        nrf_drv_gpiote_out_set(20);
                      else if(button_pressed_time>=3)
    		               nrf_drv_gpiote_out_set(19);
                       nrf_drv_gpiote_out_clear(20);
    // Function for configuring GPIO.
    static void gpio_config()
        ret_code_t err_code;
        // Initialze driver.
    	nrf_gpio_cfg_output(19);
        nrf_gpio_cfg_output(20);
        // Set output pins (this will turn off the LED's).
        // Make a configuration for input pints. This is suitable for both pins in this example.
        nrf_gpio_cfg_input(13, NRF_GPIO_PIN_PULLUP);
        nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
        in_config.pull = NRF_GPIO_PIN_PULLUP;
        // Configure input pins for buttons, with separate event handlers for each button.
        err_code = nrf_drv_gpiote_in_init(13, &in_config, button_duration_handler);
        // Enable input pins for buttons.
        nrf_drv_gpiote_in_event_enable(13, true);
    Above are the functions for button_event_handler and for configuring the gpio.
    could you please help me in solving this issue?
  • Again, please follow the debugging guide. You need to check for the error code AFTER you call a function. In your code, you have APP_ERROR_CHECK(err_code); at line 18 without any value assigned to it.
  • err_code = nrf_drv_gpiote_in_init(13, &in_config, button_duration_handler);
    The above function restarting the system.But the returned err_code value is 0.
    I am not able to figure out why it is restarting, could you please help me?
  • I'm not sure why it should restart, please make sure you change the optimization level to 0, add DEBUG into the preprocessor symbols.
    If you can see the error return 0 , I don't think there would be any restart here. If you can step to APP_ERROR_CHECK, how would it restart ? Have you tried to step into nrf_drv_gpiote_in_init() ?
