pc-ble-driver (master) scan_start() reports only one device upon every invocation
I am trying to use latest pc-ble-driver. The code is based on pc-ble-driver-js. When I call sd_ble_gap_scan_start(), I get only one "device discovered" event. This happens on every invocation of sd_ble_gap_scan_start(). Is there any inherent change in the way sd_ble_gap_scan_start() is used? Do I need to change scan params or pass different size for adv_report_buffer?
My code looks like this:
    static uint8_t mp_data[BLE_GAP_ADV_SET_DATA_SIZE_EXTENDED_MAX_SUPPORTED] = { 0 };
    static ble_data_t m_adv_report_buffer;
    void Adapter::GapStartScan(uv_work_t *req)
        auto baton = static_cast<StartScanBaton *>(req->data);
        m_adv_report_buffer.p_data = mp_data;
        m_adv_report_buffer.len = sizeof(mp_data);
        baton->result = sd_ble_gap_scan_start(baton->adapter, baton->scan_params, &m_adv_report_buffer);
start scan, stop scan work fine, they do not return any error. similar code used to report multiple devices with SD 3.1.
Scan params are as follows
active= true
interval = 100
window = 20
timeout =  -1
extended = 0
report_incomplete_evts = 0
filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL
scan_phys = BLE_GAP_PHY_1MBPS
I am using following h/w and s/w config
nRF 52840 dongle
Soft Device 140 6.1.0
Windows 10 64 bit
Node JS 9.4.0
