How to change FreeRTOS initial tick count ?
I am using the NRF52840 with FreeRTOS and I would like to start the FreeRTOS tick count at a high value for testing purpose.
I have modified the  configINITIAL_TICK_COUNT value in the FreeRTOS.h file with a high value : 0xffffffff  - 0x1e000 = 0xfffe1fff
(0xffffffff correspond to the maximal tick count, TickType_t beeing a uint32_t value)
(0x1e000 = 2*60*1024 is for 2 minuts, configTICK_TATE_HZ value beeing at 1024)
It should start FreeRTOS tick count at 0xfffe1fff and go back to the zero value after 2 minuts (acctually this is what I want to test), but I have an unexpected result when I use the xTaskGetTickCount() function to see the tick count value (now is the value returned by the xTaskGetTickCount function) :
(FreeTROS.h) #define configINITIAL_TICK_COUNT 0
(LOG) now=4000 (4000 = 3*1024 = 3 sec)
(FreeTROS.h) #define configINITIAL_TICK_COUNT 0xfffe1fff
now=3119
I wonld expect the now value to be mutch higer than 4000 (about 0xfffe1fff = 4294844415)
Does anyone know where my problem comes frone ?
Thanks a lot,
Clément
  • This is purely FreeRTOS initialization code. The value you mentioned in configINITIAL_TICK_COUNT  is directly initialized to below in task.c
    PRIVILEGED_DATA static volatile TickType_t xTickCount 				= ( TickType_t ) configINITIAL_TICK_COUNT;
    The device specific port changes never resets xTickCount, so i am not sure why you are seeing this behavior.
    It would be interesting to know where exactly you are printing these logs? and the code snippets on how you print them.
  • Thank you for your answer,
    I am printing these logs in a thread called after the vTaskStartScheduler(). I was logging my 32bits TickType_t with a %d instead of a %ld, it may resolve a part of the probleme but I am still in trouble:
    I am trying to reproduce this error in a simple environment : I am using the NRF52840 dev board and I took the ble_app_hrs_freertos example code from the nrf SDK. I just added my log in a periodically called function:
    static void heart_rate_meas_timeout_handler(TimerHandle_t xTimer)
    TickType_t val;
    val = xTaskGetTickCount();
    NRF_LOG_INFO("Tick Count : %ld", val);
    And I changed the FreeRTOS.h file from the SDK :
    #define configINITIAL_TICK_COUNT 0xff000000
    I am using CoolTerm (mac) to print my logs and I have the folowing result:
    .[1;31mLogs dropped (196).[0m
    <info> app: Tick Count : 1289
    <info> app: Tick Count : 1290
    <info> app: Tick Count : 1291
    .[1;31mLogs dropped (197).[0m
    .[1;31mLogs dropped (198).[0m
    <info> app: Tick Count : 1292
    <info> app: Tick Count : 1911
    <info> app: Tick Count : 2784
    <info> app: Tick Count : 3796
    <info> app: Tick Count : 4793
    <info> app: Tick Count : 5784
    It seems that the tick count restarts after a while. Do you have an idea of what is happening ?
  •  you seems to have found a bug in freertos kernel.
    in tasks.c-> vTaskStartScheduler() -> TickCount is uncondictionally initiallized to 0 even though it is already initialized correctly to configINITIAL_TICK_COUNT   when created.
    So comment out the below line in in tasks.c-> vTaskStartScheduler()
    xNextTaskUnblockTime = portMAX_DELAY;
    xSchedulerRunning = pdTRUE;
    //xTickCount = ( TickType_t ) 0U;
    /* If configGENERATE_RUN_TIME_STATS is defined then the following
    macro must be defined to configure the timer/counter used to generate
    the run time counter time base. NOTE: If configGENERATE_RUN_TIME_STATS
    is set to 0 and the following line fails to build then ensure you do not
    have portCONFIGURE_TIMER_FOR_RUN_TIME_STATS() defined in your
    FreeRTOSConfig.h file. */
    portCONFIGURE_TIMER_FOR_RUN_TIME_STATS();
    And everything works as you expect.
  • also note that RTC1 counter are 24bit registers, your value does not fit in the counter register
    You calculation must be as below
    0x00FFFFFF - 0x1e000 = 0xFE1FFF
    This will fit the 24 bit RTC1 counter register
    so set
    (FreeTROS.h) #define configINITIAL_TICK_COUNT 0xfe1fff (and not 0xfffe1fff )
    if you are testing for the highest possible tick count then i guess your way of testing will not help you much as tick count is 32 bit and RTC1 counter is 24 bit.
  • I tried to comment the line //xTickCount = ( TickType_t ) 0U;   on task.c, I changed the value of configINITIAL_TICK_COUNT in FreeRTOS.h to a given value and I have the following result:
    when configINITIAL_TICK_COUNT=0x0, 0x1, 0x2, ..., 0x7 : the logs works well and the first xTaskGetTickCount gives a value from 3E8 to 3EF.
    when configINITIAL_TICK_COUNT=0x8 or higer : there are dropped logs and the xTaskGetTickCount gives a strange value (examples: configINITIAL_TICK_COUNT=0x8 -> xTaskGetTickCount=1005CF0, configINITIAL_TICK_COUNT=0x8000 -> xTaskGetTickCount=0x1005C00, configINITIAL_TICK_COUNT=0x80000 -> xTaskGetTickCount=0x1005A20)
    I am still using the NRF52840 dev board and I took the ble_app_hrs_freertos example code from the nrf SDK with the following changes :
    main.c
    I added a xTeskGetTickCount in a function called periodically:
    TickType_t val;
    int_to_hex(val);
    I added a function to print the xTeskGetTickCount result in hexadecimal:
    void int_to_hex(TickType_t decimal){
    long long quotient, remainder;
    int i, j = 0;
    char hexadecimal[100];
    quotient = decimal;
    while (quotient != 0)
    remainder = quotient % 16; //step 1
    if (remainder < 10)
    hexadecimal[j++] = 48 + remainder; //step 2
    hexadecimal[j++] = 55 + remainder; //step 3
    quotient = quotient / 16; //step 4
    //step 6
    for (i = j; i >= 0; i--)
    NRF_LOG_INFO("%c", hexadecimal[i]);
    Do you have any idear of what is happening ? Thanks a lot!
