Custom mesh 3.0.1 messages.
Hello everyone,
This question is aimed at both Nordic and everyday users of a forum. I am testing out NRF52832 devboards in a mesh configuration I can run examples from sdk 3.0.1 and I am interested in having a mesh configuration where I could send short custom strings over the mesh instead of on/off value.
I have been looking around support forum and there are quite a few people asking for help with that. Would someone be willing to share custom message example for mesh 3.0.1 either from Nordic dev team or from people who frequent this forum.
I am not looking for a perfect example or official release. Just a bare bones example to test out on few devboards.
Thank you in advance,
James.
Edit: added tags and its mesh 3.1.0 not 3.0.1
  • Hi James,
    I am pretty new to the NRF52 ecosystem and so I was wondering the same. After a lot of research and trial & error I found the following:
    A model_init_cb function can be specified in the init_params of the mesh_stack_init function. In your model_init_cb function this should be done:
    The function that actually adds the model is access_model_add. This function takes two arguments, access_model_add_params_t and access_model_handle_t which is just a uint16_t. Here is a code example of my usecase:
    uint16_t model_handle;
    access_model_add_params_t add_params =
    .model_id = ACCESS_MODEL_VENDOR(0xFFAA, 0xF001),  // Format of ACCESS_MODEL_VENDOR is (model_id, company_id)
    .element_index = 0,
    .p_opcode_handlers = &m_opcode_handlers[0],
    .opcode_count = ARRAY_SIZE(m_opcode_handlers),
    .p_args = NULL,
    .publish_timeout_cb = publish_interval_cb
    uint32_t status = access_model_add(&add_params, &model_handle);
    Some of the Parameters inside the access_model_add_params_t need some explaining:
    - model_id: The Model ID is used for identifying predefined Models, like the Simple_OnOff_Client you are probably using. If you want to make your own you you can choose your own ID and Company value. What I have found is, that the two MSB of these values should be 1 (0xC0 or higher).
    - element_index: Defines in which element your model will be imported. Health and Config Server are at index 0.
    -  p_opcode_handlers: This contains your OpCodes and should look something like this:
               static const access_opcode_handler_t m_opcode_handlers[] =
                     {ACCESS_OPCODE_VENDOR(0xC1, 0xF001), your_opcode_handler_function},
              // Format of ACCESS_OPCODE_VENDOR is (opcode, company_id)
              // Again what I have found is, that the two MSB of these values should be 1 (0xC0 or higher).
             // Your OpCode Handler Function should look like this:
            // static void your_opcode_handler_function(access_model_handle_t handle, const access_message_rx_t * p_rx_msg, void * p_args);
    - p_args: Can be any additional arguments
    - publish_timeout_cb: Haven't played around with it yet, currently is just an empty function for me.
    After calling access_model_add you should call access_model_subscription_list_alloc, to allow it to subscribe to addresses. If both of these functions return the status 0 (NRF_SUCCESS) your model is added.
    To send data you can now use the access_model_publish function. In my example I have it bound to a button in the button event handler. The parameter for the function look like this:
    const uint8_t data[] = {0x00};
    const access_message_tx_t msg = {
    .opcode = ACCESS_OPCODE_VENDOR(0xC2, 0xF001), // Format of ACCESS_OPCODE_VENDOR is (opcode, company_id)
    .p_buffer = &data,
    .length = ARRAY_SIZE(data),
    .force_segmented = false,
    .transmic_size = NRF_MESH_TRANSMIC_SIZE_SMALL,
    .access_token = nrf_mesh_unique_token_get()
    access_model_publish(model_handle, &msg);
    Here you can now specify your own data. You could make a Structure with all your Data and a Function which converts it to a uint8_t Array, aswel as a function which can then convert it back from a uint8_t Array to your Structure.
    For most of the Information I used the Mesh SDK Documentation: www.nordicsemi.com/.../index
    I hope this was helpful and if you have any more questions feel free to ask.
    Cheers,
    Kilian
  • Hey Kilian,
    I am also looking into using Bluetooth mesh to pass custom messages for my home sensor network. I am bit of hobbyist and coding is not my strong side yet as I am just getting into trying nordics devboards, could you share your  source code for this project so I would have a reference point to test passing some custom messages back and forth.
    Cheers,
    John.
  • Hi John,
    of Course! In my example i am using two nRF52840 Development Kits. I am using the light_switch example from the mesh sdk. I have a Server as well as a Client. The Client can remotely control the LEDs of the Server. I am currently using my Phone and the nRF-Mesh App to provision these Node. You have to set the Client Publication Address to the Unicast Address of the Server or you could also Publish to a Group Address (0xC0 or higher) and Subscribe with the Server to the same Address.
    Server
    /* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    /* Core */
    #include "nrf_mesh_config_core.h"
    #include "nrf_mesh_gatt.h"
    #include "nrf_mesh_configure.h"
    #include "nrf_mesh.h"
    #include "mesh_stack.h"
    #include "device_state_manager.h"
    #include "access_config.h"
    /* Provisioning and configuration */
    #include "mesh_provisionee.h"
    #include "mesh_app_utils.h"
    /* Models */
    #include "access.h"
    #include "access_reliable.h"
    /* Logging and RTT */
    #include "log.h"
    #include "rtt_input.h"
    /* Example specific includes */
    #include "app_config.h"
    #include "nrf_mesh_config_examples.h"
    #include "light_switch_example_common.h"
    #include "example_common.h"
    #include "ble_softdevice_support.h"
    #include "nrf_delay.h"
    #define APP_STATE_OFF                (0)
    #define APP_STATE_ON                 (1)
    #define APP_UNACK_MSG_REPEAT_COUNT   (2)
    static bool                   m_device_provisioned;
    uint16_t mdl_hndl;
    // Provisioning =============================================================================
    static void device_identification_start_cb(uint8_t attention_duration_s)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called: device_identification_start_cb\n");
        hal_led_mask_set(LEDS_MASK, false);
        hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                         LED_BLINK_ATTENTION_INTERVAL_MS,
                         LED_BLINK_ATTENTION_COUNT(attention_duration_s));
    static void provisioning_aborted_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called: provisioning_aborted_cb\n");
        hal_led_blink_stop();
    static void provisioning_complete_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called: provisioning_complete_cb\n");
    #if MESH_FEATURE_GATT_ENABLED
        /* Restores the application parameters after switching from the Provisioning
         * service to the Proxy  */
        gap_params_init();
        conn_params_init();
        dsm_local_unicast_address_t node_address;
        dsm_local_unicast_addresses_get(&node_address);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
        hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    static void config_server_evt_cb(const config_server_evt_t * p_evt)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called: config_server_evt_cb with Event:%d\n", p_evt->type);
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            node_reset();
    static void my_status_cb(access_model_handle_t model_handle, void * p_args, access_reliable_status_t status)
      __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called my_status_cb [Handle:%04X] [Status:%d]\n", model_handle, status);
      nrf_gpio_pin_write(LED_1, true);
      if(status == 0)   // If the Transmission was successful turn LED 2 of, Else turn LED 2 on
        nrf_gpio_pin_write(LED_2, true);
        nrf_gpio_pin_write(LED_2, false);
    static void button_event_handler(uint32_t button_number)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        uint8_t data[] = {0xFF};
        uint32_t status;
        switch (button_number)  // Depending on the Button Number change the sent data
            case 0:
                data[0] = NRF_GPIO_PIN_MAP(0,13);
            case 1:
                data[0] = NRF_GPIO_PIN_MAP(0,14);
            case 2:
                data[0] = NRF_GPIO_PIN_MAP(0,15);
            case 3:
                data[0] = NRF_GPIO_PIN_MAP(0,16);
          .opcode = ACCESS_OPCODE_VENDOR(0xC2, 0xF001), // Build the normal Message, with the Opcode that the Receiver should execute
          .p_buffer = &data,
        const access_reliable_t reliable_msg = {
        .model_handle = mdl_hndl,                       // Build the reliable Message and define the Opcode that should be in the return
        .message = msg,                                 // in this case 0xC3 which corresponds to the reply_handle function
        .reply_opcode = ACCESS_OPCODE_VENDOR(0xC3, 0xF001),
        .timeout = SEC_TO_US(5),                        // Timeout is set to 5s. Minimum is 2s and Maximum is 5s (i think)
        .status_cb = my_status_cb                       // The Status Callback is called, either when an answer is received or the Timeout occured
        nrf_gpio_pin_write(LED_1, false);
        if(access_reliable_model_is_free(mdl_hndl))
          status = access_model_reliable_publish(&reliable_msg); // Send the reliable Message
          __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "\nSend Status is %d\nModel Handle is %04X\n", status, mdl_hndl);
          if (status != NRF_SUCCESS)
    static void rtt_input_handler(int key)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called: rtt_input_handler\n");
        if (key >= '0' && key <= '3')
            uint32_t button_number = key - '0';
            button_event_handler(button_number);
    static void publish_timeout_handle()
    static void publish_interval_cb()
    // Model ###########################################################################################################
    static void status_handle(access_model_handle_t handle, const access_message_rx_t * p_rx_msg, void * p_args)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called status_handle [Handle:%04X] \n", handle);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "[Data:%02X] \n", p_rx_msg->p_data[0]);
    static void reply_handle(access_model_handle_t handle, const access_message_rx_t * p_rx_msg, void * p_args)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called reply_handle [Handle:%04X] \n", handle);
        {ACCESS_OPCODE_VENDOR(0xC1, 0xF001), status_handle}, // The Opcodes can be defined by you, but I think the two MSB have to be a 1 (0xC0 and above)
        {ACCESS_OPCODE_VENDOR(0xC3, 0xF001), reply_handle},  // Company ID is 0xF001
    static void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
            .model_id = ACCESS_MODEL_VENDOR(0xFFAA, 0xF001),           // My Model ID is 0xFFAA and Company ID 0xF001
            .element_index = 0,                                        // You can define these yourself, but I think the two MSB have to be a 1 (0xC000 and above)
            .p_opcode_handlers = m_opcode_handlers,
            .p_args = NULL,
            .publish_timeout_cb = publish_interval_cb                  // I don't really know what this function is used for...
        uint32_t status = access_model_add(&add_params, &mdl_hndl);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "\nInit Status is %d\nModel Handle is %04X\n", status, mdl_hndl);
        if (status == NRF_SUCCESS)
            status = access_model_subscription_list_alloc(mdl_hndl);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "\nAllocation Status is %d\nModel Handle is %04X\n", status, mdl_hndl);
    static void mesh_init(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called: mesh_init\n");
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = NULL,
            .models.models_init_cb   = models_init_cb,          // Here is the Reference to the Model Init Function
            .models.config_server_cb = config_server_evt_cb
        ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
    static void initialize(void)
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
    static void start(void)
        rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_complete_cb = provisioning_complete_cb,
                .prov_device_identification_start_cb = device_identification_start_cb,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = provisioning_aborted_cb,
                .p_device_uri = EX_URI_LS_CLIENT
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
        ERROR_CHECK(mesh_stack_start());
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
        initialize();
        start();
        for (;;)
            (void)sd_app_evt_wait();
    Client
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    /* Core */
    /* Models */
    #include "access.h"
    #include "log.h"
    uint16_t mdl_hndl;
        gap_params_init();
        conn_params_init();
            node_reset();
        uint32_t status;
            case 0:
            case 1:
            case 2:
            case 3:
          .p_buffer = &data,
            .p_args = NULL,
        hal_leds_init();
    #if BUTTON_BOARD
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
        initialize();
        start();
        for (;;)
    If you have anymore questions feel free to ask.
    Cheers
    Kilian
  • are server and client using same code? is it because you are not using light switch model as a base?
  • No sorry, I uploaded the same code twice, probably because they are both called main.c.
    This is the Code for the Server:
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    /* Core */
    #include "proxy.h"
    /* Models */
    #include "generic_onoff_server.h"
    #include "log.h"
    #define ONOFF_SERVER_0_LED          (BSP_LED_0)
    #define APP_ONOFF_ELEMENT_INDEX     (0)
    uint16_t mdl_hndl;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Called: config_server_evt_cb\n")
            node_reset();
    static void toggle_led(uint32_t pin)
      if(hal_led_pin_get(pin))
        hal_led_pin_set(pin, false);
        hal_led_pin_set(pin, true);
        uint32_t status;
            case 0:
                data[0] = 0x00;
            case 1:
                data[0] = 0x01;
            case 2:
                data[0] = 0x02;
            case 3:
                data[0] = 0x03;
          .opcode = ACCESS_OPCODE_VENDOR(0xC1, 0xF001),
          .p_buffer = data,
        status = access_model_publish(mdl_hndl, &msg);
    static void app_rtt_input_handler(int key)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "RTT Received: %d \n", key)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
        gap_params_init();
        conn_params_init();
    static void blink_leds()
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "[Source:%02X] \n", p_rx_msg->meta_data.src.value);
        toggle_led(p_rx_msg->p_data[0]);
          .opcode = ACCESS_OPCODE_VENDOR(0xC3, 0xF001),   // Build the Answer. I just noticed that i probably get the Reply-Opcode from the received Message...
          .p_buffer = &data,
        if(access_reliable_model_is_free())
          uint32_t status = access_model_reply(handle, p_rx_msg, &msg);  // Send the Answer
          __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Send Status is %d\n", status);
        {ACCESS_OPCODE_VENDOR(0xC2, 0xF001), status_handle},
            .model_id = ACCESS_MODEL_VENDOR(0xFFAB, 0xF001),            // Probably does no have an impact on the functionality
            .element_index = 0,                  // Parameter passed to this function
            .p_opcode_handlers = &m_opcode_handlers[0],      // Bind a function to an OP Code. Are OP Codes received be server?
            .opcode_count = ARRAY_SIZE(m_opcode_handlers),   // Size if opcode_handler array
            .p_args = NULL,                              // Parameter passed to this function
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
        hal_leds_init();
    #if BUTTON_BOARD
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
        rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
                .p_device_uri = EX_URI_LS_SERVER
        initialize();
        start();
        for (;;)
    But yes technically it is possible to have a Node act as both a client and a server. For that you would just need to merge the two Models to one.
