NRF LOG on UART not working
I modified the UART example to work on different pins i.e. pin 17 and 15 on custom board. When I use printf() to print logs, it works. If I use the NRF LOG to print, it doesn't work.
What possibly could go wrong?
I have set NRF_LOG_ENABLED 1 in sdk_config.h
I found something similar but didn't work out.
Also, I don't have pin RTS PIN and CTS PIN connected so what value shall I assign them in app_uart_comm_params_t?
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup uart_example_main main.c
 * @ingroup uart_example
 * @brief UART Example Application main file.
 * This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//#include "nrf_log_default_backends.h"
#include "nrf_gpio.h"
#include "nrf_drv_gpiote.h"
//#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
/* When UART is used for communication with the host do not use flow control.*/
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
/**@brief   Function for handling uart events.
 * @details This function will receive a single character from the uart module and append it to
 *          a string. The string will be be sent over uart when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
		static uint8_t data_array[255];
    static uint8_t index = 0;
		switch (p_event->evt_type)
			case APP_UART_DATA_READY:
						index++;
						if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= 254))
								if (index > 1)
                    NRF_LOG_HEXDUMP_INFO(data_array, index);
									printf("data_array: %s", data_array);
								index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
	    ret_code_t err_code;
      const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_event_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
    uart_init();
		printf("\r\nUART example started.\r\n");
    APP_ERROR_CHECK(nrf_drv_gpiote_init());
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    APP_ERROR_CHECK(nrf_drv_gpiote_out_init(23, &out_config));
    nrf_drv_gpiote_out_clear(23);
		NRF_LOG_INFO("HEY FROM NRF LOG!!!");
    while (true)
				__WFE();
				UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
sdk_config.h
nRF52840, SDK 15.2, Keil
