nRF9160 Custom Board won't jump to application correctly.
I've been developing an application with the nRF9160 dev kit. We have just received the first rev of our custom hardware with an nRF9160 on it. I am trying to program the "secure_boot" application as well as our main application onto the custom board.
I can successfully program the "secure_boot" sample app and am getting the correct debug outputs. I can also successfully program my custom application. However, the bootloader can't successfully jump to my application. After setting some breakpoints I can see that it's throwing an error when calling this line of the "secure_boot" application:
Line 407 (main.c):        reset_ns()
My Target Output in SES displays: "Stopped by vector catch"
My application stops at line 97 of fault_s.S:   eors.n r0, r0
When I click "Attach Debugger" in my main application's solution I get this debug output:
***** HARD FAULT *****
Fault escalation (see below)
***** BUS FAULT *****
Precise data bus error
BFAR Address: 0x50008120
***** Hardware exception *****
Current thread ID = 0x200205f4
Faulting instruction address = 0x0
Fatal fault in ISR! Spinning...
Here are the steps I am taking:
(It works fine on the dev board but breaks on my custom board)
1. Erase all from the target
2. Program secure_boot
3. Program my application
Jack
  • I'm actually getting a very similar error with my custom board and followed similar steps.  Programmed secure boot and then programmed a modified at_client application,.  I then power cycled the unit and I get virtually the same error.  I'm using a terminal program with a USB->serial bridge on the UART ports, this is what's output over the UART:
    Secure Boot: SPU: set SRAM region 30 as Non-Secure
    Secure Boot: SPU: set SRAM region 31 as Non-Secure
    Secure Boot: configure peripherals
    Secure Boot: MSP_NS 200265f0
    Secure Boot: prepare to jump to Non-Secure image
    Current thread ID = 0x20023130
    Any ideas?
    How did you modify the at_client?
    If you are using another UART instance, it must be enabled in your prj.conf file. Here's an example for UART1:
    CONFIG_UART_1_NRF_UARTE=y
    Håkon
  • All I did was reassign the UART ports to different pins so I can use a USB to serial bridge. I modified it as described in this thread: https://devzone.nordicsemi.com/f/nordic-q-a/44114/continuous-wave-for-nrf9160
    It worked fine on the development board (and for that I did not modify the prj.conf file), but then loading it onto my prototype board I get the error above.
    After reading your response I did go back and update the prj.conf file but that did not make a difference.  I still get the same error.
  • Actually, I just solved the issue.  I needed to update the modem FW.
    It wasn't clear to me earlier that 'Modem FW' was the dfu and not the application or secure boot firmware.
