Integrating NUS service in ble_app_relay_rscs
I am trying to add Nordic UART service(NUS) in ble_app_relay_rscs, but after adding nus service in application device is not advertising and there is no print in serial terminal also.
Can I get any example which is with nordic service and ble_central and ble_peripheral modes together? Else may I know the reason behind this issue?
  • Can I get any example which is with nordic service and ble_central and ble_peripheral modes together? Else may I know the reason behind this issue?
     I think the ble_app_hrs_rscs_relay example would be the most suited BLE Peripheral and Central example we have.
     To find the reason behind this I suggest that you try to debug your application, to find out what is going wrong.
    Joakim.
  • Hi Joakim,
    I have debugged my code, it's not entering into advertising init(). I am using SDk14 for development
    I have attached my code for your reference. Pls have a look into it.
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE Heart Rate and Running speed Relay application main file.
     * @detail This application demonstrates a simple "Relay".
     * Meaning we pass on the values that we receive. By combining a collector part on
     * one end and a sensor part on the other, we show that the s130 can function
     * simultaneously as a central and a peripheral device.
     * In the figure below, the sensor ble_app_hrs connects and interacts with the relay
     * in the same manner it would connect to a heart rate collector. In this case, the Relay
     * application acts as a central.
     * On the other side, a collector (such as Master Control panel or ble_app_hrs_c) connects
     * and interacts with the relay the same manner it would connect to a heart rate sensor peripheral.
     * Led layout:
     * LED 1: Central side is scanning       LED 2: Central side is connected to a peripheral
     * LED 3: Peripheral side is advertising LED 4: Peripheral side is connected to a central
     * @note While testing, be careful that the Sensor and Collector are actually connecting to the Relay,
     *       and not directly to each other!
     *    Peripheral                  Relay                    Central
     *    | Heart  |        | Heart     |   Heart  |        |           |
     *    | Rate   | -----> | Rate     -|-> Rate   | -----> | Collector |
     *    | Sensor |        | Collector |   Sensor |        |           |
     *    +--------+        +-----------|   and    |        +-----------+
     *                      | Running   |   Running|
     *    +--------+        | Speed    -|-> Speed  |
     *    | Running|------> | Collector |   Sensor |
     *    | Speed  |        +-----------|----------+
     *    | Sensor |
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "peer_manager.h"
    #include "app_timer.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "ble.h".
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    #include "ble_nus.h"
    #include "ble_nus_c.h"
    #include "ble_conn_state.h"
    #include "nrf_fstorage.h"
    #include "fds.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
    #define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
    #define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
    #define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
    #define DEVICE_NAME                     "Relay"                                     /**< Name of device used for advertising. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */
    #define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout in units of seconds. */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size in octets. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size in octets. */
    #define SCAN_INTERVAL                   0x00A0                                      /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                     0x0050                                      /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_TIMEOUT                    0
    #define MIN_CONNECTION_INTERVAL         (uint16_t) MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL         (uint16_t) MSEC_TO_UNITS(30, UNIT_1_25_MS)  /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY                   0                                           /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT             (uint16_t) MSEC_TO_UNITS(4000, UNIT_10_MS)  /**< Determines supervision time-out in units of 10 milliseconds. */
    #define UUID16_SIZE                     2                                           /**< Size of a UUID, in bytes. */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
    #define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
    /**@brief   Priority of the application BLE event handler.
     * @note    You shouldn't need to modify this value.
    #define APP_BLE_OBSERVER_PRIO           1
    /**@brief Macro to unpack 16bit unsigned UUID from an octet stream.
    #define UUID16_EXTRACT(DST, SRC) \
        do                           \
            (*(DST))   = (SRC)[1];   \
            (*(DST)) <<= 8;          \
            (*(DST))  |= (SRC)[0];   \
        } while (0)
    /**@brief Variable length data encapsulation in terms of length and pointer to data. */
    typedef struct
        uint8_t  * p_data;   /**< Pointer to data. */
        uint16_t   data_len; /**< Length of data. */
    } data_t;
    BLE_NUS_DEF(m_nus);                                                 /**< Heart rate service instance. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< Heart rate service client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_discovery);                               /**< Database discovery module instances. */
    static uint16_t m_conn_handle_nus_c  = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the NUS central application */
    //static uint16_t m_conn_handle_rscs_c = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the RSC central application */
    static uint16_t m_conn_handle_to_disc = BLE_CONN_HANDLE_INVALID;    /**< The connection handle on which to retry the DB discovery. */
    static bool     m_retry_db_disc;                                    /**< Retry DB discovery if attempted while busy. */
    static bool     m_do_retry_db_disc;
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief names which the central applications will scan for, and which will be advertised by the peripherals.
     *  if these are set to empty strings, the UUIDs defined below will be used
    static char const m_target_periph_name[] = "";
    /**@brief UUIDs which the central applications will scan for if the name above is set to an empty string,
     * and which will be advertised by the peripherals.
    static ble_uuid_t m_adv_uuids[] =
        {BLE_UUID_NUS_SERVICE,        BLE_UUID_TYPE_VENDOR_BEGIN}
    /**@brief Parameters used when scanning. */
    static ble_gap_scan_params_t const m_scan_params =
        .active   = 1,
        .interval = SCAN_INTERVAL,
        .window   = SCAN_WINDOW,
        .timeout  = SCAN_TIMEOUT,
        #if (NRF_SD_BLE_API_VERSION <= 2)
            .selective   = 0,
            .p_whitelist = NULL,
        #if (NRF_SD_BLE_API_VERSION >= 3)
            .use_whitelist = 0,
    /**@brief Connection parameters requested for connection. */
    static ble_gap_conn_params_t const m_connection_param =
        MIN_CONNECTION_INTERVAL,
        MAX_CONNECTION_INTERVAL,
        SLAVE_LATENCY,
        SUPERVISION_TIMEOUT
    /**@brief Function to handle asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Parses advertisement data, providing length and location of the field in case
     *        matching data is found.
     * @param[in]  Type of data to be looked for in advertisement data.
     * @param[in]  Advertisement report length and pointer to report.
     * @param[out] If data type requested is found in the data report, type data length and
     *             pointer to data will be populated here.
     * @retval NRF_SUCCESS if the data type is found in the report.
     * @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
    static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata)
        uint32_t   index = 0;
        uint8_t  * p_data;
        p_data = p_advdata->p_data;
        while (index < p_advdata->data_len)
            uint8_t field_length = p_data[index];
            uint8_t field_type   = p_data[index + 1];
            if (field_type == type)
                p_typedata->p_data   = &p_data[index + 2];
                p_typedata->data_len = field_length - 1;
                return NRF_SUCCESS;
            index += field_length + 1;
        return NRF_ERROR_NOT_FOUND;
    /**@brief Function for initiating scanning.
    static void scan_start(void)
        ret_code_t err_code;
        (void) sd_ble_gap_scan_stop();
        err_code = sd_ble_gap_scan_start(&m_scan_params);
        // It is okay to ignore this error since we are stopping the scan anyway.
    /**@brief Function for initiating advertising and scanning.
    static void adv_scan_start(void)
        //check if there are no flash operations in progress
        if (!nrf_fstorage_is_busy(NULL))
            // Start scanning for peripherals and initiate connection to devices which
            // advertise Heart Rate or Running speed and cadence UUIDs.
            scan_start();
            // Turn on the LED to signal scanning.
            bsp_board_led_on(CENTRAL_SCANNING_LED);
            // Start advertising.
            err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        switch (p_evt->evt_id)
            case PM_EVT_BONDED_PEER_CONNECTED:
                NRF_LOG_INFO("Connected to a previously bonded device.");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                adv_scan_start();
            } break;
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // The local database has likely changed, send service changed indications.
                pm_local_database_has_changed();
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    /**@brief Function for handling characters received by the Nordic UART Service.
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
        static uint16_t index = 0;
        uint32_t ret_val;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling NUS Client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
     * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
    /**@brief Function for searching a given name in the advertisement packets.
     * @details Use this function to parse received advertising data and to find a given
     * name in them either as 'complete_local_name' or as 'short_local_name'.
     * @param[in]   p_adv_report   advertising data to parse.
     * @param[in]   name_to_find   name to search.
     * @return   true if the given name was found, false otherwise.
    static bool find_adv_name(ble_gap_evt_adv_report_t const * p_adv_report, char const * name_to_find)
        data_t     adv_data;
        data_t     dev_name;
        // Initialize advertisement report for parsing
        adv_data.p_data   = (uint8_t *)p_adv_report->data;
        adv_data.data_len = p_adv_report->dlen;
        //search for advertising names
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME, &adv_data, &dev_name);
        if (err_code == NRF_SUCCESS)
            if (memcmp(name_to_find, dev_name.p_data, dev_name.data_len)== 0)
                return true;
            // Look for the short local name if it was not found as complete
            err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME,
                                        &adv_data,
                                        &dev_name);
            if (err_code != NRF_SUCCESS)
                return false;
            if (memcmp(m_target_periph_name, dev_name.p_data, dev_name.data_len)== 0)
                return true;
        return false;
    /**@brief Function for searching a UUID in the advertisement packets.
     * UUID in them.
     * @param[in]   uuid_to_find   UUIID to search.
     * @return   true if the given UUID was found, false otherwise.
    static bool find_adv_uuid(ble_gap_evt_adv_report_t const * p_adv_report, uint16_t uuid_to_find)
        data_t     adv_data;
        data_t     type_data;
        // Initialize advertisement report for parsing.
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE,
                                    &adv_data,
                                    &type_data);
            // Look for the services in 'complete' if it was not found in 'more available'.
            err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE,
                                        &adv_data,
                                        &type_data);
                // If we can't parse the data, then exit.
                return false;
        // Verify if any UUID match the given UUID.
        for (uint32_t i = 0; i < (type_data.data_len / UUID16_SIZE); i++)
            uint16_t extracted_uuid;
            UUID16_EXTRACT(&extracted_uuid, &type_data.p_data[i * UUID16_SIZE]);
            if (extracted_uuid == uuid_to_find)
                return true;
        return false;
    /**@brief   Function for handling BLE events from central applications.
     * @details This function parses scanning reports and initiates a connection to peripherals when a
     *          target UUID is found. It updates the status of LEDs used to report central applications
     *          activity.
    static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            // Upon connection, check which peripheral has connected (HR or RSC), initiate DB
            // discovery, update LEDs status and resume scanning if necessary.
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Central connected");
                // If no Heart Rate sensor or RSC sensor is currently connected, try to find them on this peripheral.
                if   (m_conn_handle_nus_c  == BLE_CONN_HANDLE_INVALID)
                    NRF_LOG_INFO("Attempt to find NUS on conn_handle 0x%x", p_gap_evt->conn_handle);
                    if (m_db_discovery.discovery_in_progress)
                        NRF_LOG_INFO("DB discovery is already in progress. Will retry later.")
                        m_retry_db_disc = true;
                        m_conn_handle_to_disc = p_gap_evt->conn_handle;
                        memset(&m_db_discovery, 0x00, sizeof(m_db_discovery));
                        err_code = ble_db_discovery_start(&m_db_discovery, p_gap_evt->conn_handle);
                // Update LEDs status, and check if we should be looking for more peripherals to connect to.
                bsp_board_led_on(CENTRAL_CONNECTED_LED);
                if (ble_conn_state_n_centrals() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                    bsp_board_led_off(CENTRAL_SCANNING_LED);
                    // Resume scanning.
                    scan_start();
            } break; // BLE_GAP_EVT_CONNECTED
            // Upon disconnection, reset the connection handle of the peer which disconnected,
            // update the LEDs status and start scanning again.
                if (p_gap_evt->conn_handle == m_conn_handle_nus_c)
                    NRF_LOG_INFO("NUS central disconnected (reason: %d)",
                                 p_gap_evt->params.disconnected.reason);
                    // Start scanning
                    scan_start();
                    // Update LEDs status.
                if (ble_conn_state_n_centrals() == 0)
                    bsp_board_led_off(CENTRAL_CONNECTED_LED);
            } break; // BLE_GAP_EVT_DISCONNECTED
            case BLE_GAP_EVT_ADV_REPORT:
                if (strlen(m_target_periph_name) != 0)
                    if (find_adv_name(&p_gap_evt->params.adv_report, m_target_periph_name))
                        // Initiate connection.
                        err_code = sd_ble_gap_connect(&p_gap_evt->params.adv_report.peer_addr,
                                                      &m_scan_params,
                                                      &m_connection_param,
                                                      APP_BLE_CONN_CFG_TAG);
                            NRF_LOG_INFO("Connection Request Failed, reason %d", err_code);
                    // We do not want to connect to two peripherals offering the same service, so when
                    // a UUID is matched, we check that we are not already connected to a peer which
                    // offers the same service.
                    if    (find_adv_uuid(&p_gap_evt->params.adv_report, BLE_UUID_NUS_SERVICE)
                            && (m_conn_handle_nus_c == BLE_CONN_HANDLE_INVALID))
    //                    || (find_adv_uuid(&p_gap_evt->params.adv_report, BLE_UUID_RUNNING_SPEED_AND_CADENCE)
    //                        && (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)))
                                                      &m_scan_params,
                            NRF_LOG_WARNING("Connection Request Failed, reason %d", err_code);
            } break; // BLE_GAP_ADV_REPORT
            case BLE_GAP_EVT_TIMEOUT:
                // We have not specified a timeout for scanning, so only connection attemps can timeout.
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                            &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
    #if defined(S132)
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief   Function for handling BLE events from peripheral applications.
     * @details Updates the status LEDs used to report the activity of the peripheral applications.
    static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
                NRF_LOG_INFO("Peripheral connected");
                bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
                bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
                NRF_LOG_INFO("Peripheral disconnected");
                bsp_board_led_off(PERIPHERAL_CONNECTED_LED);
    #if defined(S132)
            } break;
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gap_evt.conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
                bsp_board_led_on(PERIPHERAL_ADVERTISING_LED);
            } break;
            case BLE_ADV_EVT_IDLE:
                ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
            } break;
    /**@brief Function for checking if a bluetooth stack event is an advertising timeout.
     * @param[in] p_ble_evt Bluetooth stack event.
    static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt)
      return (   (p_ble_evt->header.evt_id == BLE_GAP_EVT_TIMEOUT)
              && (p_ble_evt->evt.gap_evt.params.timeout.src == BLE_GAP_TIMEOUT_SRC_ADVERTISING));
    static void db_discovery_retry(void)
        m_retry_db_disc = false;
        NRF_LOG_INFO("Retrying DB discovery on handle 0x%x.", m_conn_handle_to_disc);
        ret_code_t err_code = ble_db_discovery_start(&m_db_discovery, m_conn_handle_to_disc);
        uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
        uint16_t role        = ble_conn_state_role(conn_handle);
        // Based on the role this device plays in the connection, dispatch to the right handler.
        if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
            on_ble_peripheral_evt(p_ble_evt);
        else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
            on_ble_central_evt(p_ble_evt);
        if (m_do_retry_db_disc)
            m_do_retry_db_disc = false;
            db_discovery_retry();
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for initializing the NUS Client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler = ble_nus_c_evt_handler;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
     * @details Initializes the SoftDevice and the BLE event interrupts.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @param[out] p_erase_bonds  Will be true if the clear bonding button was pressed to
     *                            wake the application up.
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, NULL);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        gap_conn_params.min_conn_interval = MIN_CONNECTION_INTERVAL;
        gap_conn_params.max_conn_interval = MAX_CONNECTION_INTERVAL;
        gap_conn_params.conn_sup_timeout  = SUPERVISION_TIMEOUT;
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        cp_init.start_on_notify_cccd_handle    = BLE_CONN_HANDLE_INVALID; // Start upon connection.
        cp_init.disconnect_on_fail             = true;
        cp_init.evt_handler                    = NULL;  // Ignore events.
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
       ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
        if (   (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE)
            && (m_retry_db_disc)
            && (m_conn_handle_to_disc != BLE_CONN_HANDLE_INVALID))
            // DB discovery cannot be restarted directly here because the
            // database discovery structure would need to be zeroed, however it is still
            // needed by the module (it might have pending events to send).
            // Let's set a flag and re-run DB discovery when we receive the next BLE event.
            NRF_LOG_INFO("DB discovery can be retried.");
            m_do_retry_db_disc = true;
     * @brief Database discovery initialization.
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
     * @details Initialize the Heart Rate, Battery and Device Information services.
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    /**@brief Function for initializing logging.
    static void log_init(void)
    /**@brief Function for initializing the timer.
    static void timer_init(void)
    /** @brief Function to sleep until a BLE event is received by the application.
    static void power_manage(void)
        ret_code_t err_code = sd_app_evt_wait();
        bool erase_bonds;
        log_init();
        timer_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
    	  uart_init();
        conn_params_init();
        db_discovery_init();
        peer_manager_init();
    	  nus_c_init();
        services_init();
        advertising_init();
        if (erase_bonds == true)
            // Scanning and advertising is done upon PM_EVT_PEERS_DELETE_SUCCEEDED event.
            delete_bonds();
            // Scanning and advertising is done by
            adv_scan_start();
        NRF_LOG_INFO("Relay example started.");
        for (;;)
                // Wait for BLE events.
                power_manage();
  • Pls check the above code and share your comments.
  • Hi.
    Sorry about the late reply.
    There is quite a few changes to the code. I didn't immediately see anything that stood out in the code.
    You say that it is not entering into advertising_init(). Do you know more specific where you run into an error, or where the code stops?
    Best regards.
