Button release event?
Am I right in thinking that the button handler only causes an event for a button press(although I realize it is possible to configure the button such that a release is interpreted as a press), rather than a change of state? I expect I can work around this, but would it be possible to re-configure the button in the event handler, such that events would be generated on both press and release?
  • Hi John,
    From SDK v6.0 and newer, app_button will give you an event on both button press and release. Here's an example snippet:
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        if (button_action == APP_BUTTON_PUSH)
            switch (pin_no)
    			case MY_BUTTON:
    				do_something_on_press();
                    APP_ERROR_HANDLER(pin_no);
        else if (button_action == APP_BUTTON_RELEASE)
            switch (pin_no)
    			case MY_BUTTON:
    				do_something_on_release();
    Cheers, Håkon
  • That's great news, Håkon, and many thanks for the prompt answer.
