Issue while debugging ble_app_uart program on nRF52832 in IAR IDE version 8.20.1.
I am facing issues in debugging  ble_app_uart program available in nRF5 SDK.  I am trying to debug it on IAR workbench using Jlink PLUS debugger in SWD mode.
I could connect and download the program. but whenever program calls sd_softdevice_enable() function for enabling soft device it hangs.
Details about setup.
  • controller       : nRF52832 (512KB flash) on Fanstel module BC832
  • Debugger      : Segger Jlink Plus in 6 pin SWD mode.
  • IDE                : IAR workbench v 8.20.1
  • SDK version  : nRF5_SDK_15.2.0_9412b96
  • Test program : nRF5_SDK_15.2.0_9412b96\examples\ble_peripheral\ble_app_uart
I have added additional command to download Soft device \nRF5_SDK_15.2.0_9412b96\components\softdevice\s132\hex\s132_nrf52_6.1.0_softdevice.hex at address location 0x0000
I could program and debug normal application that does not involve Soft Device. e.g. nRF5_SDK_15.2.0_9412b96\examples\peripheral\uart.
When program involves soft device; after accessing softdevice related APIs, IDE hangs and we can not further debug the program.
  • Hi.
    It looks like the Fanstel BC832 does not have any on-board crystal, it therefore "hangs" when you call sd_softdevice_enable().
    You have to edit a define in sdk_config.h
    Change this:
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 1
    To this:
    #define NRF_SDH_CLOCK_LF_SRC 0
    Try this.
    Andreas
  • Thanks for the input, but with the option NRF_SDH_CLOCK_LF_SRC set to 0,  I am getting following
    Error[Pe035]: #error directive: Please select NRF_CLOCK_LF_ACCURACY_500_PPM when using NRF_CLOCK_LF_SRC_RC C:\Users\cpendhs\git\ncs\nRF5_SDK_15.2.0_9412b96\components\softdevice\common\nrf_sdh.c 78
    for this issue I am left with 2 option
    Option 1
    #define NRF_SDH_CLOCK_LF_SRC NRF_CLOCK_LF_SRC_RC
    //AND
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY NRF_CLOCK_LF_ACCURACY_500_PPM
    Or second option would be
    #define NRF_SDH_CLOCK_LF_SRC NRF_CLOCK_LF_SRC_SYNTH
    What would be better option out of these two.
