Button push and release event BSP
Hi all,
I have created a custom board file for my pcb that uses the nRF52832 (rigado module). I have 10 buttons attached to the board and am successfully reading a button press on all (using BSP). It also nicely handles the BLE advertising and sleep features and the debouncing of course.
How can I detect the button release in the bsp_event_handler below? My goal is to set a bit in m_custom_value[2] which corresponds to a button. If the button is held down, the value won't change, however, when the button is released (upon detecting the release event) the value will be reset.
Kind Regards,
Zoran
m_custom_value[2] is initialized to 0xFF
* @param[in] event Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
ret_code_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle,
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
case BSP_EVENT_KEY_1:
m_custom_value[2] = m_custom_value[2] ^ 0x01;
break; // GL1 button pressed
case BSP_EVENT_KEY_2:
m_custom_value[2] = m_custom_value[2] ^ 0x02;
break; // GL2 button pressed
case BSP_EVENT_KEY_3:
m_custom_value[2] = m_custom_value[2] ^ 0x04;
break; // GL3 button pressed
case BSP_EVENT_KEY_4:
m_custom_value[2] = m_custom_value[2] ^ 0x08;
break; // GL4 button pressed
case BSP_EVENT_KEY_5:
m_custom_value[2] = m_custom_value[2] ^ 0x10;
break; // GL5 button pressed
case BSP_EVENT_KEY_6:
m_custom_value[2] = m_custom_value[2] ^ 0x20;
nrf_gpio_pin_toggle(LED_2);
break; // GL6 button pressed
case BSP_EVENT_KEY_7:
m_custom_value[2] = m_custom_value[2] ^ 0x40;
break; // Saf button pressed
case BSP_EVENT_KEY_8:
m_custom_value[2] = m_custom_value[2] ^ 0x80;
break; // MRel button pressed
case BSP_EVENT_KEY_9:
m_custom_value[3] = m_custom_value[3] ^ 0x01;
break; // MRep button pressed
