I am using two nrf52840 DK boards, I tried to run TWI scanner example on one of the boards of SDK 15.0 example. I'm not getting the other device address it is giving message as "no device detected". I have connected the SCL and SDA pins respectively and given the power supply from the board in which twi scanner example is running to other board with external supply pins(Even if I have connected with two cables for supply independently not getting the address).
Kindly, suggest the possible method to find the address of the nrf52840 board .
