LCOMP/COMP cannot wakeup the device
I use  'nRF5_SDK_15.2.0_9412b96\examples\ble_peripheral\ble_app_uart' as my project base for PCA10040.  The code has its default sleep mode which use 'sleep_mode_enter' function for idle evt in 'on_adv_evt'.  And I add comps like the following content.
static void sensor_timeout_handler(void * p_context)
      UNUSED_PARAMETER(p_context);
    nrf_drv_comp_start(NRF_DRV_COMP_EVT_EN_UP_MASK, NRF_DRV_COMP_SHORT_STOP_AFTER_UP_EVT);
static void comp_event_handler(nrf_comp_event_t event)
    uint32_t                err_code;
    if (event == NRF_COMP_EVENT_UP)
        nrf_gpio_pin_toggle(BSP_LED_2); // just change state of first LED
    //nrf_gpio_pin_toggle(BSP_LED_2); // just change state of first LED
    sensor_count++;
    err_code = app_timer_start(m_sensor_timer_id, sensor_time_intervel, NULL);
 * @brief Initialize COMP driver.
static void comp_init(void)
    uint32_t                err_code;
    nrf_drv_comp_config_t config = NRF_DRV_COMP_DEFAULT_CONFIG(3);
    // initialize LPCOMP driver, from this point LPCOMP will be active and provided
    // event handler will be executed when defined action is detected
    err_code = nrf_drv_comp_init(&config, comp_event_handler);
And I call ' comp_init' in the main function. What should do to wakeup the LCOMP by giving a high voltage pulse to p0.05. But the device cannot wake up from it.
Does anybody caught this issue?
Do you have any advices for let  only LCOMP/COMP wakeup system?
