i need a help
As mentioned in this thread
https://devzone.nordicsemi.com/f/nordic-q-a/18512/directed-advertising-with-pre-shared-irk
in need to do directed advertising with pre shared irk
this is my code where should i add on the peripheral side
#include <stdint.h>
#include <string.h>
#include "ble_advertising.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_soc.h"
#include "nrf_drv_saadc.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_tps.h"
#include "ble_ias.h"
#include "ble_lls.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "ble_ias_c.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble_db_discovery.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
//#include "nrf_ble_scan.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_fstorage.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "NORDIC"
#define APP_BLE_OBSERVER_PRIO 3
#define APP_BLE_CONN_CFG_TAG 1
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(120000)
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(1000, UNIT_1_25_MS)
#define SLAVE_LATENCY 0
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)
//#define APP_ADV_INTERVAL 40
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS)
#define APP_ADV_DURATION 18000
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT 3
#define SEC_PARAM_BOND 1
#define SEC_PARAM_MITM 0
#define SEC_PARAM_LESC 0
#define SEC_PARAM_KEYPRESS 0
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE
#define SEC_PARAM_OOB 0
#define SEC_PARAM_MIN_KEY_SIZE 7
#define SEC_PARAM_MAX_KEY_SIZE 16
#define INITIAL_LLS_ALERT_LEVEL BLE_CHAR_ALERT_LEVEL_NO_ALERT
#define TX_POWER_LEVEL (-8)
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS 600
#define ADC_PRE_SCALING_COMPENSATION 6
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS 270
#define ADC_RES_10BIT 1024
#define DEAD_BEEF 0xDEADBEEF
#define APP_BEACON_INFO_LENGTH 0x17
#define APP_ADV_DATA_LENGTH 0x15
#define APP_DEVICE_TYPE 0x02
#define APP_MEASURED_RSSI 0xC5
#define APP_COMPANY_IDENTIFIER 0x004C
#define APP_MAJOR_VALUE 0x00, 0x02
#define APP_MINOR_VALUE 0x00, 0x02
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO 18
#define UICR_ADDRESS 0x10001080
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
APP_TIMER_DEF(m_battery_timer_id);
BLE_TPS_DEF(m_tps);
BLE_IAS_DEF(m_ias, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_LLS_DEF(m_lls);
BLE_BAS_DEF(m_bas);
BLE_IAS_C_DEF(m_ias_c);
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr);
BLE_ADVERTISING_DEF(m_advertising);
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);
static volatile bool m_is_high_alert_signalled;
static volatile bool m_is_ias_present = false;
static nrf_saadc_value_t adc_buf[2];
static ble_uuid_t m_adv_uuids[] =
{BLE_UUID_IMMEDIATE_ALERT_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_LINK_LOSS_SERVICE, BLE_UUID_TYPE_BLE}
static ble_gap_adv_params_t m_adv_params;
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static uint8_t m_enc_scandata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = m_enc_scandata,
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =
APP_DEVICE_TYPE,
APP_ADV_DATA_LENGTH,
APP_BEACON_UUID,
APP_MAJOR_VALUE,
APP_MINOR_VALUE,
APP_MEASURED_RSSI
static void on_ias_evt(ble_ias_t * p_ias, ble_ias_evt_t * p_evt);
static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
static void on_ias_c_evt(ble_ias_c_t * p_lls, ble_ias_c_evt_t * p_evt);
static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
static void advertising_init(void);
static void advertising_start(bool erase_bonds);
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
nrf_saadc_value_t adc_result;
uint16_t batt_lvl_in_milli_volts;
uint8_t percentage_batt_lvl;
uint32_t err_code;
adc_result = p_event->data.done.p_buffer[0];
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
DIODE_FWD_VOLT_DROP_MILLIVOLTS;
percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_ias_c_on_db_disc_evt(&m_ias_c, p_evt);
static void adc_configure(void)
ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
nrf_saadc_channel_config_t config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
err_code = nrf_drv_saadc_channel_init(0, &config);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
ret_code_t err_code;
err_code = nrf_drv_saadc_sample();
static void timers_init(void)
err_code = app_timer_init();
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
break; // BLE_ADV_EVT_FAST
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
break; // BLE_ADV_EVT_IDLE
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_t scandata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL;
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0;
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
memset(&scandata, 0, sizeof(scandata));
scandata.name_type = BLE_ADVDATA_FULL_NAME;
scandata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scandata.uuids_complete.p_uuids = m_adv_uuids;
ble_gap_addr_t gap_address;
gap_address.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
memcpy(&gap_address.addr, "\xbb\xaa\xcc\xbb\xaa\xAC", sizeof(gap_address.addr));
err_code = sd_ble_gap_addr_set(&gap_address);
err_code = ble_advdata_encode(&scandata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
if (erase_bonds == true){
delete_bonds();
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
///**@brief Function for initializing the Advertising functionality.
// * @details Encodes the required advertising data and passes it to the stack.
// * Also builds a structure to be passed to the stack when starting advertising.
//static void advertising_init(void)
// ret_code_t err_code;
// ble_advertising_init_t init;
// memset(&init, 0, sizeof(init));
// init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
// init.advdata.include_appearance = true;
// init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
// init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
// init.advdata.uuids_complete.p_uuids = m_adv_uuids;
// init.config.ble_adv_fast_enabled = true;
// init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
// init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
// init.evt_handler = on_adv_evt;
// err_code = ble_advertising_init(&m_advertising, &init);
// APP_ERROR_CHECK(err_code);
// ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG);
static void qwr_init(void)
nrf_ble_qwr_init_t qwr_init_obj = {0};
qwr_init_obj.error_handler = nrf_qwr_error_handler;
err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
static void tps_init(void)
ble_tps_init_t tps_init_obj;
memset(&tps_init_obj, 0, sizeof(tps_init_obj));
tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
err_code = ble_tps_init(&m_tps, &tps_init_obj);
static void ias_init(void)
ble_ias_init_t ias_init_obj;
memset(&ias_init_obj, 0, sizeof(ias_init_obj));
ias_init_obj.evt_handler = on_ias_evt;
ias_init_obj.alert_wr_sec = SEC_JUST_WORKS;
err_code = ble_ias_init(&m_ias, &ias_init_obj);
static void lls_init(void)
ble_lls_init_t lls_init_obj;
// Initialize Link Loss Service
memset(&lls_init_obj, 0, sizeof(lls_init_obj));
lls_init_obj.evt_handler = on_lls_evt;
lls_init_obj.error_handler = service_error_handler;
lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
lls_init_obj.alert_level_rd_sec = SEC_JUST_WORKS;
lls_init_obj.alert_level_wr_sec = SEC_JUST_WORKS;
err_code = ble_lls_init(&m_lls, &lls_init_obj);
static void bas_init(void)
ble_bas_init_t bas_init_obj;
memset(&bas_init_obj, 0, sizeof(bas_init_obj));
bas_init_obj.evt_handler = on_bas_evt;
bas_init_obj.support_notification = true;
bas_init_obj.p_report_ref = NULL;
bas_init_obj.initial_batt_level = 100;
bas_init_obj.bl_rd_sec = SEC_OPEN;
bas_init_obj.bl_cccd_wr_sec = SEC_OPEN;
bas_init_obj.bl_report_rd_sec = SEC_OPEN;
err_code = ble_bas_init(&m_bas, &bas_init_obj);
static void ias_client_init(void)
ble_ias_c_init_t ias_c_init_obj;
memset(&ias_c_init_obj, 0, sizeof(ias_c_init_obj));
m_is_high_alert_signalled = false;
ias_c_init_obj.evt_handler = on_ias_c_evt;
ias_c_init_obj.error_handler = service_error_handler;
err_code = ble_ias_c_init(&m_ias_c, &ias_c_init_obj);
qwr_init();
tps_init();
ias_init();
lls_init();
bas_init();
ias_client_init();
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
static void alert_signal(uint8_t alert_level)
switch (alert_level)
case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
NRF_LOG_INFO("No Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
break; // BLE_CHAR_ALERT_LEVEL_NO_ALERT
case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
NRF_LOG_INFO("Mild Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
break; // BLE_CHAR_ALERT_LEVEL_MILD_ALERT
case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
NRF_LOG_INFO("HIGH Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
break; // BLE_CHAR_ALERT_LEVEL_HIGH_ALERT
switch (p_evt->evt_type)
case BLE_IAS_EVT_ALERT_LEVEL_UPDATED:
if (p_evt->p_link_ctx != NULL)
alert_signal(p_evt->p_link_ctx->alert_level);
break; // BLE_IAS_EVT_ALERT_LEVEL_UPDATED
// No implementation needed.
case BLE_LLS_EVT_LINK_LOSS_ALERT:
alert_signal(p_evt->params.alert_level);
break; // BLE_LLS_EVT_LINK_LOSS_ALERT
static void on_ias_c_evt(ble_ias_c_t * p_ias_c, ble_ias_c_evt_t * p_evt)
case BLE_IAS_C_EVT_DISCOVERY_COMPLETE:
// IAS is found on peer. The Find Me Locator functionality of this app will work.
err_code = ble_ias_c_handles_assign(&m_ias_c,
p_evt->conn_handle,
p_evt->alert_level.handle_value);
m_is_ias_present = true;
break; // BLE_IAS_C_EVT_DISCOVERY_COMPLETE
case BLE_IAS_C_EVT_DISCOVERY_FAILED:
// IAS is not found on peer. The Find Me Locator functionality of this app will NOT work.
break; // BLE_IAS_C_EVT_DISCOVERY_FAILED
case BLE_IAS_C_EVT_DISCONN_COMPLETE:
// Disable alert buttons
break; // BLE_IAS_C_EVT_DISCONN_COMPLETE
case BLE_BAS_EVT_NOTIFICATION_ENABLED:
// Start battery timer
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
case BLE_BAS_EVT_NOTIFICATION_DISABLED:
err_code = app_timer_stop(m_battery_timer_id);
break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
// Assign connection handle to the Queued Write module.
err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
// Discover peer's services.
err_code = ble_db_discovery_start(&m_ble_db_discovery,
} break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ias_c.conn_handle,
case BSP_EVENT_KEY_0:
if (m_is_ias_present)
if (!m_is_high_alert_signalled)
err_code =
ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_HIGH_ALERT);
err_code = ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_NO_ALERT);
if (err_code == NRF_SUCCESS)
m_is_high_alert_signalled = !m_is_high_alert_signalled;
else if (
(err_code != NRF_ERROR_RESOURCES)
(err_code != NRF_ERROR_NOT_FOUND)
} break;
case BSP_EVENT_KEY_1:
NRF_LOG_INFO("Alert Off.");
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
///**@brief Function for starting advertising.
//static void advertising_start(bool erase_bonds)
// if (erase_bonds == true){
// delete_bonds();
// // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
// else
// uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void tx_power_set(void)
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
adc_configure();
gap_params_init();
gatt_init();
advertising_init();
db_discovery_init();
services_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Proximity example started.");
advertising_start(erase_bonds);
tx_power_set();
// Enter main loop.
for (;;)
idle_state_handle();
thank you
