DFU Issue: Getting "DFU failed with error: Cannot convert, number too large: 281474976710656."
I just recently started getting an error when I try to perform a DFU. I have been able to perform the DFU successfully many times in the past, but have been running into a new issue. The issue is that when starting a DFU onto a nrf52832 that already has an application loaded, I'm getting the error "DFU failed with error: Cannot convert, number too large: 281474976710656." on the nRF Connect log.
If I start with an erased nRF52832, load the bootloader using Segger Embedded Studio, then do a DFU, I can load and run the app without issue. The issue occurs once I try to use DFU again to update with a new file.
I haven't changed any of the DFU or bootloader related code from when it was working to when I started seeing the issues.
I'd greatly appreciate any suggestions or pointing to the right direction.
Thank you!
Setup: Windows 10, Segger Embedded Studio, Nordic nRF Connect with BMD-300 Eval Kit, SDK v15.2, nRF52832
