Questions about the AoA/AoD in 52811
Hi Sir,
We want to know about AoA /AoD applications for 52811, and there are some question as below.
1. Is there a difference between BT 5.1 and BT 5.0 from the perspective of HW? If so, what is the main difference?
2. For the existing BT 5.0 chip (52840/52832/52810), is there any opportunity to use 5.1 AoA/AoD indoor positioning application after Upgrade FW (SDK)? if yes, Any schedule for the SDK release?
3. Since the RAM size of 52811 is not big, Is the build-in RAM size (24KB) enough for AoA/AoD application for 52811?
4. Which application loading will be heavier between the AoA and AoD in 52811?
5. If AoA works as wireless access point (AP), How to design the multi-antenna in RF port? will Nordic announce the reference schematic design of multi-antenna for 52811?
Thank you.
BRs, Han
  • Hi Han,
    1. The AoA/AoD feature of 5.1 requires different HW from 5.0, it is otherwise similar and on-air compatible. The difference is the ability to retrieve IQ data from the radio as specified in the BT 5.1 spec.
    2. No, 52840/52832/52810 do not support retrival of the IQ data, required for AoA/AoD.
    3. Yes.
    4. Not possible to say at this moment, I would expect it to be about equally heavy.
    5. The device that is to support AoA/AoD needs an antenna array, and an external RF switch to switch between the antennas. The radio has a built in mechanism to control the switch. We will be coming with algorithms and reference designs later this year. There will probably be some freedom when it comes to the antenna array design, obviously depending on how the algorithms turn out, but as I understand it the goal is that each designer will be able to calibrate the algorithms to their array and their product.
    Andreas
  • Hi Andreas,
    Thanks for quick response.
    More questions.
    6. What kind of AoA/AoD role can be implement in 52811? AoA Transmitter/Receiver? AoD Transmitter/Receiver?
    Thank you.
    BRs, Han
    6. AoA = Angle of arrival, meaning receive. AoD = Angle or departure = Transmit. nRF52811 can implement both.
    Andreas
