Can the nRF52840 MCU power LED direct?
I'm planning to connect The nRF52840 MCU GPIO in series to a 1.8V 20mA LED and a Resistor then to ground.
Would the current from the MCU be sufficient to power the LED ?
Thank you
  • Both GPIO codes don't work
    As with debugging any problem, you need to take this one step at a time.
    For a start, have you tried using an unmodified SDK example on a DevKit? That is always the best place to start - giving you a known-good basis to work from.
    In your circuit:
    1. If you disconnect the LED cathode from the port pin, and ground it - does the LED light.
    2. With the LED disconnected, can you see the pin level changing; eg, on a scope or meter?
    3. Run you code in the debugger - is it actually reaching the point(s) that configure the pins, & change the output?
    How To Debug
