Updating PWM output signal
May be it's some what basic but I'm not able to update my pwm value.
I'm using sdk 14.02 with softdevice in SES.
This is my code:
PWM Config:
static uint16_t const              base_pwm_top  = 10000;
static uint16_t const              base_pwm_step = 100;
static uint8_t                       pwm_phase;
static nrf_pwm_values_individual_t   pwm_seq_values;
static nrf_pwm_sequence_t const      pwm_seq =
    .values.p_individual = &pwm_seq_values,
    .length              = NRF_PWM_VALUES_LENGTH(pwm_seq_values),
    .repeats             = 0,
    .end_delay           = 0
PWM init:
  //Base PWM config
    ret_code_t err_code_base;
    // configure nrf driver
    nrf_drv_pwm_config_t const config1 =
        .output_pins =
            BASE_PWM_PIN,//| NRF_DRV_PWM_PIN_INVERTED, // channel 0
            NRF_DRV_PWM_PIN_NOT_USED,
        .irq_priority = APP_IRQ_PRIORITY_LOWEST,
        .base_clock   = NRF_PWM_CLK_1MHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = base_pwm_top,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
    err_code_base = nrf_drv_pwm_init(&m_base_pwm, &config1, base_pwm_event_handler);
    APP_ERROR_CHECK(err_code_base);
    if (err_code_base != NRF_SUCCESS)
        // Initialization failed. Take recovery action.
        NRF_LOG_INFO("PWM initialization failed");
Update pwm value in pwm event handler:
//base_pwm_event_handler
static void base_pwm_event_handler(nrf_drv_pwm_evt_type_t event_type)
   if (event_type == NRF_DRV_PWM_EVT_FINISHED)
      pwm_seq_values.channel_0 = base_pwm_val;
Update pwm sequence:
static void pwm_timer_timeout_handler(void *p_context)
      UNUSED_PARAMETER(p_context);
      pid_control_loop();
      /* Update duty cycle cap PWM ... */
      nrf_drv_pwm_simple_playback(&m_base_pwm, &pwm_seq, 1, NRF_DRV_PWM_FLAG_LOOP);
