DFU compatibility for a mesh example
I am interested to know how to make a mesh node (for example, a light server) compatible to perform a DFU.
I have gone through the DFU page and I noticed that the DFU is done over the Serial port. I understand that the dfu firmware is being replaced with blinky firmware. Correct me if I am wrong.
Now, what changes should I make to the commands inorder to make the light_server example node to be DFU compatible/capable over the air?
Would replacing the application hex file on step 8 to light_server instead of dfu solve it? or should I add any other commands to have light_server firmware first?
Thank you.
    I have been trying to analyze the messages sent back and forth between the PC and the target while establishing the initial UART communication.
    Case1:
    Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
    PC -> target: 0502aabbccdd
    target -> PC: 0582aabbccdd
    Got echo response
    Sending DFU init packet
    PC -> target: 1378fdff040fd3260a7859000000010003000000
    target -> PC: 03847800
    PC -> target: 1478fcff0000d3260a78ffffffff5d71000040000c
    target -> PC: 03847887
    I assume that the PC -> target message contains 59-company id, 1 - app-id, 3- application version that I sent. Is that right?
    The response from the target to PC is 03847800. What does this indicate?
    The third response back from the target to PC is 03847887. This is different from the first two responses. When the PC gets this response back, the DFU stops(fails). What does this value indicate?
    Is there any link that I can refer to regarding these messages?
    Case2:
    Got echo response
    PC -> target: 1378fdff040f2625fa6859000000010004000000
    target -> PC: 16a6045900000001000400000059000000010001000000
    PC -> target: 1478fcff00002625fa68ffffffff5995000040000c
    target -> PC: 0ea30104590000000100040000000d
    Sending firmware file
    [------------------------------------] 1% 00:11:49PC -> target: 1978fcff01002625fa6800f0002071630200596302005b630200
    In this case, the target sends two message as a reply which wasn't done in the first case. Why does the target send variable amount of messages?
    Also, the transfer began and then it was stopped when it received a different response back from the target. What might cause this behavior?
    There have been situations where I successfully ran the DFU when the target responded back with one message and with two messages.
    Why different responses for same/similar message packets sent from PC to target?
    Please check out the Serial commands, Serial events and Serial status codes in the mesh sdk documentation.
    So, basically, 03847887 means:
    03: Internal Events Report
    84: Cmd Response
    78: DFU Data
    87: ERROR_INVALID_DATA
    So it means that the init packet is not accepted.
    We have seen some weird behavior on certain compiler versions. So what IDE/compiler do you use? Segger Embedded Version? What version?
  • We have seen some weird behavior on certain compiler versions. So what IDE/compiler do you use? Segger Embedded Version? What version?
    Since you suggested previously, I have been using only SES v3.40. But I keep getting this response frequently.
    Additionally, I have noticed that once the DFU transfer stops in the middle(for example, my PC went to sleep after transferring 87% which stopped sending packets); there is no way to resume the DFU from that point. I tried pushing the new update with increased version number. It failed sending the error code for ERROR_INVALID_DATA.
    How does the flash for new FW image get freed? Does it gets overridden overtime new DFU is pushed or does the flash gets erased after the node loads the new FW?
    The error that I mentioned, is there any chance that it could be because of the DFU packets stored during the previous transfer.
     Sorry. I am out travelling, so I didn't read through the thread.
     That is because the device is probably expecting the next packet in the sequence. It should be possible to resume by sending the next packet, but this is not something that nrfutil currently supports. You would have to do this by altering the nrfutil FW, or wait until the DFU times out, and start over.
     Yes. If the device is still in DFU mode with a previous image, then you have to wait until it times out. Check out the reply that describes TIMER_DATA_TIMEOUT_US. There is also a define TIMER_START_TIMEOUT_US (both in nrf_mesh_dfu.c). If any of these times out, the DFU is stopped, and it will be ready to receive a new packet.
    How many DFU pushes can the board handle?
    Is there any time frame needed between each push?
    I am having hard time pushing the DFU multiple times.I have been pushing the same FW image of DFU example as well as customized example with DFU over and over again but the second DFU push fails most of the time. Sometimes, second push is successful but third fails. It fails sending the error code for ERROR_INVALID_DATA.
    I did try it by sending commands individually and also using scripts(version number is increased everytime). If there was something wrong with either commands or the scripts, it would have failed in the first push but it fails on second or third push. Also,  I am not even changing the hex files for pushing. It is the same file that was used for the first push.
    In the customized example, I do change the name and push it so that I see the indication that the device is successfully updated with new FW image.
    I dunno why but I feel that the flash which stores the new FW image isn't accepting the new image as I can see that the initial messages that are sent to check the ID's reply back with Success code which is 0x00.
    The DFU start message which carries the start address, size of the application is the one that is returning back with the ERROR_INVALID_DATA reply
    The only difference that I see with the DFU start message when the DFU is pushed successfully and when it fails is the transfer ID field in the message packet. I don't see anything else changing. So, I am still unsure on what is going wrong while trying to push the same FW again and again.
    It would be great if you or any of your colleagues find time to push DFU example multiple times onto the same board and see if there is anything wrong with that?
