Scan advertising devices for a limited time
Hey
This is sumanth. I have worked on mesh beaconing example and saw the output of continuous scanning advertisement of nearby devices in RTT, I made changes in light_switch_server program with the help of beaconing example to scan the advertisements when i press the button 1 in nRF52 DK. It worked well, but it continuously scanning the advertisement of nearby devices like it is in a infinate loop. I want to know how can i stop the scanning data. My requirement is like below mentioned.
The nRf52 DK should start Scanning the advertisments and print in RTT when i press button 1 and stop scanning when i press button 2, It should also able to do its light_switch_example. What are the changes i have to do.
The modified server program is shown below.
static void rx_cb(const nrf_mesh_adv_packet_rx_data_t * p_rx_data)
    LEDS_OFF(BSP_LED_0_MASK);  /* @c LED_RGB_RED_MASK on pca10031 */
    char msg[64];
    (void) sprintf(msg, "RX [@%u]: RSSI: %3d ADV TYPE: %x ADDR: [%02x:%02x:%02x:%02x:%02x:%02x]",
                   p_rx_data->p_metadata->params.scanner.timestamp,
                   p_rx_data->p_metadata->params.scanner.rssi,
                   p_rx_data->adv_type,
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[0],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[1],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[2],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[3],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[4],
                   p_rx_data->p_metadata->params.scanner.adv_addr.addr[5]);
    __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, msg, p_rx_data->p_payload, p_rx_data->length);
    LEDS_ON(BSP_LED_0_MASK);  /* @c LED_RGB_RED_MASK on pca10031 */
static void button_event_handler(uint32_t button_number)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
    switch (button_number)
        /* Pressing SW1 on the Development Kit will result in LED state to toggle and trigger
        the STATUS message to inform client about the state change. This is a demonstration of
        state change publication due to local event. */
        case 0:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "User action \n");
            hal_led_pin_set(ONOFF_SERVER_0_LED, !hal_led_pin_get(ONOFF_SERVER_0_LED));
            app_onoff_status_publish(&m_onoff_server_0);
        case 1:
            nrf_mesh_rx_cb_set(rx_cb);
        /* Initiate node reset */
        case 3:
            /* Clear all the states to reset the node. */
            if (mesh_stack_is_device_provisioned())
#if MESH_FEATURE_GATT_PROXY_ENABLED
                (void) proxy_stop();
                mesh_stack_config_clear();
                node_reset();
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "The device is unprovisioned. Resetting has no effect.\n");
I used the rx_cb function from beconing example and placed in the main.c of server and called that function in button_event_handler under case 1.
