nrf_drv_gpiote weird behavior
I created own app button library. It's just return handler into main with number of pin and type of push - short or long.  Also I created library for rgb_led (using nrf_pwm).
Both libraries work ok when I use them in project based on peripheral example (without softdevice). But the weird things occurred when I add them into project based on buttonless_dfu example. My steps for creating own project based on existing buttonless_dfu from sdk15.3 (15.2 is the same):
1. I have added ble_nus service and create macro for turning off dfu things for ability flash chip without bootloader.
2. I have separated bluetooth related functions from main into ble_main.c, handler for ble events I add into ble_handle.c. I have not changed any of functionality just do project more readable and clear for me.
Now all works good without any issues.
Then after adding my two libraries into this project, they can not work correctly together. Actually rgb_led (pwm) works ok without buttons (gpiote), with buttons rgb light pale or not works at all. if I comment ble_init_m() also everything works ok. I understand that probably issue related to bsp library because it's also used gpiote and happens reinit or maybe use the same instance or something else. I try comment bsp_led calling function but not helped.
If I wrap nrf_drv_gpiote_init() by APP_ERROR_CHECK I got fatal error:
0> <error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at :0
0> PC at: 0x00000000
0> <error> app: End of error report
main.c
#include "ble_main.h"
#include "buttons.h"
#include "rgb_led.h"
void but_handler(bool state, nrfx_gpiote_pin_t pin){
	SEGGER_RTT_printf(0, "button = %d, long = %d\n", pin, state);
	ble_send_printf2("b=%d, long=%d\n", pin, state);
		ble_init_m();
	  pwm_init_rgb();
		//just blinky 5 times green color of rgb
		rgb_set(0,50,0,5,500);
		uint8_t buttons[] = {7,8,9,10};
		button_init(buttons, but_handler);
	for (;;)
buttons.c
APP_TIMER_DEF(but_timer);
static but_evt_handler_t  p_but_evt_handler;
static uint8_t c_pin;
typedef enum {RESET, CHECK, CHECKED} but_state_t;
static but_state_t state = RESET;
static bool pin_set() { return nrf_drv_gpiote_in_is_set(c_pin); }
void but_timer_handler (void *p_context){
			if(state == CHECK && pin_set()){
				app_timer_start(but_timer, APP_TIMER_TICKS(1000), NULL);
				state = CHECKED;
			else if (state == CHECKED && pin_set()){ //long press
				p_but_evt_handler(true, c_pin);
				state = RESET;
			else state = RESET;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action){
		 	c_pin = pin;
			if(state == RESET){
				state = CHECK;
				app_timer_start(but_timer, 1500, NULL);
			else if (state == CHECKED && !pin_set()){ //short press
				p_but_evt_handler(false, c_pin);
				state = RESET;
				app_timer_stop(but_timer);
static void button_timer_init(){
	ret_code_t error_code;
	app_timer_init();
	app_timer_create(&but_timer, APP_TIMER_MODE_SINGLE_SHOT, but_timer_handler);
  if(nrf_sdh_is_enabled()){
	} else {
	NRF_CLOCK->TASKS_LFCLKSTART = 1;
	while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
	APP_ERROR_CHECK(nrf_drv_gpiote_init());
void button_init(uint8_t* buttons, but_evt_handler_t but_evt_handler){
	button_timer_init();
	p_but_evt_handler = but_evt_handler;
	nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
	in_config.pull = NRF_GPIO_PIN_PULLUP;
	for(uint8_t i = 0; i < strlen((char*)buttons); i++){
			nrf_drv_gpiote_in_init(buttons[i], &in_config, in_pin_handler);
			nrf_drv_gpiote_in_event_enable(buttons[i], true);
buttons.h
#ifndef BUTTONS_H__
#define BUTTONS_H__
#include "nrf_drv_gpiote.h"
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "SEGGER_RTT.h"
#include "app_timer.h"
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "nrf_gpio.h"
//#include "ble_main.h"
typedef void (*but_evt_handler_t)(bool, nrf_drv_gpiote_pin_t);
void button_init(uint8_t* buttons, but_evt_handler_t but_evt_handler);
rgb_led.c
nrf_drv_pwm_t m_pwm_rgb = NRF_DRV_PWM_INSTANCE(0);
nrf_pwm_values_individual_t seq_value_rgb[2];
nrf_pwm_sequence_t seq_rgb;
void pwm_init_rgb()
	nrf_gpio_cfg_output(RGB_GND);
	nrf_gpio_pin_set(RGB_GND);
  //uint32_t err_code;
	nrf_drv_pwm_config_t const config0 =
			.output_pins =
					RED_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 0
					GREEN_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 1
					BLUE_PIN | NRF_DRV_PWM_PIN_INVERTED, // channel 2
					NRF_DRV_PWM_PIN_NOT_USED, // channel 3
			.irq_priority = APP_IRQ_PRIORITY_LOW,
			.base_clock   = NRF_PWM_CLK_1MHz,
			.count_mode   = NRF_PWM_MODE_UP,
			.top_value    = RGB_TOP,
			.load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
			.step_mode    = NRF_PWM_STEP_AUTO
	nrf_drv_pwm_init(&m_pwm_rgb, &config0, NULL);
	seq_value_rgb[0].channel_0 = RGB_TOP - 200;
	seq_value_rgb[1].channel_0 = RGB_TOP - 0;
	seq_value_rgb[0].channel_1 = RGB_TOP - 200;
	seq_value_rgb[1].channel_1 = RGB_TOP - 0;
	seq_value_rgb[0].channel_2 = RGB_TOP - 200;
	seq_value_rgb[1].channel_2 = RGB_TOP - 0;
	seq_rgb.values.p_individual = seq_value_rgb;
	seq_rgb.length = NRF_PWM_VALUES_LENGTH(seq_value_rgb);
	seq_rgb.repeats             = 0;
  seq_rgb.end_delay           = 0;
//	nrf_drv_pwm_simple_playback(&m_pwm_rgb, &seq_rgb, 0, NRF_DRV_PWM_FLAG_STOP);
void rgb_set(uint16_t red_value, uint16_t green_value, uint16_t blue_value, uint8_t times, uint16_t delay_time)
	seq_value_rgb[0].channel_0 = red_value;
	seq_value_rgb[1].channel_0 = 0;
	seq_value_rgb[0].channel_1 = green_value;
	seq_value_rgb[1].channel_1 = 0;
	seq_value_rgb[0].channel_2 = blue_value;
	seq_value_rgb[1].channel_2 = 0;
	if(times > 0)
		seq_rgb.repeats = delay_time;
		nrf_drv_pwm_simple_playback(&m_pwm_rgb, &seq_rgb, (uint16_t)times, NRF_DRV_PWM_FLAG_STOP);
		nrf_drv_pwm_simple_playback(&m_pwm_rgb, &seq_rgb, 2, NRF_DRV_PWM_FLAG_LOOP);
rgb_led.h
#ifndef RGB_LED_H
#define RGB_LED_H
#include "util.h"
#include "nrf_drv_pwm.h"
#include <stdio.h>
#include <string.h>
#include "boards.h"
#include "bsp.h"
#include "nrf_drv_clock.h"
#include "nrfx_pwm.h"
#define RGB_TOP 255
#define RGB_GND 3
#define RED_PIN 2
#define GREEN_PIN 5
#define BLUE_PIN 4
void pwm_init_rgb(void);
void rgb_set(uint16_t red_value, uint16_t green_value, uint16_t blue_value, uint8_t times, uint16_t delay_time);
ble_main.c
ble_handler_t     p_ble_handler;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                            /**< Handle of the current connection. */
static void advertising_start(bool erase_bonds);                                    /**< Forward declaration of advertising start function */
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}};
/**@brief Handler for shutdown preparation.
 * @details During shutdown procedures, this function will be called at a 1 second interval
 *          untill the function returns true. When the function returns true, it means that the
 *          app is ready to reset to DFU mode.
 * @param[in]   event   Power manager event.
 * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_DFU:
            NRF_LOG_INFO("Power management wants to reset to DFU mode.");
            // YOUR_JOB: Get ready to reset into DFU mode
            // If you aren't finished with any ongoing tasks, return "false" to
            // signal to the system that reset is impossible at this stage.
            // Here is an example using a variable to delay resetting the device.
            // if (!m_ready_for_reset)
            //      return false;
            // else
            //    // Device ready to enter
            //    uint32_t err_code;
            //    err_code = sd_softdevice_disable();
            //    APP_ERROR_CHECK(err_code);
            //    err_code = app_timer_stop_all();
            // YOUR_JOB: Implement any of the other events available from the power management module:
            //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
            //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
            //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
            return true;
    NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
    return true;
//lint -esym(528, m_app_shutdown_handler)
/**@brief Register application shutdown handler with priority 0.
NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
#ifdef DFU
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
    if (state == NRF_SDH_EVT_STATE_DISABLED)
        // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
        nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
        //Go to system off.
        nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/* nrf_sdh state observer. */
NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
    .handler = buttonless_dfu_sdh_state_observer,
static void advertising_config_get(ble_adv_modes_config_t * p_config)
    memset(p_config, 0, sizeof(ble_adv_modes_config_t));
    p_config->ble_adv_fast_enabled  = true;
    p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
    p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
#ifdef DFU
static void disconnect(uint16_t conn_handle, void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
        NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
 * @param[in]   event   Event from the Buttonless Secure DFU service.
#ifdef DFU
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
    switch (event)
        case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
            NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
            // Prevent device from advertising on disconnect.
            ble_adv_modes_config_t config;
            advertising_config_get(&config);
            config.ble_adv_on_disconnect_disabled = true;
            ble_advertising_modes_config_set(&m_advertising, &config);
            // Disconnect all other bonded devices that currently are connected.
            // This is required to receive a service changed indication
            // on bootup after a successful (or aborted) Device Firmware Update.
            uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
            NRF_LOG_INFO("Disconnected %d links.", conn_count);
        case BLE_DFU_EVT_BOOTLOADER_ENTER:
            // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
            //           by delaying reset by reporting false in app_shutdown_handler
            NRF_LOG_INFO("Device will enter bootloader mode.");
        case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
            NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
            // YOUR_JOB: Take corrective measures to resolve the issue
            //           like calling APP_ERROR_CHECK to reset the device.
        case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
            NRF_LOG_ERROR("Request to send a response to client failed.");
            APP_ERROR_CHECK(false);
            NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
//void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name)
//    app_error_handler(DEAD_BEEF, line_num, p_file_name);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    uint32_t err_code = app_timer_init();
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
       APP_ERROR_CHECK(err_code); */
    APP_ERROR_HANDLER(nrf_error);
	//code here later
	p_ble_handler(p_evt);
    uint32_t                  err_code;
    nrf_ble_qwr_init_t        qwr_init  = {0};
#ifdef DFU
     ble_dfu_buttonless_init_t dfus_init = {0};
     dfus_init.evt_handler = ble_dfu_evt_handler;
     err_code = ble_dfu_buttonless_init(&dfus_init);
		ble_nus_init_t     nus_init;
		// Initialize NUS.
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
       uint32_t err_code;
       err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    //Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
    //GPREGRET2 register holds the information about skipping CRC check on next boot.
    err_code = nrf_sdh_disable_request();
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code = NRF_SUCCESS;
        case BLE_GAP_EVT_CONNECTED:
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init()
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/** @brief Clear bonding information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    advertising_config_get(&init.config);
    uint32_t err_code;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for the Power manager.
static void log_init(void)
    uint32_t err_code = NRF_LOG_INIT(NULL);
/**@brief   Function for initializing the GATT module.
 * @details The GATT module handles ATT_MTU and Data Length update procedures automatically.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        NRF_LOG_DEBUG("advertising is started");
    uint32_t err_code = nrf_pwr_mgmt_init();
//static void idle_state_handle(void)
//    if (NRF_LOG_PROCESS() == false)
//        nrf_pwr_mgmt_run();
void ble_send_m (uint8_t* data_array, uint16_t length) {
		//uint16_t length = strlen((char*) data_array);
		ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
void ble_routine(ble_handler_t ble_handler){
		p_ble_handler = ble_handler;
	    bool       erase_bonds;
    log_init();
		#ifdef DFU
    // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
    err_code = ble_dfu_buttonless_async_svci_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    peer_manager_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
   // NRF_LOG_INFO("Buttonless DFU Application started.");
    // Start execution.
    application_timers_start();
    advertising_start(erase_bonds);
ble_main.h
#ifndef BLE_MAIN_H__
#define BLE_MAIN_H__
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "nrf_dfu_ble_svci_bond_sharing.h"
#include "nrf_svci_async_function.h"
#include "nrf_svci_async_handler.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "ble_conn_state.h"
#include "ble_dfu.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "fds.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_power.h"
#include "nrf_bootloader_info.h"
#include "ble_nus.h"
#include "ble_handle.h"
#include "util.h"
//uncomment for dfu enabled (will need flash bootloader)
//#define DFU
#define DEVICE_NAME                     "sdr_2"                         /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)            /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
typedef void (* ble_handler_t) (ble_nus_evt_t * p_evt);
//typedef void (* ble_nus_data_handler_t) (ble_nus_evt_t * p_evt);
void ble_routine(ble_handler_t ble_handler);
void ble_send_m (uint8_t* data_array, uint16_t length);
ble_handle.c
#define BLE_ARR(n) char result_str[n];               \
									 if(strlen(pattern) > 20){		     \
									  SEGGER_RTT_printf(0,"ivan");}
uint8_t ble_rx_data[20];
static void ble_handler(ble_nus_evt_t* p_evt){
	if(p_evt->type == BLE_NUS_EVT_RX_DATA){
			SEGGER_RTT_printf(0, "receive: %s\n", p_evt->params.rx_data.p_data);
			for (int i = 0; i < p_evt->params.rx_data.length; i++){
						ble_rx_data[i] = p_evt->params.rx_data.p_data[i];
			if(ble_rx_data[0] == 's'){
				ble_send_str(ble_rx_data);
void ble_init_m(){
	ble_routine(ble_handler);
void ble_send_str(uint8_t* data_array){
	 ble_send_m(data_array, length);
void ble_send_ch(char data){
	 ble_send_m((uint8_t*)&data, 1);
void ble_send_printf1(char* pattern, uint16_t num1){
		char result_str[20];
		sprintf(result_str, pattern, num1);
		ble_send_str((uint8_t*)result_str);
void ble_send_printf2(char* pattern, uint16_t num1, uint16_t num2){
		sprintf(result_str, pattern, num1, num2);
void ble_send_printf3(char* pattern, uint16_t num1, uint16_t num2, uint16_t num3){
		sprintf(result_str, pattern, num1, num2, num3);
void ble_send_int(int num){
		sprintf(result_str, "%d", num);
ble_handle.h
#ifndef BLE_HANDLE_H__
#define BLE_HANDLE_H__
void ble_init_m(void);
void ble_send_str (uint8_t* data_array);
void ble_send_ch(char data);
void ble_send_int(int num);
void ble_send_printf1(char* pattern, uint16_t num1);
void ble_send_printf2(char* pattern, uint16_t num1, uint16_t num2);
void ble_send_printf3(char* pattern, uint16_t num1, uint16_t num2, uint16_t num3);
