Problem sending data array using BLE_NUS_DATA_SEND
I am simply trying to send a sample of data from a TWI sensor to smartphone via BLE with a 2 second delay between each send.
I've adapted the ble_app_uart and twi_sensor examples, and everything is working properly except one thing. The data is not received properly.
The BLE_NUS_DATA_SEND is sending and working correctly because I do see the "value" title appear in the NRF Connect app after enabling notifications, but there is just no value there (just empty space).
To check the data, I printed/logged the sensor value in the data_send function. M_sample prints correctly, but when I try to print the data array, it doesn't show. So I believe this problem is caused when m_sample is put into the data array. This tells me that m_sample is of the wrong type or form.
I have 2 questions:
1. What type/size/form does my data need to be in to be printed/logged, and why can't I print the data_array but can with the m_sample?
2. What changes need to be applied to send my number sample (m_sample) via BLE_NUS_DATA_SEND?
I'm sure these questions are obvious to someone. I may have missed some basic things in the documentation, but I'd really appreciate if someone could point out my problem.
SDK15.3, SES
void data_send(uint8_t m_sample)
    static uint8_t index = 0;
    uint32_t       err_code;
    data_array[BLE_NUS_MAX_DATA_LEN - 1] = m_sample;
NRF_LOG_INFO("check msample: %d Celsius degrees.", m_sample);
       // NRF_LOG_INFO("Check array.", data_array);
          NRF_LOG_INFO("Check array2.", m_sample);
                    //NRF_LOG_DEBUG("Ready to send data over BLE NUS");
                    //NRF_LOG_HEXDUMP_DEBUG(data_array, index);
                        err_code = ble_nus_data_send(&m_nus, &data_array, &length, m_conn_handle);
   if ((err_code != NRF_ERROR_INVALID_STATE) &&// This part is right (saw another user do it).
                            (err_code != NRF_ERROR_NOT_FOUND))//different
  • I expected the m_sample to be inserted into the array with a length and size that matches the requirement of ble_nus_data_send.
    In that case, why would the value of data_array be such a large number? I printed it, and it's showing a value of 536884548. What could this number represent then?
  • Well. This is C programming, so there is no magic here, unfortunately.
    ble_nus_data_send takes a data array (in your case the variable data_array[]). Now, it doesn't send the entire array, but from element 0 to element p_length (3rd element, e.g. &length). If this value is 0, then it will send 0 bytes, so if you want to send one byte, which it looks like, based on that you take in one (!) byte, m_sample, you should try to set index to 1. However, I suspect that you are actually trying to send more than one byte. Look at how it is done in the ble_app_uart example.
    Now. It returns 5, e.g. NRF_ERROR_NOT_FOUND. This simply means that you aren't connected to anything. If you try to connect, you will probably get the return value NRF_ERROR_INVALID_STATE (== 8). This means that notifications aren't enabled.
    Unless ble_nus_data_send() returns 0 the data array that you try to send have not been queued.
    However, to send data from a TWI sensor, you should look at the ble_app_uart example, and take some inspiration from the uart_event_handle() in main.c.
    BR,
    Edvin
  • This is C programming
    Absolutely!
    That's not what your code does - as described above.
    Again, this is standard 'C' programming - nothing specifically to do with Nordic or even embedded microcontrollers!
    In 'C', the name of an array - such as "data_array" -  gives a pointer to the first element of the array; or, in other words, the address of the first element of the array.
    So, if you print that, you will very likely get a large number!
    So that's 0x20003544 - which is, indeed, an address in the nRF52 RAM:
    I think you might need to brush-up on your 'C' - so here are some 'C' learning & reference materials:
    http://blog.antronics.co.uk/2011/08/08/so-youre-thinking-of-starting-with-c/
  • I still don't understand how to insert m_sample into an array of correct type
    See replies below.
    This part is just standard 'C' - not specific to Nordic.
