I want to add an OUT endpoint to the USBD example, but it is not successful. I cannot find the relevant tutorial. Below is my main.c, asking for help, thank you very much.
/** * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ #include <stdint.h> #include <stdbool.h> #include <stddef.h> #include "nrf.h" #include "nrf_drv_usbd.h" #include "nrf_drv_clock.h" #include "nrf_gpio.h" #include "nrf_delay.h" #include "nrf_drv_power.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #include "app_timer.h" #include "app_error.h" #include "bsp.h" #include "bsp_cli.h" #include "nrf_cli.h" #include "nrf_cli_uart.h" /** * @brief CLI interface over UART */ NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16); NRF_CLI_DEF(m_cli_uart, "uart_cli:~$ ", &m_cli_uart_transport.transport, '\r', 4); static bool m_send_flag = 0; #define BTN_DATA_SEND 0 #define BTN_DATA_KEY_RELEASE (bsp_event_t)(BSP_EVENT_KEY_LAST + 1) /** * @brief Button used to simulate mouse move * * Every button press would move the cursor one step in the square. */ #define BTN_MOUSE_MOVE BSP_BOARD_BUTTON_0 /** * @brief Button for system OFF request * * This button would set the request for system OFF. */ #define BTN_SYSTEM_OFF BSP_BOARD_BUTTON_1 /** * @brief Configuration status LED * * This LED would blink quickly (5 Hz) when device is not configured * or slowly (1 Hz) when configured and working properly. */ #define LED_USB_STATUS BSP_BOARD_LED_0 /** * @brief Power detect LED * * The LED is ON when connection is detected on USB port. * It is turned off when connection is removed. */ #define LED_USB_POWER BSP_BOARD_LED_1 /** * @brief Running LED * * LED that turns on when program is not sleeping */ #define LED_RUNNING BSP_BOARD_LED_2 /** * @brief Active LED * * LED that turns on when program is not in system OFF */ #define LED_ACTIVE BSP_BOARD_LED_3 /** * @brief Enable power USB detection * * Configure if example supports USB port connection */ #ifndef USBD_POWER_DETECTION #define USBD_POWER_DETECTION true #endif /** * @brief Startup delay * * Number of microseconds to start USBD after powering up. * Kind of port insert debouncing. */ #define STARTUP_DELAY 100 /** Maximum size of the packed transfered by EP0 */ #define EP0_MAXPACKETSIZE NRF_DRV_USBD_EPSIZE /** Device descriptor */ #define USBD_DEVICE_DESCRIPTOR \ 0x12, /* bLength | size of descriptor */\ 0x01, /* bDescriptorType | descriptor type */\ 0x00, 0x02, /* bcdUSB | USB spec release (ver 2.0) */\ 0x00, /* bDeviceClass ¦ class code (each interface specifies class information) */\ 0x00, /* bDeviceSubClass ¦ device sub-class (must be set to 0 because class code is 0) */\ 0x00, /* bDeviceProtocol | device protocol (no class specific protocol) */\ EP0_MAXPACKETSIZE, /* bMaxPacketSize0 | maximum packet size (64 bytes) */\ 0x15, 0x19, /* vendor ID (0x1915 Nordic) */\ 0x0A, 0x52, /* product ID (0x520A nRF52 HID mouse on nrf_drv) */\ 0x01, 0x01, /* bcdDevice | final device release number in BCD Format */\ USBD_STRING_MANUFACTURER_IX, /* iManufacturer | index of manufacturer string */\ USBD_STRING_PRODUCT_IX, /* iProduct | index of product string */\ USBD_STRING_SERIAL_IX, /* iSerialNumber | Serial Number string */\ 0x01 /* bNumConfigurations | number of configurations */ /** Configuration descriptor */ #define DEVICE_SELF_POWERED 1 #define REMOTE_WU 1 #define USBD_CONFIG_DESCRIPTOR_SIZE 9 #define USBD_CONFIG_DESCRIPTOR_FULL_SIZE (9 + (9 + 9 + 7)) #define USBD_CONFIG_DESCRIPTOR \ 0x09, /* bLength | length of descriptor */\ 0x02, /* bDescriptorType | descriptor type (CONFIGURATION) */\ USBD_CONFIG_DESCRIPTOR_FULL_SIZE, 0x00, /* wTotalLength | total length of descriptor(s) */\ 0x01, /* bNumInterfaces */\ 0x01, /* bConfigurationValue */\ 0x00, /* index of string Configuration | configuration string index (not supported) */\ 0x80| (((DEVICE_SELF_POWERED) ? 1U:0U)<<6) | (((REMOTE_WU) ? 1U:0U)<<5), /* bmAttributes */\ 49 /* maximum power in steps of 2mA (98mA) */ #define USBD_INTERFACE0_DESCRIPTOR \ 0x09, /* bLength */\ 0x04, /* bDescriptorType | descriptor type (INTERFACE) */\ 0x00, /* bInterfaceNumber */\ 0x00, /* bAlternateSetting */\ 0x02, /* bNumEndpoints | number of endpoints (1) */\ 0x03, /* bInterfaceClass | interface class (3..defined by USB spec: HID) */\ 0x00, /* bInterfaceSubClass |interface sub-class (0.. no boot interface) */\ 0x01, /* bInterfaceProtocol | interface protocol (1..defined by USB spec: mouse) */\ 0x00 /* interface string index (not supported) */ /** * HID Table must normally be between Interface and EndPoint Descriptor * as written in HID spec§7.1 but it doesn't work with OSR2.1 */ #define USBD_HID0_DESCRIPTOR \ 0x09, /* bLength | length of descriptor (9 bytes) */\ 0x21, /* bHIDDescriptor | descriptor type (HID) */\ 0x11, 0x01, /* HID wBcdHID | Spec version 01.11 */\ 0x00, /* bCountryCode | HW Target country */\ 0x01, /* bNumDescriptors | Number of HID class descriptors to follow */\ 0x22, /* bDescriptorType | Report descriptor type is 0x22 (report) */\ (uint8_t)(USBD_MOUSE_REPORT_DESCRIPTOR_SIZE), /* Total length of Report descr., low byte */ \ (uint8_t)(USBD_MOUSE_REPORT_DESCRIPTOR_SIZE / 256) /* Total length of Report descr., high byte */ #define USBD_ENDPOINT1_DESCRIPTOR \ 0x07, /* bLength | length of descriptor (7 bytes) */\ 0x05, /* bDescriptorType | descriptor type (ENDPOINT) */\ 0x81, /* bEndpointAddress | endpoint address (IN endpoint, endpoint 1) */\ 0x03, /* bmAttributes | endpoint attributes (interrupt) */\ 0x08,0x00, /* bMaxPacketSizeLowByte,bMaxPacketSizeHighByte | maximum packet size (8 bytes) */\ 0x08 /* bInterval | polling interval (10ms) */ #define USBD_ENDPOINT1_DESCRIPTOR_OUT \ 0x07, /* bLength | length of descriptor (7 bytes) */\ 0x05, /* bDescriptorType | descriptor type (ENDPOINT) */\ 0x01, /* bEndpointAddress | endpoint address (IN endpoint, endpoint 1) */\ 0x03, /* bmAttributes | endpoint attributes (interrupt) */\ 0x02,0x00, /* bMaxPacketSizeLowByte,bMaxPacketSizeHighByte | maximum packet size (8 bytes) */\ 0x08 /* bInterval | polling interval (10ms) */ /** * String config descriptor */ #define USBD_STRING_LANG_IX 0x00 #define USBD_STRING_LANG \ 0x04, /* length of descriptor */\ 0x03, /* descriptor type */\ 0x09, /* */\ 0x04 /* Supported LangID = 0x0409 (US-English) */ #define USBD_STRING_MANUFACTURER_IX 0x01 #define USBD_STRING_MANUFACTURER \ 42, /* length of descriptor (? bytes) */\ 0x03, /* descriptor type */\ 'N', 0x00, /* Define Unicode String "Nordic Semiconductor */\ 'o', 0x00, \ 'r', 0x00, \ 'd', 0x00, \ 'i', 0x00, \ 'c', 0x00, \ ' ', 0x00, \ 'S', 0x00, \ 'e', 0x00, \ 'm', 0x00, \ 'i', 0x00, \ 'c', 0x00, \ 'o', 0x00, \ 'n', 0x00, \ 'd', 0x00, \ 'u', 0x00, \ 'c', 0x00, \ 't', 0x00, \ 'o', 0x00, \ 'r', 0x00 #define USBD_STRING_PRODUCT_IX 0x02 #define USBD_STRING_PRODUCT \ 72, /* length of descriptor (? bytes) */\ 0x03, /* descriptor type */\ 'n', 0x00, /* generic unicode string for all devices */\ 'R', 0x00, \ 'F', 0x00, \ '5', 0x00, \ '2', 0x00, \ ' ', 0x00, \ 'U', 0x00, \ 'S', 0x00, \ 'B', 0x00, \ ' ', 0x00, \ 'H', 0x00, \ 'I', 0x00, \ 'D', 0x00, \ ' ', 0x00, \ 'm', 0x00, \ 'o', 0x00, \ 'u', 0x00, \ 's', 0x00, \ 'e', 0x00, \ ' ', 0x00, \ 'o', 0x00, \ 'n', 0x00, \ ' ', 0x00, \ 'n', 0x00, \ 'r', 0x00, \ 'f', 0x00, \ '_', 0x00, \ 'd', 0x00, \ 'r', 0x00, \ 'v', 0x00, \ ' ', 0x00, \ 'D', 0x00, \ 'e', 0x00, \ 'm', 0x00, \ 'o', 0x00, \ #define USBD_STRING_SERIAL_IX 0x00 #define USBD_MOUSE_REPORT_DESCRIPTOR_SIZE 61 #define USBD_MOUSE_REPORT_DESCRIPTOR \ 0x05, 0x01, \ 0x09, 0x06, \ 0xa1, 0x01, \ 0x05, 0x07, \ 0x19, 0xe0, \ 0x29, 0xe7, \ 0x15, 0x00, \ 0x25, 0x01, \ 0x95, 0x08, \ 0x75, 0x01, \ 0x81, 0x02, \ 0x95, 0x01, \ 0x75, 0x08, \ 0x81, 0x03, \ 0x95, 0x06, \ 0x75, 0x08, \ 0x25, 0xFF, \ 0x19, 0x00, \ 0x29, 0x65, \ 0x81, 0x00, \ 0x25, 0x01, \ 0x95, 0x02, \ 0x75, 0x01, \ 0x05, 0x08, \ 0x19, 0x01, \ 0x29, 0x02, \ 0x91, 0x02, \ 0x95, 0x01, \ 0x75, 0x06, \ 0x91, 0x03, \ 0xc0 \ static const uint8_t get_descriptor_device[] = { USBD_DEVICE_DESCRIPTOR }; static const uint8_t get_descriptor_configuration[] = { USBD_CONFIG_DESCRIPTOR, USBD_INTERFACE0_DESCRIPTOR, USBD_HID0_DESCRIPTOR, USBD_ENDPOINT1_DESCRIPTOR, USBD_ENDPOINT1_DESCRIPTOR_OUT }; static const uint8_t get_descriptor_string_lang[] = { USBD_STRING_LANG }; static const uint8_t get_descriptor_string_manuf[] = { USBD_STRING_MANUFACTURER }; static const uint8_t get_descriptor_string_prod[] = { USBD_STRING_PRODUCT }; static const uint8_t get_descriptor_report_interface_0[] = { USBD_MOUSE_REPORT_DESCRIPTOR }; static const uint8_t get_config_resp_configured[] = {1}; static const uint8_t get_config_resp_unconfigured[] = {0}; static const uint8_t get_status_device_resp_nrwu[] = { ((DEVICE_SELF_POWERED) ? 1 : 0), //LSB first: self-powered, no remoteWk 0 }; static const uint8_t get_status_device_resp_rwu[] = { ((DEVICE_SELF_POWERED) ? 1 : 0) | 2, //LSB first: self-powered, remoteWk 0 }; static const uint8_t get_status_interface_resp[] = {0, 0}; static const uint8_t get_status_ep_halted_resp[] = {1, 0}; static const uint8_t get_status_ep_active_resp[] = {0, 0}; #define GET_CONFIG_DESC_SIZE sizeof(get_descriptor_configuration) #define GET_INTERFACE_DESC_SIZE 9 #define GET_HID_DESC_SIZE 9 #define GET_ENDPOINT_DESC_SIZE 7 #define get_descriptor_interface_0 \ &get_descriptor_configuration[9] #define get_descriptor_hid_0 \ &get_descriptor_configuration[9+GET_INTERFACE_DESC_SIZE] #define get_descriptor_endpoint_1 \ &get_descriptor_configuration[9+GET_INTERFACE_DESC_SIZE+GET_HID_DESC_SIZE] #define get_descriptor_endpoint_1_OUT \ &get_descriptor_configuration[9+GET_INTERFACE_DESC_SIZE+GET_HID_DESC_SIZE+GET_ENDPOINT_DESC_SIZE] /** * @brief USB configured flag * * The flag that is used to mark the fact that USB is configured and ready * to transmit data */ static volatile bool m_usbd_configured = false; /** * @brief USB suspended * * The flag that is used to mark the fact that USB is suspended and requires wake up * if new data is available. * * @note This variable is changed from the main loop. */ static bool m_usbd_suspended = false; /** * @brief Mark the fact if remote wake up is enabled * * The internal flag that marks if host enabled the remote wake up functionality in this device. */ static #if REMOTE_WU volatile // Disallow optimization only if Remote wakeup is enabled #endif bool m_usbd_rwu_enabled = false; /** * @brief Current mouse position * * The index of current mouse position that would be changed to real offset. */ static volatile uint8_t m_mouse_position = 0; /** * @brief The flag for mouse position send pending * * Setting this flag means that USB endpoint is busy by sending * last mouse position. */ static volatile bool m_send_mouse_position = false; /** * @brief The requested suspend state * * The currently requested suspend state based on the events * received from USBD library. * If the value here is different than the @ref m_usbd_suspended * the state changing would be processed inside main loop. */ static volatile bool m_usbd_suspend_state_req = false; /** * @brief System OFF request flag * * This flag is used in button event processing and marks the fact that * system OFF should be activated from main loop. */ static volatile bool m_system_off_req = false; /** * @brief Setup all the endpoints for selected configuration * * Function sets all the endpoints for specific configuration. * * @note * Setting the configuration index 0 means technically disabling the HID interface. * Such configuration should be set when device is starting or USB reset is detected. * * @param index Configuration index * * @retval NRF_ERROR_INVALID_PARAM Invalid configuration * @retval NRF_SUCCESS Configuration successfully set */ static ret_code_t ep_configuration(uint8_t index) { if ( index == 1 ) { nrf_drv_usbd_ep_dtoggle_clear(NRF_DRV_USBD_EPIN1); nrf_drv_usbd_ep_stall_clear(NRF_DRV_USBD_EPIN1); nrf_drv_usbd_ep_enable(NRF_DRV_USBD_EPIN1); nrf_drv_usbd_ep_dtoggle_clear(NRF_DRV_USBD_EPOUT1); nrf_drv_usbd_ep_stall_clear(NRF_DRV_USBD_EPOUT1); nrf_drv_usbd_ep_enable(NRF_DRV_USBD_EPOUT1); m_usbd_configured = true; nrf_drv_usbd_setup_clear(); } else if ( index == 0 ) { nrf_drv_usbd_ep_disable(NRF_DRV_USBD_EPIN1); nrf_drv_usbd_ep_disable(NRF_DRV_USBD_EPOUT1); m_usbd_configured = false; nrf_drv_usbd_setup_clear(); } else { return NRF_ERROR_INVALID_PARAM; } return NRF_SUCCESS; } /** * @name Processing setup requests * * @{ */ /** * @brief Respond on ep 0 * * Auxiliary function for sending respond on endpoint 0 * @param[in] p_setup Pointer to setup data from current setup request. * It would be used to calculate the size of data to send. * @param[in] p_data Pointer to the data to send. * @param[in] size Number of bytes to send. * @note Data pointed by p_data has to be available till the USBD_EVT_BUFREADY event. */ static void respond_setup_data( nrf_drv_usbd_setup_t const * const p_setup, void const * p_data, size_t size) { /* Check the size against required response size */ if (size > p_setup->wLength) { size = p_setup->wLength; } ret_code_t ret; nrf_drv_usbd_transfer_t transfer = { .p_data = {.tx = p_data}, .size = size }; ret = nrf_drv_usbd_ep_transfer(NRF_DRV_USBD_EPIN0, &transfer); if (ret != NRF_SUCCESS) { NRF_LOG_ERROR("Transfer starting failed: %d", (uint32_t)ret); } ASSERT(ret == NRF_SUCCESS); UNUSED_VARIABLE(ret); } /** React to GetStatus */ static void usbd_setup_GetStatus(nrf_drv_usbd_setup_t const * const p_setup) { switch (p_setup->bmRequestType) { case 0x80: // Device if (((p_setup->wIndex) & 0xff) == 0) { respond_setup_data( p_setup, m_usbd_rwu_enabled ? get_status_device_resp_rwu : get_status_device_resp_nrwu, sizeof(get_status_device_resp_nrwu)); return; } break; case 0x81: // Interface if (m_usbd_configured) // Respond only if configured { if (((p_setup->wIndex) & 0xff) == 0) // Only interface 0 supported { respond_setup_data( p_setup, get_status_interface_resp, sizeof(get_status_interface_resp)); return; } } break; case 0x82: // Endpoint if (((p_setup->wIndex) & 0xff) == 0) // Endpoint 0 { respond_setup_data( p_setup, get_status_ep_active_resp, sizeof(get_status_ep_active_resp)); return; } if (m_usbd_configured) // Other endpoints responds if configured { if (((p_setup->wIndex) & 0xff) == NRF_DRV_USBD_EPIN1) { if (nrf_drv_usbd_ep_stall_check(NRF_DRV_USBD_EPIN1)) { respond_setup_data( p_setup, get_status_ep_halted_resp, sizeof(get_status_ep_halted_resp)); return; } else { respond_setup_data( p_setup, get_status_ep_active_resp, sizeof(get_status_ep_active_resp)); return; } } else if (((p_setup->wIndex) & 0xff) == NRF_DRV_USBD_EPOUT1) { if (nrf_drv_usbd_ep_stall_check(NRF_DRV_USBD_EPOUT1)) { respond_setup_data( p_setup, get_status_ep_halted_resp, sizeof(get_status_ep_halted_resp)); return; } else { respond_setup_data( p_setup, get_status_ep_active_resp, sizeof(get_status_ep_active_resp)); return; } } } break; default: break; // Just go to stall } NRF_LOG_ERROR("Unknown status: 0x%2x", p_setup->bmRequestType); nrf_drv_usbd_setup_stall(); } static void usbd_setup_ClearFeature(nrf_drv_usbd_setup_t const * const p_setup) { if ((p_setup->bmRequestType) == 0x02) // standard request, recipient=endpoint { if ((p_setup->wValue) == 0) { if ((p_setup->wIndex) == NRF_DRV_USBD_EPIN1) { nrf_drv_usbd_ep_stall_clear(NRF_DRV_USBD_EPIN1); nrf_drv_usbd_setup_clear(); return; } else if ((p_setup->wIndex) == NRF_DRV_USBD_EPOUT1) { nrf_drv_usbd_ep_stall_clear(NRF_DRV_USBD_EPOUT1); nrf_drv_usbd_setup_clear(); return; } } } else if ((p_setup->bmRequestType) == 0x0) // standard request, recipient=device { if (REMOTE_WU) { if ((p_setup->wValue) == 1) // Feature Wakeup { m_usbd_rwu_enabled = false; nrf_drv_usbd_setup_clear(); return; } } } NRF_LOG_ERROR("Unknown feature to clear"); nrf_drv_usbd_setup_stall(); } static void usbd_setup_SetFeature(nrf_drv_usbd_setup_t const * const p_setup) { if ((p_setup->bmRequestType) == 0x02) // standard request, recipient=endpoint { if ((p_setup->wValue) == 0) // Feature HALT { if ((p_setup->wIndex) == NRF_DRV_USBD_EPIN1) { nrf_drv_usbd_ep_stall(NRF_DRV_USBD_EPIN1); nrf_drv_usbd_setup_clear(); return; } else if ((p_setup->wIndex) == NRF_DRV_USBD_EPOUT1) { nrf_drv_usbd_ep_stall(NRF_DRV_USBD_EPOUT1); nrf_drv_usbd_setup_clear(); return; } } } else if ((p_setup->bmRequestType) == 0x0) // standard request, recipient=device { if (REMOTE_WU) { if ((p_setup->wValue) == 1) // Feature Wakeup { m_usbd_rwu_enabled = true; nrf_drv_usbd_setup_clear(); return; } } } NRF_LOG_ERROR("Unknown feature to set"); nrf_drv_usbd_setup_stall(); } static void usbd_setup_GetDescriptor(nrf_drv_usbd_setup_t const * const p_setup) { //determine which descriptor has been asked for switch ((p_setup->wValue) >> 8) { case 1: // Device if ((p_setup->bmRequestType) == 0x80) { respond_setup_data( p_setup, get_descriptor_device, sizeof(get_descriptor_device)); return; } break; case 2: // Configuration if ((p_setup->bmRequestType) == 0x80) { respond_setup_data( p_setup, get_descriptor_configuration, GET_CONFIG_DESC_SIZE); return; } break; case 3: // String if ((p_setup->bmRequestType) == 0x80) { // Select the string switch ((p_setup->wValue) & 0xFF) { case USBD_STRING_LANG_IX: respond_setup_data( p_setup, get_descriptor_string_lang, sizeof(get_descriptor_string_lang)); return; case USBD_STRING_MANUFACTURER_IX: respond_setup_data( p_setup, get_descriptor_string_manuf, sizeof(get_descriptor_string_manuf)); return; case USBD_STRING_PRODUCT_IX: respond_setup_data(p_setup, get_descriptor_string_prod, sizeof(get_descriptor_string_prod)); return; default: break; } } break; case 4: // Interface if ((p_setup->bmRequestType) == 0x80) { // Which interface? if ((((p_setup->wValue) & 0xFF) == 0)) { respond_setup_data( p_setup, get_descriptor_interface_0, GET_INTERFACE_DESC_SIZE); return; } } break; case 5: // Endpoint if ((p_setup->bmRequestType) == 0x80) { // Which endpoint? if (((p_setup->wValue) & 0xFF) == 0x81) { respond_setup_data( p_setup, get_descriptor_endpoint_1, GET_ENDPOINT_DESC_SIZE); return; } else if (((p_setup->wValue) & 0xFF) == 0x01) { respond_setup_data( p_setup, get_descriptor_endpoint_1_OUT, GET_ENDPOINT_DESC_SIZE); return; } } break; case 0x21: // HID if ((p_setup->bmRequestType) == 0x81) { // Which interface if (((p_setup->wValue) & 0xFF) == 0) { respond_setup_data( p_setup, get_descriptor_hid_0, GET_HID_DESC_SIZE); return; } } break; case 0x22: // HID report if ((p_setup->bmRequestType) == 0x81) { // Which interface? if (((p_setup->wValue) & 0xFF) == 0) { respond_setup_data( p_setup, get_descriptor_report_interface_0, sizeof(get_descriptor_report_interface_0)); return; } } break; default: break; // Not supported - go to stall } NRF_LOG_ERROR("Unknown descriptor requested: 0x%2x, type: 0x%2x or value: 0x%2x", p_setup->wValue >> 8, p_setup->bmRequestType, p_setup->wValue & 0xFF); nrf_drv_usbd_setup_stall(); } static void usbd_setup_GetConfig(nrf_drv_usbd_setup_t const * const p_setup) { if (m_usbd_configured) { respond_setup_data( p_setup, get_config_resp_configured, sizeof(get_config_resp_configured)); } else { respond_setup_data( p_setup, get_config_resp_unconfigured, sizeof(get_config_resp_unconfigured)); } } static void usbd_setup_SetConfig(nrf_drv_usbd_setup_t const * const p_setup) { if ((p_setup->bmRequestType) == 0x00) { // accept only 0 and 1 if (((p_setup->wIndex) == 0) && ((p_setup->wLength) == 0) && ((p_setup->wValue) <= UINT8_MAX)) { if (NRF_SUCCESS == ep_configuration((uint8_t)(p_setup->wValue))) { nrf_drv_usbd_setup_clear(); return; } } } NRF_LOG_ERROR("Wrong configuration: Index: 0x%2x, Value: 0x%2x.", p_setup->wIndex, p_setup->wValue); nrf_drv_usbd_setup_stall(); } static void usbd_setup_SetIdle(nrf_drv_usbd_setup_t const * const p_setup) { if (p_setup->bmRequestType == 0x21) { //accept any value nrf_drv_usbd_setup_clear(); return; } NRF_LOG_ERROR("Set Idle wrong type: 0x%2x.", p_setup->bmRequestType); nrf_drv_usbd_setup_stall(); } static void usbd_setup_SetInterface( nrf_drv_usbd_setup_t const * const p_setup) { //no alternate setting is supported - STALL always NRF_LOG_ERROR("No alternate interfaces supported."); nrf_drv_usbd_setup_stall(); } static void usbd_setup_SetProtocol( nrf_drv_usbd_setup_t const * const p_setup) { if (p_setup->bmRequestType == 0x21) { //accept any value nrf_drv_usbd_setup_clear(); return; } NRF_LOG_ERROR("Set Protocol wrong type: 0x%2x.", p_setup->bmRequestType); nrf_drv_usbd_setup_stall(); } /** @} */ /* End of processing setup requests functions */ static void usbd_event_handler(nrf_drv_usbd_evt_t const * const p_event) { switch (p_event->type) { case NRF_DRV_USBD_EVT_SUSPEND: NRF_LOG_INFO("SUSPEND state detected"); m_usbd_suspend_state_req = true; break; case NRF_DRV_USBD_EVT_RESUME: NRF_LOG_INFO("RESUMING from suspend"); m_usbd_suspend_state_req = false; break; case NRF_DRV_USBD_EVT_WUREQ: NRF_LOG_INFO("RemoteWU initiated"); m_usbd_suspend_state_req = false; break; case NRF_DRV_USBD_EVT_RESET: { ret_code_t ret = ep_configuration(0); ASSERT(ret == NRF_SUCCESS); UNUSED_VARIABLE(ret); m_usbd_suspend_state_req = false; break; } case NRF_DRV_USBD_EVT_SOF: { static uint32_t cycle = 0; ++cycle; if ((cycle % (m_usbd_configured ? 500 : 100)) == 0) { bsp_board_led_invert(LED_USB_STATUS); } break; } case NRF_DRV_USBD_EVT_EPTRANSFER: if (NRF_DRV_USBD_EPIN1 == p_event->data.eptransfer.ep) { m_send_mouse_position = false; } else if (NRF_DRV_USBD_EPIN0 == p_event->data.eptransfer.ep) { if (NRF_USBD_EP_OK == p_event->data.eptransfer.status) { if (!nrf_drv_usbd_errata_154()) { /* Transfer ok - allow status stage */ nrf_drv_usbd_setup_clear(); } } else if (NRF_USBD_EP_ABORTED == p_event->data.eptransfer.status) { /* Just ignore */ NRF_LOG_INFO("Transfer aborted event on EPIN0"); } else { NRF_LOG_ERROR("Transfer failed on EPIN0: %d", p_event->data.eptransfer.status); nrf_drv_usbd_setup_stall(); } } else if (NRF_DRV_USBD_EPOUT0 == p_event->data.eptransfer.ep) { /* NOTE: No EPOUT0 data transfers are used. * The code is here as a pattern how to support such a transfer. */ if (NRF_USBD_EP_OK == p_event->data.eptransfer.status) { /* NOTE: Data values or size may be tested here to decide if clear or stall. * If errata 154 is present the data transfer is acknowledged by the hardware. */ if (!nrf_drv_usbd_errata_154()) { /* Transfer ok - allow status stage */ nrf_drv_usbd_setup_clear(); } } else if (NRF_USBD_EP_ABORTED == p_event->data.eptransfer.status) { /* Just ignore */ NRF_LOG_INFO("Transfer aborted event on EPOUT0"); } else { NRF_LOG_ERROR("Transfer failed on EPOUT0: %d", p_event->data.eptransfer.status); nrf_drv_usbd_setup_stall(); } } else { /* Nothing to do */ } break; case NRF_DRV_USBD_EVT_SETUP: { nrf_drv_usbd_setup_t setup; nrf_drv_usbd_setup_get(&setup); switch (setup.bmRequest) { case 0x00: // GetStatus usbd_setup_GetStatus(&setup); break; case 0x01: // CleartFeature usbd_setup_ClearFeature(&setup); break; case 0x03: // SetFeature usbd_setup_SetFeature(&setup); break; case 0x05: // SetAddress //nothing to do, handled by hardware; but don't STALL break; case 0x06: // GetDescriptor usbd_setup_GetDescriptor(&setup); break; case 0x08: // GetConfig usbd_setup_GetConfig(&setup); break; case 0x09: // SetConfig usbd_setup_SetConfig(&setup); break; //HID class case 0x0A: // SetIdle usbd_setup_SetIdle(&setup); break; case 0x0B: // SetProtocol or SetInterface if (setup.bmRequestType == 0x01) // standard request, recipient=interface { usbd_setup_SetInterface(&setup); } else if (setup.bmRequestType == 0x21) // class request, recipient=interface { usbd_setup_SetProtocol(&setup); } else { NRF_LOG_ERROR("Command 0xB. Unknown request: 0x%2x", setup.bmRequestType); nrf_drv_usbd_setup_stall(); } break; default: NRF_LOG_ERROR("Unknown request: 0x%2x", setup.bmRequest); nrf_drv_usbd_setup_stall(); return; } break; } default: break; } } static void move_mouse_pointer(void) { static uint32_t databuffer; if (!m_usbd_configured) return; if (!m_send_mouse_position) { switch (m_mouse_position & 0x3) { case 0: /* X = 10, rest all are unchanged */ databuffer = 0x00000A00; break; case 1: /* Y = 10, rest all are unchanged */ databuffer = 0x000A0000; break; case 2: /* X = -10, rest all are unchanged */ databuffer = 0x0000F600; break; case 3: /* Y = -10, rest all are unchanged */ databuffer = 0x00F60000; break; } m_mouse_position++; /* Send data */ static const nrf_drv_usbd_transfer_t transfer = { .p_data = {.tx = &databuffer}, .size = sizeof(databuffer) }; m_send_mouse_position = true; UNUSED_RETURN_VALUE(nrf_drv_usbd_ep_transfer( NRF_DRV_USBD_EPIN1, &transfer)); } } static void power_usb_event_handler(nrf_drv_power_usb_evt_t event) { switch (event) { case NRF_DRV_POWER_USB_EVT_DETECTED: NRF_LOG_INFO("USB power detected"); if (!nrf_drv_usbd_is_enabled()) { nrf_drv_usbd_enable(); } break; case NRF_DRV_POWER_USB_EVT_REMOVED: NRF_LOG_INFO("USB power removed"); m_usbd_configured = false; m_send_mouse_position = false; if (nrf_drv_usbd_is_started()) { nrf_drv_usbd_stop(); } if (nrf_drv_usbd_is_enabled()) { nrf_drv_usbd_disable(); } /* Turn OFF LEDs */ bsp_board_led_off(LED_USB_STATUS); bsp_board_led_off(LED_USB_POWER); break; case NRF_DRV_POWER_USB_EVT_READY: NRF_LOG_INFO("USB ready"); bsp_board_led_on(LED_USB_POWER); if (!nrf_drv_usbd_is_started()) { nrf_drv_usbd_start(true); } break; default: ASSERT(false); } } static void bsp_evt_handler(bsp_event_t evt) { switch ((unsigned int)evt) { case BSP_EVENT_SYSOFF: { m_system_off_req = true; break; } case CONCAT_2(BSP_EVENT_KEY_, BTN_DATA_SEND): { m_send_flag = 1; break; } case BTN_DATA_KEY_RELEASE: { m_send_flag = 0; break; } default: return; } } static void init_power_clock(void) { ret_code_t ret; /* Initializing power and clock */ ret = nrf_drv_clock_init(); APP_ERROR_CHECK(ret); ret = nrf_drv_power_init(NULL); APP_ERROR_CHECK(ret); nrf_drv_clock_hfclk_request(NULL); nrf_drv_clock_lfclk_request(NULL); while (!(nrf_drv_clock_hfclk_is_running() && nrf_drv_clock_lfclk_is_running())) { /* Just waiting */ } ret = app_timer_init(); APP_ERROR_CHECK(ret); /* Avoid warnings if assertion is disabled */ UNUSED_VARIABLE(ret); } static void init_bsp(void) { ret_code_t ret; ret = bsp_init(BSP_INIT_BUTTONS, bsp_evt_handler); APP_ERROR_CHECK(ret); ret = bsp_event_to_button_action_assign( BTN_SYSTEM_OFF, BSP_BUTTON_ACTION_RELEASE, BSP_EVENT_SYSOFF); APP_ERROR_CHECK(ret); ret = bsp_event_to_button_action_assign(BTN_DATA_SEND, BSP_BUTTON_ACTION_RELEASE, BTN_DATA_KEY_RELEASE); APP_ERROR_CHECK(ret); /* Avoid warnings if assertion is disabled */ UNUSED_VARIABLE(ret); } static void init_cli(void) { ret_code_t ret; ret = bsp_cli_init(bsp_evt_handler); APP_ERROR_CHECK(ret); nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG; uart_config.pseltxd = 20; uart_config.pselrxd = 21; uart_config.hwfc = NRF_UART_HWFC_DISABLED; ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO); APP_ERROR_CHECK(ret); ret = nrf_cli_start(&m_cli_uart); APP_ERROR_CHECK(ret); } static void log_resetreason(void) { /* Reset reason */ uint32_t rr = nrf_power_resetreas_get(); NRF_LOG_INFO("Reset reasons:"); if (0 == rr) { NRF_LOG_INFO("- NONE"); } if (0 != (rr & NRF_POWER_RESETREAS_RESETPIN_MASK)) { NRF_LOG_INFO("- RESETPIN"); } if (0 != (rr & NRF_POWER_RESETREAS_DOG_MASK )) { NRF_LOG_INFO("- DOG"); } if (0 != (rr & NRF_POWER_RESETREAS_SREQ_MASK )) { NRF_LOG_INFO("- SREQ"); } if (0 != (rr & NRF_POWER_RESETREAS_LOCKUP_MASK )) { NRF_LOG_INFO("- LOCKUP"); } if (0 != (rr & NRF_POWER_RESETREAS_OFF_MASK )) { NRF_LOG_INFO("- OFF"); } if (0 != (rr & NRF_POWER_RESETREAS_LPCOMP_MASK )) { NRF_LOG_INFO("- LPCOMP"); } if (0 != (rr & NRF_POWER_RESETREAS_DIF_MASK )) { NRF_LOG_INFO("- DIF"); } if (0 != (rr & NRF_POWER_RESETREAS_NFC_MASK )) { NRF_LOG_INFO("- NFC"); } if (0 != (rr & NRF_POWER_RESETREAS_VBUS_MASK )) { NRF_LOG_INFO("- VBUS"); } } int main(void) { ret_code_t ret; UNUSED_RETURN_VALUE(NRF_LOG_INIT(NULL)); init_power_clock(); init_bsp(); init_cli(); NRF_LOG_INFO("USDB example started."); if (NRF_DRV_USBD_ERRATA_ENABLE) { NRF_LOG_INFO("USB errata 104 %s", (uint32_t)(nrf_drv_usbd_errata_104() ? "enabled" : "disabled")); NRF_LOG_INFO("USB errata 154 %s", (uint32_t)(nrf_drv_usbd_errata_154() ? "enabled" : "disabled")); } log_resetreason(); nrf_power_resetreas_clear(nrf_power_resetreas_get()); /* USB work starts right here */ ret = nrf_drv_usbd_init(usbd_event_handler); APP_ERROR_CHECK(ret); /* Configure selected size of the packed on EP0 */ nrf_drv_usbd_ep_max_packet_size_set(NRF_DRV_USBD_EPOUT0, EP0_MAXPACKETSIZE); nrf_drv_usbd_ep_max_packet_size_set(NRF_DRV_USBD_EPIN0, EP0_MAXPACKETSIZE); /* Configure LED and button */ bsp_board_init(BSP_INIT_LEDS); bsp_board_led_on(LED_RUNNING); bsp_board_led_on(LED_ACTIVE); if (USBD_POWER_DETECTION) { static const nrf_drv_power_usbevt_config_t config = { .handler = power_usb_event_handler }; ret = nrf_drv_power_usbevt_init(&config); APP_ERROR_CHECK(ret); } else { NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now"); nrf_delay_us(STARTUP_DELAY); if (!nrf_drv_usbd_is_enabled()) { nrf_drv_usbd_enable(); ret = ep_configuration(0); APP_ERROR_CHECK(ret); } /* Wait for regulator power up */ while (NRF_DRV_POWER_USB_STATE_CONNECTED == nrf_drv_power_usbstatus_get()) { /* Just waiting */ } if (NRF_DRV_POWER_USB_STATE_READY == nrf_drv_power_usbstatus_get()) { if (!nrf_drv_usbd_is_started()) { nrf_drv_usbd_start(true); } } else { nrf_drv_usbd_disable(); } } while (true) { if (m_system_off_req) { NRF_LOG_INFO("Going to system OFF"); NRF_LOG_FLUSH(); bsp_board_led_off(LED_RUNNING); bsp_board_led_off(LED_ACTIVE); nrf_power_system_off(); } if (m_usbd_suspended != m_usbd_suspend_state_req) { if (m_usbd_suspend_state_req) { m_usbd_suspended = nrf_drv_usbd_suspend(); if (m_usbd_suspended) { bsp_board_leds_off(); } } else { m_usbd_suspended = false; } } if (m_usbd_configured) { if (m_send_flag) { if (m_usbd_suspended) { if (m_usbd_rwu_enabled) { UNUSED_RETURN_VALUE(nrf_drv_usbd_wakeup_req()); } } else { NRF_LOG_INFO(" TX pointer"); move_mouse_pointer(); } } } nrf_cli_process(&m_cli_uart); UNUSED_RETURN_VALUE(NRF_LOG_PROCESS()); bsp_board_led_off(LED_RUNNING); /* Even if we miss an event enabling USB, * USB event would wake us up. */ __WFE(); /* Clear SEV flag if CPU was woken up by event */ __SEV(); __WFE(); bsp_board_led_on(LED_RUNNING); } }
BR
shen
