I want to add an OUT endpoint to the USBD example, but it is not successful. I cannot find the relevant tutorial. Below is my main.c, asking for help, thank you very much.
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "app_timer.h"
#include "app_error.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
* @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
"uart_cli:~$ ",
&m_cli_uart_transport.transport,
'\r',
4);
static bool m_send_flag = 0;
#define BTN_DATA_SEND 0
#define BTN_DATA_KEY_RELEASE (bsp_event_t)(BSP_EVENT_KEY_LAST + 1)
* @brief Button used to simulate mouse move
* Every button press would move the cursor one step in the square.
#define BTN_MOUSE_MOVE BSP_BOARD_BUTTON_0
* @brief Button for system OFF request
* This button would set the request for system OFF.
#define BTN_SYSTEM_OFF BSP_BOARD_BUTTON_1
* @brief Configuration status LED
* This LED would blink quickly (5 Hz) when device is not configured
* or slowly (1 Hz) when configured and working properly.
#define LED_USB_STATUS BSP_BOARD_LED_0
* @brief Power detect LED
* The LED is ON when connection is detected on USB port.
* It is turned off when connection is removed.
#define LED_USB_POWER BSP_BOARD_LED_1
* @brief Running LED
* LED that turns on when program is not sleeping
#define LED_RUNNING BSP_BOARD_LED_2
* @brief Active LED
* LED that turns on when program is not in system OFF
#define LED_ACTIVE BSP_BOARD_LED_3
* @brief Enable power USB detection
* Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
* @brief Startup delay
* Number of microseconds to start USBD after powering up.
* Kind of port insert debouncing.
#define STARTUP_DELAY 100
/** Maximum size of the packed transfered by EP0 */
#define EP0_MAXPACKETSIZE NRF_DRV_USBD_EPSIZE
/** Device descriptor */
#define USBD_DEVICE_DESCRIPTOR \
0x12, /* bLength | size of descriptor */\
0x01, /* bDescriptorType | descriptor type */\
0x00, 0x02, /* bcdUSB | USB spec release (ver 2.0) */\
0x00, /* bDeviceClass ¦ class code (each interface specifies class information) */\
0x00, /* bDeviceSubClass ¦ device sub-class (must be set to 0 because class code is 0) */\
0x00, /* bDeviceProtocol | device protocol (no class specific protocol) */\
EP0_MAXPACKETSIZE, /* bMaxPacketSize0 | maximum packet size (64 bytes) */\
0x15, 0x19, /* vendor ID (0x1915 Nordic) */\
0x0A, 0x52, /* product ID (0x520A nRF52 HID mouse on nrf_drv) */\
0x01, 0x01, /* bcdDevice | final device release number in BCD Format */\
USBD_STRING_MANUFACTURER_IX, /* iManufacturer | index of manufacturer string */\
USBD_STRING_PRODUCT_IX, /* iProduct | index of product string */\
USBD_STRING_SERIAL_IX, /* iSerialNumber | Serial Number string */\
0x01 /* bNumConfigurations | number of configurations */
/** Configuration descriptor */
#define DEVICE_SELF_POWERED 1
#define REMOTE_WU 1
#define USBD_CONFIG_DESCRIPTOR_SIZE 9
#define USBD_CONFIG_DESCRIPTOR_FULL_SIZE (9 + (9 + 9 + 7))
#define USBD_CONFIG_DESCRIPTOR \
0x09, /* bLength | length of descriptor */\
0x02, /* bDescriptorType | descriptor type (CONFIGURATION) */\
USBD_CONFIG_DESCRIPTOR_FULL_SIZE, 0x00, /* wTotalLength | total length of descriptor(s) */\
0x01, /* bNumInterfaces */\
0x01, /* bConfigurationValue */\
0x00, /* index of string Configuration | configuration string index (not supported) */\
0x80| (((DEVICE_SELF_POWERED) ? 1U:0U)<<6) | (((REMOTE_WU) ? 1U:0U)<<5), /* bmAttributes */\
49 /* maximum power in steps of 2mA (98mA) */
#define USBD_INTERFACE0_DESCRIPTOR \
0x09, /* bLength */\
0x04, /* bDescriptorType | descriptor type (INTERFACE) */\
0x00, /* bInterfaceNumber */\
0x00, /* bAlternateSetting */\
0x02, /* bNumEndpoints | number of endpoints (1) */\
0x03, /* bInterfaceClass | interface class (3..defined by USB spec: HID) */\
0x00, /* bInterfaceSubClass |interface sub-class (0.. no boot interface) */\
0x01, /* bInterfaceProtocol | interface protocol (1..defined by USB spec: mouse) */\
0x00 /* interface string index (not supported) */
* HID Table must normally be between Interface and EndPoint Descriptor
* as written in HID spec§7.1 but it doesn't work with OSR2.1
#define USBD_HID0_DESCRIPTOR \
0x09, /* bLength | length of descriptor (9 bytes) */\
0x21, /* bHIDDescriptor | descriptor type (HID) */\
0x11, 0x01, /* HID wBcdHID | Spec version 01.11 */\
0x00, /* bCountryCode | HW Target country */\
0x01, /* bNumDescriptors | Number of HID class descriptors to follow */\
0x22, /* bDescriptorType | Report descriptor type is 0x22 (report) */\
(uint8_t)(USBD_MOUSE_REPORT_DESCRIPTOR_SIZE), /* Total length of Report descr., low byte */ \
(uint8_t)(USBD_MOUSE_REPORT_DESCRIPTOR_SIZE / 256) /* Total length of Report descr., high byte */
#define USBD_ENDPOINT1_DESCRIPTOR \
0x07, /* bLength | length of descriptor (7 bytes) */\
0x05, /* bDescriptorType | descriptor type (ENDPOINT) */\
0x81, /* bEndpointAddress | endpoint address (IN endpoint, endpoint 1) */\
0x03, /* bmAttributes | endpoint attributes (interrupt) */\
0x08,0x00, /* bMaxPacketSizeLowByte,bMaxPacketSizeHighByte | maximum packet size (8 bytes) */\
0x08 /* bInterval | polling interval (10ms) */
#define USBD_ENDPOINT1_DESCRIPTOR_OUT \
0x01, /* bEndpointAddress | endpoint address (IN endpoint, endpoint 1) */\
0x02,0x00, /* bMaxPacketSizeLowByte,bMaxPacketSizeHighByte | maximum packet size (8 bytes) */\
* String config descriptor
#define USBD_STRING_LANG_IX 0x00
#define USBD_STRING_LANG \
0x04, /* length of descriptor */\
0x03, /* descriptor type */\
0x09, /* */\
0x04 /* Supported LangID = 0x0409 (US-English) */
#define USBD_STRING_MANUFACTURER_IX 0x01
#define USBD_STRING_MANUFACTURER \
42, /* length of descriptor (? bytes) */\
'N', 0x00, /* Define Unicode String "Nordic Semiconductor */\
'o', 0x00, \
'r', 0x00, \
'd', 0x00, \
'i', 0x00, \
'c', 0x00, \
' ', 0x00, \
'S', 0x00, \
'e', 0x00, \
'm', 0x00, \
'i', 0x00, \
'c', 0x00, \
'o', 0x00, \
'n', 0x00, \
'd', 0x00, \
'u', 0x00, \
'c', 0x00, \
't', 0x00, \
'o', 0x00, \
'r', 0x00
#define USBD_STRING_PRODUCT_IX 0x02
#define USBD_STRING_PRODUCT \
72, /* length of descriptor (? bytes) */\
'n', 0x00, /* generic unicode string for all devices */\
'R', 0x00, \
'F', 0x00, \
'5', 0x00, \
'2', 0x00, \
' ', 0x00, \
'U', 0x00, \
'S', 0x00, \
'B', 0x00, \
' ', 0x00, \
'H', 0x00, \
'I', 0x00, \
'D', 0x00, \
' ', 0x00, \
'm', 0x00, \
'o', 0x00, \
'u', 0x00, \
's', 0x00, \
'e', 0x00, \
' ', 0x00, \
'o', 0x00, \
'n', 0x00, \
' ', 0x00, \
'n', 0x00, \
'r', 0x00, \
'f', 0x00, \
'_', 0x00, \
'd', 0x00, \
'r', 0x00, \
'v', 0x00, \
' ', 0x00, \
'D', 0x00, \
'e', 0x00, \
'm', 0x00, \
'o', 0x00, \
#define USBD_STRING_SERIAL_IX 0x00
#define USBD_MOUSE_REPORT_DESCRIPTOR_SIZE 61
#define USBD_MOUSE_REPORT_DESCRIPTOR \
0x05, 0x01, \
0x09, 0x06, \
0xa1, 0x01, \
0x05, 0x07, \
0x19, 0xe0, \
0x29, 0xe7, \
0x15, 0x00, \
0x25, 0x01, \
0x95, 0x08, \
0x75, 0x01, \
0x81, 0x02, \
0x95, 0x01, \
0x75, 0x08, \
0x81, 0x03, \
0x95, 0x06, \
0x75, 0x08, \
0x25, 0xFF, \
0x19, 0x00, \
0x29, 0x65, \
0x81, 0x00, \
0x25, 0x01, \
0x95, 0x02, \
0x75, 0x01, \
0x05, 0x08, \
0x19, 0x01, \
0x29, 0x02, \
0x91, 0x02, \
0x95, 0x01, \
0x75, 0x06, \
0x91, 0x03, \
0xc0 \
static const uint8_t get_descriptor_device[] = {
static const uint8_t get_descriptor_configuration[] = {
USBD_CONFIG_DESCRIPTOR,
USBD_INTERFACE0_DESCRIPTOR,
USBD_HID0_DESCRIPTOR,
USBD_ENDPOINT1_DESCRIPTOR,
static const uint8_t get_descriptor_string_lang[] = {
USBD_STRING_LANG
static const uint8_t get_descriptor_string_manuf[] = {
static const uint8_t get_descriptor_string_prod[] = {
USBD_STRING_PRODUCT
static const uint8_t get_descriptor_report_interface_0[] = {
static const uint8_t get_config_resp_configured[] = {1};
static const uint8_t get_config_resp_unconfigured[] = {0};
static const uint8_t get_status_device_resp_nrwu[] = {
((DEVICE_SELF_POWERED) ? 1 : 0), //LSB first: self-powered, no remoteWk
0
static const uint8_t get_status_device_resp_rwu[] = {
((DEVICE_SELF_POWERED) ? 1 : 0) | 2, //LSB first: self-powered, remoteWk
0
static const uint8_t get_status_interface_resp[] = {0, 0};
static const uint8_t get_status_ep_halted_resp[] = {1, 0};
static const uint8_t get_status_ep_active_resp[] = {0, 0};
#define GET_CONFIG_DESC_SIZE sizeof(get_descriptor_configuration)
#define GET_INTERFACE_DESC_SIZE 9
#define GET_HID_DESC_SIZE 9
#define GET_ENDPOINT_DESC_SIZE 7
#define get_descriptor_interface_0 \
&get_descriptor_configuration[9]
#define get_descriptor_hid_0 \
&get_descriptor_configuration[9+GET_INTERFACE_DESC_SIZE]
#define get_descriptor_endpoint_1 \
&get_descriptor_configuration[9+GET_INTERFACE_DESC_SIZE+GET_HID_DESC_SIZE]
#define get_descriptor_endpoint_1_OUT \
&get_descriptor_configuration[9+GET_INTERFACE_DESC_SIZE+GET_HID_DESC_SIZE+GET_ENDPOINT_DESC_SIZE]
* @brief USB configured flag
* The flag that is used to mark the fact that USB is configured and ready
* to transmit data
static volatile bool m_usbd_configured = false;
* @brief USB suspended
* The flag that is used to mark the fact that USB is suspended and requires wake up
* if new data is available.
* @note This variable is changed from the main loop.
static bool m_usbd_suspended = false;
* @brief Mark the fact if remote wake up is enabled
* The internal flag that marks if host enabled the remote wake up functionality in this device.
static
#if REMOTE_WU
volatile // Disallow optimization only if Remote wakeup is enabled
bool m_usbd_rwu_enabled = false;
* @brief Current mouse position
* The index of current mouse position that would be changed to real offset.
static volatile uint8_t m_mouse_position = 0;
* @brief The flag for mouse position send pending
* Setting this flag means that USB endpoint is busy by sending
* last mouse position.
static volatile bool m_send_mouse_position = false;
* @brief The requested suspend state
* The currently requested suspend state based on the events
* received from USBD library.
* If the value here is different than the @ref m_usbd_suspended
* the state changing would be processed inside main loop.
static volatile bool m_usbd_suspend_state_req = false;
* @brief System OFF request flag
* This flag is used in button event processing and marks the fact that
* system OFF should be activated from main loop.
static volatile bool m_system_off_req = false;
* @brief Setup all the endpoints for selected configuration
* Function sets all the endpoints for specific configuration.
* @note
* Setting the configuration index 0 means technically disabling the HID interface.
* Such configuration should be set when device is starting or USB reset is detected.
* @param index Configuration index
* @retval NRF_ERROR_INVALID_PARAM Invalid configuration
* @retval NRF_SUCCESS Configuration successfully set
static ret_code_t ep_configuration(uint8_t index)
if ( index == 1 )
nrf_drv_usbd_ep_dtoggle_clear(NRF_DRV_USBD_EPIN1);
nrf_drv_usbd_ep_stall_clear(NRF_DRV_USBD_EPIN1);
nrf_drv_usbd_ep_enable(NRF_DRV_USBD_EPIN1);
nrf_drv_usbd_ep_dtoggle_clear(NRF_DRV_USBD_EPOUT1);
nrf_drv_usbd_ep_stall_clear(NRF_DRV_USBD_EPOUT1);
nrf_drv_usbd_ep_enable(NRF_DRV_USBD_EPOUT1);
m_usbd_configured = true;
nrf_drv_usbd_setup_clear();
else if ( index == 0 )
nrf_drv_usbd_ep_disable(NRF_DRV_USBD_EPIN1);
nrf_drv_usbd_ep_disable(NRF_DRV_USBD_EPOUT1);
return NRF_ERROR_INVALID_PARAM;
return NRF_SUCCESS;
* @name Processing setup requests
* @brief Respond on ep 0
* Auxiliary function for sending respond on endpoint 0
* @param[in] p_setup Pointer to setup data from current setup request.
* It would be used to calculate the size of data to send.
* @param[in] p_data Pointer to the data to send.
* @param[in] size Number of bytes to send.
* @note Data pointed by p_data has to be available till the USBD_EVT_BUFREADY event.
static void respond_setup_data(
nrf_drv_usbd_setup_t const * const p_setup,
void const * p_data, size_t size)
/* Check the size against required response size */
if (size > p_setup->wLength)
size = p_setup->wLength;
ret_code_t ret;
nrf_drv_usbd_transfer_t transfer =
.p_data = {.tx = p_data},
.size = size
ret = nrf_drv_usbd_ep_transfer(NRF_DRV_USBD_EPIN0, &transfer);
if (ret != NRF_SUCCESS)
NRF_LOG_ERROR("Transfer starting failed: %d", (uint32_t)ret);
ASSERT(ret == NRF_SUCCESS);
UNUSED_VARIABLE(ret);
/** React to GetStatus */
static void usbd_setup_GetStatus(nrf_drv_usbd_setup_t const * const p_setup)
switch (p_setup->bmRequestType)
case 0x80: // Device
if (((p_setup->wIndex) & 0xff) == 0)
respond_setup_data(
p_setup,
m_usbd_rwu_enabled ? get_status_device_resp_rwu : get_status_device_resp_nrwu,
sizeof(get_status_device_resp_nrwu));
return;
case 0x81: // Interface
if (m_usbd_configured) // Respond only if configured
if (((p_setup->wIndex) & 0xff) == 0) // Only interface 0 supported
respond_setup_data(
p_setup,
get_status_interface_resp,
sizeof(get_status_interface_resp));
return;
case 0x82: // Endpoint
if (((p_setup->wIndex) & 0xff) == 0) // Endpoint 0
respond_setup_data(
p_setup,
get_status_ep_active_resp,
sizeof(get_status_ep_active_resp));
return;
if (m_usbd_configured) // Other endpoints responds if configured
if (((p_setup->wIndex) & 0xff) == NRF_DRV_USBD_EPIN1)
if (nrf_drv_usbd_ep_stall_check(NRF_DRV_USBD_EPIN1))
respond_setup_data(
p_setup,
get_status_ep_halted_resp,
sizeof(get_status_ep_halted_resp));
return;
respond_setup_data(
p_setup,
return;
else if (((p_setup->wIndex) & 0xff) == NRF_DRV_USBD_EPOUT1)
if (nrf_drv_usbd_ep_stall_check(NRF_DRV_USBD_EPOUT1))
respond_setup_data(
p_setup,
return;
respond_setup_data(
p_setup,
return;
break; // Just go to stall
NRF_LOG_ERROR("Unknown status: 0x%2x", p_setup->bmRequestType);
nrf_drv_usbd_setup_stall();
static void usbd_setup_ClearFeature(nrf_drv_usbd_setup_t const * const p_setup)
if ((p_setup->bmRequestType) == 0x02) // standard request, recipient=endpoint
if ((p_setup->wValue) == 0)
if ((p_setup->wIndex) == NRF_DRV_USBD_EPIN1)
return;
else if ((p_setup->wIndex) == NRF_DRV_USBD_EPOUT1)
return;
else if ((p_setup->bmRequestType) == 0x0) // standard request, recipient=device
if (REMOTE_WU)
if ((p_setup->wValue) == 1) // Feature Wakeup
return;
NRF_LOG_ERROR("Unknown feature to clear");
static void usbd_setup_SetFeature(nrf_drv_usbd_setup_t const * const p_setup)
if ((p_setup->wValue) == 0) // Feature HALT
nrf_drv_usbd_ep_stall(NRF_DRV_USBD_EPIN1);
return;
nrf_drv_usbd_ep_stall(NRF_DRV_USBD_EPOUT1);
return;
if (REMOTE_WU)
m_usbd_rwu_enabled = true;
return;
NRF_LOG_ERROR("Unknown feature to set");
static void usbd_setup_GetDescriptor(nrf_drv_usbd_setup_t const * const p_setup)
//determine which descriptor has been asked for
switch ((p_setup->wValue) >> 8)
case 1: // Device
if ((p_setup->bmRequestType) == 0x80)
respond_setup_data(
p_setup,
get_descriptor_device,
sizeof(get_descriptor_device));
return;
case 2: // Configuration
respond_setup_data(
p_setup,
get_descriptor_configuration,
GET_CONFIG_DESC_SIZE);
return;
case 3: // String
// Select the string
switch ((p_setup->wValue) & 0xFF)
case USBD_STRING_LANG_IX:
respond_setup_data(
p_setup,
get_descriptor_string_lang,
sizeof(get_descriptor_string_lang));
return;
case USBD_STRING_MANUFACTURER_IX:
respond_setup_data(
p_setup,
get_descriptor_string_manuf,
sizeof(get_descriptor_string_manuf));
return;
case USBD_STRING_PRODUCT_IX:
respond_setup_data(p_setup,
get_descriptor_string_prod,
sizeof(get_descriptor_string_prod));
return;
case 4: // Interface
// Which interface?
if ((((p_setup->wValue) & 0xFF) == 0))
respond_setup_data(
p_setup,
get_descriptor_interface_0,
GET_INTERFACE_DESC_SIZE);
return;
case 5: // Endpoint
// Which endpoint?
if (((p_setup->wValue) & 0xFF) == 0x81)
respond_setup_data(
p_setup,
get_descriptor_endpoint_1,
GET_ENDPOINT_DESC_SIZE);
return;
else if (((p_setup->wValue) & 0xFF) == 0x01)
respond_setup_data(
p_setup,
get_descriptor_endpoint_1_OUT,
return;
case 0x21: // HID
if ((p_setup->bmRequestType) == 0x81)
// Which interface
if (((p_setup->wValue) & 0xFF) == 0)
respond_setup_data(
p_setup,
get_descriptor_hid_0,
GET_HID_DESC_SIZE);
return;
case 0x22: // HID report
// Which interface?
respond_setup_data(
p_setup,
get_descriptor_report_interface_0,
sizeof(get_descriptor_report_interface_0));
return;
break; // Not supported - go to stall
NRF_LOG_ERROR("Unknown descriptor requested: 0x%2x, type: 0x%2x or value: 0x%2x",
p_setup->wValue >> 8,
p_setup->bmRequestType,
p_setup->wValue & 0xFF);
static void usbd_setup_GetConfig(nrf_drv_usbd_setup_t const * const p_setup)
respond_setup_data(
p_setup,
get_config_resp_configured,
sizeof(get_config_resp_configured));
respond_setup_data(
p_setup,
get_config_resp_unconfigured,
sizeof(get_config_resp_unconfigured));
static void usbd_setup_SetConfig(nrf_drv_usbd_setup_t const * const p_setup)
if ((p_setup->bmRequestType) == 0x00)
// accept only 0 and 1
if (((p_setup->wIndex) == 0) && ((p_setup->wLength) == 0) &&
((p_setup->wValue) <= UINT8_MAX))
if (NRF_SUCCESS == ep_configuration((uint8_t)(p_setup->wValue)))
return;
NRF_LOG_ERROR("Wrong configuration: Index: 0x%2x, Value: 0x%2x.",
p_setup->wIndex,
p_setup->wValue);
static void usbd_setup_SetIdle(nrf_drv_usbd_setup_t const * const p_setup)
if (p_setup->bmRequestType == 0x21)
//accept any value
return;
NRF_LOG_ERROR("Set Idle wrong type: 0x%2x.", p_setup->bmRequestType);
static void usbd_setup_SetInterface(
//no alternate setting is supported - STALL always
NRF_LOG_ERROR("No alternate interfaces supported.");
static void usbd_setup_SetProtocol(
//accept any value
return;
NRF_LOG_ERROR("Set Protocol wrong type: 0x%2x.", p_setup->bmRequestType);
/** @} */ /* End of processing setup requests functions */
static void usbd_event_handler(nrf_drv_usbd_evt_t const * const p_event)
switch (p_event->type)
case NRF_DRV_USBD_EVT_SUSPEND:
NRF_LOG_INFO("SUSPEND state detected");
m_usbd_suspend_state_req = true;
case NRF_DRV_USBD_EVT_RESUME:
NRF_LOG_INFO("RESUMING from suspend");
case NRF_DRV_USBD_EVT_WUREQ:
NRF_LOG_INFO("RemoteWU initiated");
case NRF_DRV_USBD_EVT_RESET:
ret_code_t ret = ep_configuration(0);
case NRF_DRV_USBD_EVT_SOF:
static uint32_t cycle = 0;
++cycle;
if ((cycle % (m_usbd_configured ? 500 : 100)) == 0)
bsp_board_led_invert(LED_USB_STATUS);
case NRF_DRV_USBD_EVT_EPTRANSFER:
if (NRF_DRV_USBD_EPIN1 == p_event->data.eptransfer.ep)
if (NRF_DRV_USBD_EPIN0 == p_event->data.eptransfer.ep)
if (NRF_USBD_EP_OK == p_event->data.eptransfer.status)
if (!nrf_drv_usbd_errata_154())
/* Transfer ok - allow status stage */
else if (NRF_USBD_EP_ABORTED == p_event->data.eptransfer.status)
/* Just ignore */
NRF_LOG_INFO("Transfer aborted event on EPIN0");
NRF_LOG_ERROR("Transfer failed on EPIN0: %d", p_event->data.eptransfer.status);
if (NRF_DRV_USBD_EPOUT0 == p_event->data.eptransfer.ep)
/* NOTE: No EPOUT0 data transfers are used.
* The code is here as a pattern how to support such a transfer. */
/* NOTE: Data values or size may be tested here to decide if clear or stall.
* If errata 154 is present the data transfer is acknowledged by the hardware. */
/* Just ignore */
NRF_LOG_INFO("Transfer aborted event on EPOUT0");
NRF_LOG_ERROR("Transfer failed on EPOUT0: %d", p_event->data.eptransfer.status);
/* Nothing to do */
case NRF_DRV_USBD_EVT_SETUP:
nrf_drv_usbd_setup_t setup;
nrf_drv_usbd_setup_get(&setup);
switch (setup.bmRequest)
case 0x00: // GetStatus
usbd_setup_GetStatus(&setup);
case 0x01: // CleartFeature
usbd_setup_ClearFeature(&setup);
case 0x03: // SetFeature
usbd_setup_SetFeature(&setup);
case 0x05: // SetAddress
//nothing to do, handled by hardware; but don't STALL
case 0x06: // GetDescriptor
usbd_setup_GetDescriptor(&setup);
case 0x08: // GetConfig
usbd_setup_GetConfig(&setup);
case 0x09: // SetConfig
usbd_setup_SetConfig(&setup);
//HID class
case 0x0A: // SetIdle
usbd_setup_SetIdle(&setup);
case 0x0B: // SetProtocol or SetInterface
if (setup.bmRequestType == 0x01) // standard request, recipient=interface
usbd_setup_SetInterface(&setup);
else if (setup.bmRequestType == 0x21) // class request, recipient=interface
usbd_setup_SetProtocol(&setup);
NRF_LOG_ERROR("Command 0xB. Unknown request: 0x%2x", setup.bmRequestType);
NRF_LOG_ERROR("Unknown request: 0x%2x", setup.bmRequest);
return;
static void move_mouse_pointer(void)
static uint32_t databuffer;
if (!m_usbd_configured)
return;
if (!m_send_mouse_position)
switch (m_mouse_position & 0x3)
case 0:
/* X = 10, rest all are unchanged */
databuffer = 0x00000A00;
case 1:
/* Y = 10, rest all are unchanged */
databuffer = 0x000A0000;
case 2:
/* X = -10, rest all are unchanged */
databuffer = 0x0000F600;
case 3:
/* Y = -10, rest all are unchanged */
databuffer = 0x00F60000;
m_mouse_position++;
/* Send data */
static const nrf_drv_usbd_transfer_t transfer =
.p_data = {.tx = &databuffer},
.size = sizeof(databuffer)
m_send_mouse_position = true;
UNUSED_RETURN_VALUE(nrf_drv_usbd_ep_transfer(
NRF_DRV_USBD_EPIN1,
&transfer));
static void power_usb_event_handler(nrf_drv_power_usb_evt_t event)
switch (event)
case NRF_DRV_POWER_USB_EVT_DETECTED:
NRF_LOG_INFO("USB power detected");
if (!nrf_drv_usbd_is_enabled())
nrf_drv_usbd_enable();
case NRF_DRV_POWER_USB_EVT_REMOVED:
NRF_LOG_INFO("USB power removed");
if (nrf_drv_usbd_is_started())
nrf_drv_usbd_stop();
if (nrf_drv_usbd_is_enabled())
nrf_drv_usbd_disable();
/* Turn OFF LEDs */
bsp_board_led_off(LED_USB_STATUS);
bsp_board_led_off(LED_USB_POWER);
case NRF_DRV_POWER_USB_EVT_READY:
NRF_LOG_INFO("USB ready");
bsp_board_led_on(LED_USB_POWER);
if (!nrf_drv_usbd_is_started())
nrf_drv_usbd_start(true);
ASSERT(false);
static void bsp_evt_handler(bsp_event_t evt)
switch ((unsigned int)evt)
case BSP_EVENT_SYSOFF:
m_system_off_req = true;
case CONCAT_2(BSP_EVENT_KEY_, BTN_DATA_SEND):
m_send_flag = 1;
case BTN_DATA_KEY_RELEASE:
m_send_flag = 0;
return;
static void init_power_clock(void)
ret_code_t ret;
/* Initializing power and clock */
ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
ret = nrf_drv_power_init(NULL);
nrf_drv_clock_hfclk_request(NULL);
while (!(nrf_drv_clock_hfclk_is_running() &&
nrf_drv_clock_lfclk_is_running()))
/* Just waiting */
ret = app_timer_init();
/* Avoid warnings if assertion is disabled */
static void init_bsp(void)
ret_code_t ret;
ret = bsp_init(BSP_INIT_BUTTONS, bsp_evt_handler);
ret = bsp_event_to_button_action_assign(
BTN_SYSTEM_OFF,
BSP_BUTTON_ACTION_RELEASE,
BSP_EVENT_SYSOFF);
ret = bsp_event_to_button_action_assign(BTN_DATA_SEND,
BTN_DATA_KEY_RELEASE);
static void init_cli(void)
ret_code_t ret;
ret = bsp_cli_init(bsp_evt_handler);
nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
uart_config.pseltxd = 20;
uart_config.pselrxd = 21;
uart_config.hwfc = NRF_UART_HWFC_DISABLED;
ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
ret = nrf_cli_start(&m_cli_uart);
static void log_resetreason(void)
/* Reset reason */
uint32_t rr = nrf_power_resetreas_get();
NRF_LOG_INFO("Reset reasons:");
if (0 == rr)
NRF_LOG_INFO("- NONE");
if (0 != (rr & NRF_POWER_RESETREAS_RESETPIN_MASK))
NRF_LOG_INFO("- RESETPIN");
if (0 != (rr & NRF_POWER_RESETREAS_DOG_MASK ))
NRF_LOG_INFO("- DOG");
if (0 != (rr & NRF_POWER_RESETREAS_SREQ_MASK ))
NRF_LOG_INFO("- SREQ");
if (0 != (rr & NRF_POWER_RESETREAS_LOCKUP_MASK ))
NRF_LOG_INFO("- LOCKUP");
if (0 != (rr & NRF_POWER_RESETREAS_OFF_MASK ))
NRF_LOG_INFO("- OFF");
if (0 != (rr & NRF_POWER_RESETREAS_LPCOMP_MASK ))
NRF_LOG_INFO("- LPCOMP");
if (0 != (rr & NRF_POWER_RESETREAS_DIF_MASK ))
NRF_LOG_INFO("- DIF");
if (0 != (rr & NRF_POWER_RESETREAS_NFC_MASK ))
NRF_LOG_INFO("- NFC");
if (0 != (rr & NRF_POWER_RESETREAS_VBUS_MASK ))
NRF_LOG_INFO("- VBUS");
ret_code_t ret;
UNUSED_RETURN_VALUE(NRF_LOG_INIT(NULL));
init_power_clock();
init_bsp();
init_cli();
NRF_LOG_INFO("USDB example started.");
if (NRF_DRV_USBD_ERRATA_ENABLE)
NRF_LOG_INFO("USB errata 104 %s", (uint32_t)(nrf_drv_usbd_errata_104() ? "enabled" : "disabled"));
NRF_LOG_INFO("USB errata 154 %s", (uint32_t)(nrf_drv_usbd_errata_154() ? "enabled" : "disabled"));
log_resetreason();
nrf_power_resetreas_clear(nrf_power_resetreas_get());
/* USB work starts right here */
ret = nrf_drv_usbd_init(usbd_event_handler);
/* Configure selected size of the packed on EP0 */
nrf_drv_usbd_ep_max_packet_size_set(NRF_DRV_USBD_EPOUT0, EP0_MAXPACKETSIZE);
nrf_drv_usbd_ep_max_packet_size_set(NRF_DRV_USBD_EPIN0, EP0_MAXPACKETSIZE);
/* Configure LED and button */
bsp_board_led_on(LED_RUNNING);
bsp_board_led_on(LED_ACTIVE);
if (USBD_POWER_DETECTION)
static const nrf_drv_power_usbevt_config_t config =
.handler = power_usb_event_handler
ret = nrf_drv_power_usbevt_init(&config);
NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
nrf_delay_us(STARTUP_DELAY);
/* Wait for regulator power up */
while (NRF_DRV_POWER_USB_STATE_CONNECTED
nrf_drv_power_usbstatus_get())
/* Just waiting */
if (NRF_DRV_POWER_USB_STATE_READY == nrf_drv_power_usbstatus_get())
while (true)
if (m_system_off_req)
NRF_LOG_INFO("Going to system OFF");
NRF_LOG_FLUSH();
bsp_board_led_off(LED_RUNNING);
bsp_board_led_off(LED_ACTIVE);
nrf_power_system_off();
if (m_usbd_suspended != m_usbd_suspend_state_req)
if (m_usbd_suspend_state_req)
m_usbd_suspended = nrf_drv_usbd_suspend();
if (m_usbd_suspended)
bsp_board_leds_off();
if (m_send_flag)
if (m_usbd_rwu_enabled)
UNUSED_RETURN_VALUE(nrf_drv_usbd_wakeup_req());
NRF_LOG_INFO(" TX pointer");
move_mouse_pointer();
nrf_cli_process(&m_cli_uart);
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
/* Even if we miss an event enabling USB,
* USB event would wake us up. */
__WFE();
/* Clear SEV flag if CPU was woken up by event */
__SEV();
__WFE();
BR
shen
