We are using nrf52832 with softdevice 6.0.0 ,SDK 15.0. Our code is based on the FreeRTOS heart rate example.
We have one button in our system and when we press it several times in a row the software crashes (without any error and without disconnecting from the debugger)
We use the button using app button driver. The Initializing of the button goes like this:
button_config[0].pin_no = BUTTON_1 ;
button_config[0].active_state = BUTTONS_ACTIVE_STATE;
button_config[0].pull_cfg = BUTTON_PULL;
button_config[0].button_handler = vHAL_button_handler;
app_button_init(button_config,1,5);
app_button_enable();
The button handler simply change a Boolean according to the pressing state.
The button works fine when pushed once in a while. When the button pushed repeatedly the device crashes and i cant see any error in the errors handler ( __WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
Did you encounter issues like this with FreeRTOS? We know that it is a software issue and not HW related because when removing the button definition it does not happen.
Ibrahim
