Cant do bonding after the first time
SDK - 15.2.0
IDE - Segger Embedded Studio
Computer platform Windows 10
I added to example "ble_app_blinky" all the peer manger, because I want to add password  in connection.
I was succeeded  to do it, but the problem is when I want to connect  the phone again.
In the first time the phone ask me to write the pin code. If I close the bluetooth, open it again and try to connect to the module, I cant until I undo matching.
Can someone tell me what to do please?
  • I used to have the same problem. There are 2 possible reasons:
    1/ There is a problem with the phone Bluetooth, usually happens with Android phones.
    2/ Have you implemented this correctly?
    I think you should upload your program here for a better support.
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "ble_conn.h"
    #include "ble_serialization.h"
    #include "cond_field_serialization.h"
    #include "ble_struct_serialization.h"
    #include "ble_gap_struct_serialization.h"
    #include "ble_gatt_struct_serialization.h"
    #include "ble_gattc_struct_serialization.h"
    #include "ble_gatts_struct_serialization.h"
    #include "ble_l2cap_struct_serialization.h"
    #include "app_util.h"
    #include "ble_advertising.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "fds.h"
    #include "nrf_fstorage.h"
    #include "ble_conn_state.h"
    //#include "pstorage.h"
    //#include "device_manager.h"
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(10, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
    #define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                             /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    //BLE_ADVERTISING_DEF(m_advertising);
    static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
            case PM_EVT_CONN_SEC_SUCCEEDED:
                pm_conn_sec_status_t conn_sec_status;
                // Check if the link is authenticated (meaning at least MITM).
                err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
                if (conn_sec_status.mitm_protected)
                    NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                                 ble_conn_state_role(p_evt->conn_handle),
                                 p_evt->conn_handle,
                                 p_evt->params.conn_sec_succeeded.procedure);
                    // The peer did not use MITM, disconnect.
                    NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                    err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                    err_code = sd_ble_gap_disconnect(m_conn_handle,
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                advertising_start(false);
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        static ble_opt_t optS;
        static uint8_t passw[]="123456";
        optS.gap_opt.passkey.p_passkey=&passw[0];
        err_code =sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &optS);
        //BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&sec_mode);
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        adv_params.scan_req_notification = 1;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            bsp_board_led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        ble_lbs_init_t     init     = {0};
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
    #define STATIC_PASSKEY    "123456"
    static void set_static_passkey()
        static ble_opt_t    m_static_pin_option;
        uint8_t passkey[] = STATIC_PASSKEY;
        m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
        uint32_t err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
    void advertising_start(void)
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    //    bsp_board_led_on(ADVERTISING_LED);
         int8_t rssi=0;
         static int32_t rssi_avg = 0;
         static uint8_t num_of_samples=0;
            case BLE_GAP_EVT_CONNECTED:
               // NRF_LOG_INFO("scan_req_report: %d", p_ble_evt->evt.gap_evt.params.scan_req_report.rssi);
                //bsp_board_led_on(CONNECTED_LED);
                //bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Connected 0x%x",p_ble_evt->evt.gap_evt.conn_handle);
                err_code = sd_ble_gap_rssi_start(m_conn_handle, 0, 0);
            case BLE_GAP_EVT_RSSI_CHANGED:
                //err_code =  sd_ble_gap_rssi_get(m_conn_handle, &rssi,0);
                rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
                num_of_samples += 1;
                rssi_avg += rssi;
                //NRF_LOG_INFO("RSSI AVG=%d; num_of_samples=%d",rssi_avg,num_of_samples);
                //NRF_LOG_INFO("handle 0x%x",p_ble_evt->evt.gap_evt.conn_handle);
                //NRF_LOG_INFO("RSSI %d %d",rssi,err_code);
                if (num_of_samples == 15){
                    rssi_avg = rssi_avg / num_of_samples;
                    if (rssi_avg > -50)
                      bsp_board_led_on(BSP_BOARD_LED_0);
                      bsp_board_led_on(BSP_BOARD_LED_1);
                      bsp_board_led_on(BSP_BOARD_LED_2);
                      bsp_board_led_on(BSP_BOARD_LED_3);
                    else if (rssi_avg < -60)
                      bsp_board_leds_off();
                    rssi_avg = 0;
                    num_of_samples = 0;
                NRF_LOG_INFO("Disconnected");
                err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                NRF_LOG_INFO("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
          case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
                err_code = sd_ble_gap_auth_key_reply(m_conn_handle,BLE_GAP_AUTH_KEY_TYPE_PASSKEY, STATIC_PASSKEY);
           case BLE_GAP_EVT_SCAN_REQ_REPORT:
                // NRF_LOG_INFO("SCAN REPORT SENT");
              //   int8_t rssi;
             //    rssi = p_ble_evt->evt.gap_evt.params.scan_req_report.rssi;
             //    NRF_LOG_INFO("RSSI:%d",rssi);
             //    ble_gap_addr_t  peer_address;
                 //p_ble_evt->evt.gap_evt.params.connected.peer_addr.addr
             //    peer_address = p_ble_evt->evt.gap_evt.params.scan_req_report.peer_addr;
                 //p_ble_evt->evt.gap_evt.params.scan_req_report.adv_handle.
              //   NRF_LOG_INFO("peer:%d",peer_address.addr);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        //according to https://devzone.nordicsemi.com/f/nordic-q-a/35675/how-to-use-static-passkey-for-a-no-display-no-output-peripheral
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    static void delete_bonds(void)
        printf("\r\nErase bonds.\r\n");
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        //APP_ERROR_CHECK(err_code);
    /**@brief Function for application main entry.
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        set_static_passkey();
        peer_manager_init();
        advertising_init();
        conn_params_init();
       //delete_bonds();
        // Start execution.
        NRF_LOG_INFO("Blinky example started.");
        // Enter main loop.
        for (;;)
            idle_state_handle();
    This are the code. I dont think the phone is the problem, And I think the second solution is implemented in the code
  • Hi
    In projects where the peer manager is missing we handle some of the security related callbacks in the ble_evt_handler. Try removing/commenting out BLE_GAP_EVT_SEC_PARAMS_REQUEST and BLE_GATTS_EVT_SYS_ATTR_MISSING to avoid any conflicts with the peer manager.
    Simon
